Old 09-21-2008, 01:07 PM   #1
airansun OP
Ride Wet!
airansun's Avatar
Oddometer: 307
Cry R1200GS Drive Shaft U-Joint Failure @ 58K Miles
Yes, I regret to report that my ‘05 GS has eaten its drive shaft’s front universal joint.
A recent 125 mile freeway trip persuaded me that something might be amiss: going over rises and dips, as the suspension unloaded and recompressed, I observed increased vibration in the pegs and bars. Pulling in the clutch made the symptom much less pronounced. I assumed that a driveline bearing was going.
I got home fine, although I rode slower than typical. The next day (a Saturday), I rode it up to a local bike hangout. On winding two lane narrow roads (under 50 mph), I did not notice anything significant. But, going across long, straighter sections at 60-70, the same symptom was present. I rode the bike home and parked it.
This past Tuesday, I rode the bike into the dealership. By that time, I noticed that there was a rubbing noise at less than 25 mph. Without an appointment, it took the shop a couple of days to get to it. Yesterday, I stopped by and was shown the drive shaft. The u-joint needle bearings were all gone or embedded in the metal. There was about 3/16" play and the metal was all heat colored and deformed. (I will post pictures when I get the part back from the dealer.)
Facts:
Bike has just short of 58,000 miles.
Very little dirt riding (less than 1,000 miles probably) and probably less than 25% freeway either.
At 54,000 miles, the transmission assembly tab on the bike’s frame was repaired. While the bike was split, we replaced the clutch. The input splines were almost completely shot, so the shaft was replaced at that time too. Here’s the link to that thread:
http://www.advrider.com/forums/showthread.php?t=202388&page=2
Obviously, there may be a relationship between this previous problem and the drive shaft.
Just thought you all should know.
PS - The bike does have an extended warrantee.
'06 HP2
'05 R1200GS
airansun is offline   Reply With Quote
Old 09-21-2008, 03:31 PM   #2
CheckerdD
CheckerdD's Avatar
Oddometer: 1,292
Oh Boy now I can look forward to something else going wrong. I am getting tired of the final drive failing. I demand greater variety. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 09-21-2008, 03:37 PM   #3
GsGrins
does his own stunts
GsGrins's Avatar
Oddometer: 259
mine tanked at 41,000 miles. It's a ~ $650. part, u-joint & driveshaft. I traded mine broken on a Sprint ST (ABS)....
GsGrins is offline   Reply With Quote
Old 09-21-2008, 04:22 PM   #4
brenter
Brenter
Oddometer: 370
You must be missing it since you are on this site.
brenter is offline   Reply With Quote
Old 09-23-2008, 04:09 AM   #5
GsGrins
does his own stunts
GsGrins's Avatar
Oddometer: 259
"missing it" ? No, not me. My early '05 was just a lemon from the get-go. I pushed it into Canada w/ 700 miles on the clock (faulty o-ring on fuel pump brain cover) , spent 2000.+ to have the motor resealed. 3 final drive seals in 3 months, clutch slave cyl (new, updated seal failed), then the u-joint/driveshaft failure @ 41,000 miles.
People visit sites like this to gather additional datapoints. I've had trouble free experiences w/ two previous GS's. If I were do do my MotoAmericas ride again the R12GS would NOT be on my list, short or otherwise, for appropriate bikes.
I wish you well w/ yours......
Old 09-23-2008, 09:12 AM   #6
Just_Sean
herewegoagain
Just_Sean's Avatar
Oddometer: 14,504
At least he had some warning - my driveshaft went (the rubber dampener disintegrated) with no symptoms at 58,000 miles
Then the FD Big bearing at 58,600 (same trip )
Fuel pump at 61,000
Maybe I should sell it?
NOT!!!!!! I abuse it - it takes it,
So, when I hit 100,000 miles, (and about every 50,000 after that)I'll change the driveshaft, FD and fuel pump as preventative measures
Just_Sean is offline   Reply With Quote
Old 11-25-2008, 11:45 AM   #7
ShaftEd
ShaftEd's Avatar
Oddometer: 3,349
Front u-joint blew up at 39,000 miles on my 07 12GS too. I noticed a very light pulsating vibe in 6th gear for a couple of hundred miles. Wasn't sure if I was imagining it or not, but it seemed some type of bearing might be going out.
Had an appointment with the dealer for new tires and thought I would have them ride it and see if they felt the vibe too. However, before I could ever get to the dealer, the front u-joint bearing blew up. Gouged the swingarm housing when it went. I'm out of oem warranty, but fortunately, I bought the extended warranty at time of bike purchase (Don't ride a late model BMW without it!). $1800 in parts and labor paid by warranty and she's back running fine. Haven't heard about too many of these, but I do know one other rider in town this happed on their 07 12GS too. Just another worry bead to add to the list.
ShaftEd is offline   Reply With Quote
Old 11-25-2008, 11:55 AM   #8
Wallowa
Oddometer: 5,453
A Dumb Question...But What The Hell...
Front U-joint...any possible link to not lubing the front drive line splines? Could that affect the angle while the u-joint was under load? Most riders [my guess] never lube the front spline on the drive shaft and if the splines do not have the correct movement could that incorrectly or excessively load the front u-joint?
Just askin'
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 11-25-2008, 12:00 PM   #9
ShaftEd
ShaftEd's Avatar
Oddometer: 3,349
Fas as I know front splines were never lubed other than at the factory. I had the dealer replace FD oil at the 600 service, and then again at 36k miles. No FD issues to report.
Old 11-25-2008, 12:06 PM   #10
Wallowa
Oddometer: 5,453
Front and Rear Splines..
Front and rear splines on the axles are service items...I use Moly 60 on them.....nothing to do with FD issues other than those of us with drain plugs at 8 o'clock on FD need to drop it when changing FD lube and that makes it easy to lube splines..
"In Wallowas"
Old 11-25-2008, 12:43 PM   #11
ShaftEd
ShaftEd's Avatar
Oddometer: 3,349
Wallowa, How often are you doing the spline lube. I'd imagine it's whenever you do the FD oil change too?
I've never known the 12GS to have a maintenance schedule for the splines.
Old 11-25-2008, 12:44 PM   #12
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,377
Just askin'
This should have nothing to do with lubing the front splines since the splines are locked by the C-clip. The rear splines move just a tiny bit for any needed compensation.
If I had to guess I would suggest the front U-joints were improperly lubed at assembly which caused them to fail.
Jim
Old 11-25-2008, 02:56 PM   #13
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,400
Jim
OK everybody, pull them puppies apart and see if they have enough lube in them.
You know BMW put "Lifetime" lube in these parts, just like the early FDs.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 11-25-2008, 03:27 PM   #14
Wallowa
Oddometer: 5,453
Right..I Forgot About Clip
Jim
Yup I forgot about the front clip which will hold if not lock in the shaft on the splines....lube is to keep the splines from corroding..
SE...I do drain and change my own FD on an 8,000 mile schedule [Redline Heavy Shockproof lube]...excessive perhaps but I ride almost entirely in the dirt and through mud/water/snow so lubing the splines is part of the FD lube change protocol for me...
All this lets me check on wear and hopefully spot problems before they disable the bike or become expensive!
"In Wallowas"
Old 11-25-2008, 03:47 PM   #15
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,130
Does BMW have some secret plan to make a shaft drive require as much or more maintenance than a chain? Perhaps they are trying to make the shaft obsolete?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Times are GMT -7.   It's 12:32 AM.
