Old 04-01-2009, 11:00 PM   #121
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
A Chevy Astro will run on two stroke (from a bike on the trailer in back) for about one mile.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 04-01-2009, 11:01 PM   #122
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
You can start a freezing cold diesel VW Rabbit by twisting a newspaper and putting it in the air intake and setting it on fire.
Old 04-01-2009, 11:03 PM   #123
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
Raw eggs in a radiator will cook and the whites find holes and block them (for a while)
Old 04-01-2009, 11:04 PM   #124
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
You can wrap duct tape around bald the tire of your R100GS and go about 40 miles
Old 04-01-2009, 11:06 PM   #125
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
You can ride a 1995 BMW R1100RSL twenty miles home without a clutch cable. You run like hell pushing the bike with the engine running in neutral, jump on and snick it in second. At stop lights and junctions you either run them or slick it in Neutral and stop. Then you run like hell again and hop on and stick it in second.
Old 04-01-2009, 11:08 PM   #126
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
If your charging system goes out on your R100GS you can put a car battery on the passenger seat and connect booster cables to the battery leads.
Old 04-01-2009, 11:09 PM   #127
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
deisel fluid rubbed over a dull car will make it shine until it sells in the auction
Old 04-01-2009, 11:10 PM   #128
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
You can 'buff' a car body with AJAX if you have no money, you have to apply polish after though to make it stay.
Old 04-01-2009, 11:13 PM   #129
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
A clothes line from the Supermarket isn't much good for towing a VW Bug
Old 04-01-2009, 11:14 PM   #130
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
You can stuff the front tire of your BSA Bantam with grass and ride it home four miles through a field
Old 04-01-2009, 11:15 PM   #131
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
Three people can fit on a Triumph Bonneville and go fifty miles in the dark on back roads without even SEEING a policeman.
Old 04-01-2009, 11:16 PM   #132
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
Old Mini Coopers can easily be turned back on their wheels (from laying on the door) by two young men
Old 04-01-2009, 11:18 PM   #133
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,998
A Daf Daffodil with variable auto transmission will go 40mph in reverse before you crash
Old 04-02-2009, 03:54 AM   #134
Mungo
Monarch 53
Mungo's Avatar
Oddometer: 356
Great stuff Tuckers. Keep 'em coming.
Alcohol does not solve any problems, but neither does milk.
Mungo is offline   Reply With Quote
Old 04-08-2009, 05:42 PM   #135
Irnworker433
XR650RRRRRRRR
Irnworker433's Avatar
Oddometer: 98
earplug
If your welding with a mig gun and the trigger comes apart and the spring vanishes, you can wad up a foam earplug and stick inside the trigger and continue on with your business. Works great!
Irnworker433 is offline   Reply With Quote
Times are GMT -7.   It's 04:20 AM.
