Old 05-30-2012, 12:41 PM   #76
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,752
On my 1150 Adventure the first driveshaft was replaced at 97,000 miles. The front joit was loose but not exploded.
The second driveshaft died at around 168,000 near redline in third gear.
That took out the swingarm as well.
There were no swingarms for 1150's in the US. No estimate on when. Cost new was in excess of $800 plus the $700 drive shaft.
A friend found two used swing arms from Ebay resellers. I got one for less than $200.
Badne$$
more badne$$
New to me
All better,
I was two miles from home and the asshat behind me passed me on the right forcing me into the triangle between the ramp and freeway when it all let loose.
I now pull the swinging arm off and the shaft and feel the u-joint every year, or about 20,000 miles. It's just cheaper that way.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 05-30-2012, 03:23 PM   #77
franzzzzzzz
shut up and dance
franzzzzzzz's Avatar
Oddometer: 59
Originally Posted by Mr Head View Post
more badne$$
Swingarm dont look to bad..Why change for another ? Is there more serious gouge ?
I had same experience last year and paralever was grind a bit but reusable.
franzzzzzzz screwed with this post 05-30-2012 at 03:33 PM
franzzzzzzz is offline   Reply With Quote
Old 05-30-2012, 09:27 PM   #78
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,752
There is evidence of cracks. I bought and installed another.
The "another" was free from visible problems.
...Dick
Smugmug
Old 05-31-2012, 04:03 AM   #79
Spout
English GStleman
Spout's Avatar
Oddometer: 152
Originally Posted by tommyvdv View Post
can't see the pics
Try:
http://www.ukgser.com/forums/showthread.php?t=300233
All sorted now. Had to buy a new rear drive as the shaft into FD was bent.
Past the first flush of youth, but not yet at the frequent flush of old age.
Spout is offline   Reply With Quote
Old 05-31-2012, 04:12 AM   #80
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,331
I had mine rebuilt after seeing the carnage Mr. head posted..peace of mind is priceless
Tbone is offline   Reply With Quote
Old 06-01-2012, 05:09 AM   #81
tommyvdv
tommyvdv's Avatar
Oddometer: 420
could a dying shaft (increased resistance of U joint bearings thus increased vibrations) kill the wheel bearings?
I've noticed play in my rear wheel. This was not the case before the shaft crapped out on me once. Replaced the bearings 5k km's ago. Waiting for dealer to bring it in for a new shaft + seals.
tommyvdv is offline   Reply With Quote
Old 06-01-2012, 05:15 AM   #82
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,331
I doubt it. Your just paying more attention to the amount of slop now that the driveshaft crapped out.
Old 06-01-2012, 06:10 AM   #83
tommyvdv
tommyvdv's Avatar
Oddometer: 420
friend of mine had play on his rear wheel and metal in the oil. After he told me this i checked my rear wheel and was happy to find out there was no play in there. This was about 7k kms ago. A while before my driveshaft crapped out.
Good to know the chances of the one affecting the other are low.
Old 05-30-2013, 05:12 PM   #84
dutch97501
dutch97501's Avatar
Oddometer: 114
At the end of last summer I noticed a vibration on my 09 GSA. I wrote it off as a tire ballance issue and rode thru the winter. The bike now has 39k on it and I spare no expense on it. I am planning a dual sport vacation this year and thought it would be a good idea to run the ESA in offroad max mode for a few weeks prior to my vacation to get use to the added ride height. As soon as I increased the angle on the para lever my vibration multiplied. Vibes in the foot pegs and the bars at 35 to 40 mph in 4th gear in offroad max was what it took for me to stop and say"wait a minute something's not right". I pulled the drive shaft and found the front unoint just starting to fail. I took the shaft to my local dealer and was told of the $1000 replacement shaft. Thank god for extended warranty's. I guess what I'm trying to say is if you have a GS with ESA and you pickup a vibration use it to check the unoints!
dutch97501 is offline   Reply With Quote
Old 05-30-2013, 05:18 PM   #85
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
Try to get your old shaft back..they let me have mine after 60 days..(BMW NA didn't require it) So I have that one to rebuild and put servicable joints in..adn when I swap it..I'll have another as well..to fix up and sell.
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 05-30-2013, 05:23 PM   #86
dutch97501
dutch97501's Avatar
Oddometer: 114
I will ask. Where can you get replacement unoints?
Old 05-30-2013, 05:24 PM   #87
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
Bruno..or..I just had Driveline service hook me up here in Oregon..need to go pick them up..
Old 05-30-2013, 05:29 PM   #88
dutch97501
dutch97501's Avatar
Oddometer: 114
Really. I'm only a few blocks from driveline service as I type. Thanks
Old 05-30-2013, 05:40 PM   #89
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
Joe Delk has my parts..if you stop in..have him get you what he got me..and tell him I haven't forgot him!! I will be in next week to pick mine up..
Old 05-30-2013, 06:28 PM   #90
dutch97501
dutch97501's Avatar
Oddometer: 114
First hansens has to let me keep the old shaft!
Times are GMT -7.   It's 03:40 PM.
