03-21-2011, 02:23 PM
#31 |
Oddometer: 254
did a bit more work to the k at the weekend to seats only temporary
03-21-2011, 02:28 PM
#32 | |
Oddometer: 254
03-21-2011, 03:00 PM
#33 |
Oddometer: 524
What headlight did you use?
03-21-2011, 03:04 PM
#34 |
Oddometer: 254
another photo from the front going to make a aluminium tail piece to fit under the rack to cover the wiring going to have a go at making a seat the one in the photos just to get an idea of hight and hopeing to fit a acewell speedo
ver the wiring
jings screwed with this post 03-21-2011 at 03:11 PM |
03-21-2011, 03:10 PM
#35 |
Oddometer: 254
03-21-2011, 04:44 PM
#36 | |
BMW uber alles!
Oddometer: 969
Btw, my dad's dad came from Kirriemuir/Forfar wee bit north of Perth...my regards to Scotland along with wishes for a great outcome with your K100 re-do!
=Zagando= 1994 BMW K75S 2003 Honda Ruckus Recent K75S renovation: www.tinyurl.com/njaltf ex: '92 R100GSPD '85 K100RS '73 R75/5 '65 R60/2 |
03-22-2011, 12:36 PM
#37 | |
Oddometer: 254
03-22-2011, 03:00 PM
#38 |
BMW uber alles!
Oddometer: 969
Yeah, I know, I was there back in '94 but got around on foot, bus and train.
Once you get that bad boy up and running you should have a blast across all those two-lane twisties and open stretches. Gorgeous countryside, too. My ancesters are buried in the church cemetary just outside of Glamis Castle. Are you going to polish out that tank further or leave it as is, kind of frosty satin? I sanded and sanded and buffed and buffed and it was really a ton of work. I never managed to get the perfect polish I was seeking but I came close. ![]() ![]() One nice thing about polishing out an aluminum K-bike tank is that it costs next to nothing (sandpaper and polish)---but adds some real pizazz... Boils down to how much elbow grease you're willing to invest, though.
03-22-2011, 03:41 PM
#39 | |
Oddometer: 1,490
awesome!!!!! |
03-23-2011, 12:15 PM
#40 | |
Oddometer: 254
05-10-2011, 01:04 AM
#41 |
Real men ride sidecars
Oddometer: 828
G'day
What do you reckon the weight of a naked K1100 would be, just like what you guys have done with yours. I'm toying around with the same idea, to totally strip the bike and just keep whatever I need to keep it roadworthy. Cheers 3legs |
05-10-2011, 05:03 AM
#42 | |
Oddometer: 939
![]() ![]() Having had the K100 in bits to do the chair, I'm thinking there is a good 20-30 KG in an RT fairing including the spider mount bit. I'd go for the lower figure as it'll need mirrors* and a fork mounted headlight. * The bars have holes/threads for mirrors but I'm lead to believe that the K100 had solid not rubber mounted bars, so I might need to change there too. I'd want to keep the speedo and clocks for navigation use. As I want a pair of halogen lights, the saving will be less still, but not as much as adding fog lamps to the fairing. Andy |
08-23-2011, 04:41 AM
#43 |
Oddometer: 4
Naked K100
Hiya, I found your post here Jings while searching for others who have naked K100 projects. Lookin good so far!
I joined this discussion (and the forum) because I want to get rid of the gauge-cluster on my K100 (formerly an RT that I stripped down) and put some more attractive round gauges on. I want to ask what you are using for gauges but I don't see any on yours... what kind of gauges do you intend to put on your K100? More importantly I guess, if you are using aftermarket ones, will you need to have custom speedo/odo cables made or ?? This the situation that perplexes me...what will match up. Thanks. Kaze screwed with this post 08-23-2011 at 06:03 PM |
06-09-2012, 03:42 PM
#44 |
scooter
Oddometer: 84
did you have to reconfigure any wiring? i'm in the process of doing the same thing and want to remove hazards, elec grips, horn, etc and want to make sure it doesn't incomplete a circuit. this came up because i don't seem to be getting juice to the injectors but it may be a whole different issue. also, where'd u mount your ignition? thx
06-09-2012, 09:57 PM
#45 | |
PsyKotic Waterfowl
Oddometer: 10,109
What about the fuel pump? Is that getting power? Year and model are also helpful......
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR IBA #17739 (SS1K, BBG, 50CC) http://home.comcast.net/~smithduck/BMW_Tours.htm |
