Old 06-05-2009, 08:24 AM   #91
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,116
Originally Posted by datchew
after the picture in your "so i sold my GOOD PARALEVER and bought a JUNK MONOLEVER" thread....
Dude, jealousy is an evil emotion....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 06-25-2009, 09:09 AM   #92
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,116
I'd do the same. If it's 180 out, it might just minutely change the timing and you did that by removing it anyway so no biggy..
Update on my side... after stripping and cleaning my can I had a backfire.... after finiding I had my timing wrong, and then swinging it all the way to the end of the can's adjustment I find that while the timing is now spot on, I still have a slight pop... might be carb synch so I will re-set that first..
If that doens't fix things (or perhaps regardless) I'm gonna pull the can and rotate the key locator 180 degrees and see what happens
R65LazaruS
Old 06-25-2009, 10:11 AM   #93
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Slight pop -> lean idle mixture
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 06-25-2009, 10:23 AM   #94
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,116
you would think, but I took the mixtures out to where the idle stumbled turned in a tiny bit and has the same pop...
I am thinking unsynched cables and perhaps one butterly is closed while another is open under very small throttle openings
R65LazaruS
Old 06-25-2009, 10:28 AM   #95
StephenB
StephenB's Avatar
Oddometer: 2,044
Is that another proper way to do it? I have the rpm not coming back fast enough to idle (engine brake not as effective as it was), and I am thinking too lean mixture (valves are freshly adjusted at 4/8) as I have a bit of popping too. Can I use your procedure? How much is tiny?
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 06-25-2009, 10:39 AM   #96
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,116
Have you cleaned your ignition advance weight set-up?
Mine had been doing that hanging at a higher idle a bit for years and never popped, as soon as I cleanded the advance it stopped completely...
R65LazaruS
Old 06-25-2009, 11:17 AM   #97
StephenB
StephenB's Avatar
Oddometer: 2,044
OMEGA Ignition
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
StephenB screwed with this post 06-25-2009 at 11:44 AM
Old 06-25-2009, 06:12 PM   #98
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,220
OMEGA Ignition
You could open the intake to 6 and no one would know.
I think the valve adjustment is designed to drive me nuts. I know I cant fit the .2mm in to the intake, so it must be good.
Isnt hanging idle a possible sign of small air leak? I just did a valve and carb adjust...Used Bings idle procedure. Slight popping is lean, I heard, as well. And on Decel it would on the idle circuit. I've been popping on decel since I put the Staintune and Ypipe on.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 06-25-2009, 08:11 PM   #99
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,851
If the idle hangs or increases at a stop then it is probably the can - easy way to tell is to shut the bike off and then re-start - usually it will return to set idle unless really dirty like mine was
Air leak - mist a little starting fluid/ether around the joints and see if it increases from a steady idle or blows up
Had a great time last weekend rebuilding the carbs with the full Bing kit and re-cleaning the can again. I had to special order the tri-flow lub I've heard ya'll talk about
The amount of crap around the main jets after 50k miles was totally astounding
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 06-26-2009, 08:16 AM   #100
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
this ain't soundin like bean can talkin to meh.
Put this stuff in the Phil Collins paralever jealousy neverending upgrade thread.
datchew is offline   Reply With Quote
Old 06-26-2009, 08:32 AM   #101
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Oooohhhhhhh, burrrrrrrrrn.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 06-26-2009, 09:08 AM   #102
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,116
oooh, ouch...
whitty response forthcoming
R65LazaruS
Old 06-29-2009, 06:08 PM   #103
adrenal
skrunkwerks.com
adrenal's Avatar
Oddometer: 570
Interesting thread.
I've been mucking around with my hall effect beancan for dual plugging.
Discovered a few things, one of which is that earlier hall effect beancans had heavier bobweights and slightly stiffer springs. If you combine the earlier springs with the later lighter bobweights then this stretches the timing curve a bit (RPM at which max advance occurs.) I just started a blog. 1st chapter is about timing for dual plugging. It contains a dyno run comparing 2 beancan strategies for dual plug timing.
I'm pretty sure that my modified beancan is suffering from stiction despite me cleaning the innards and using a light grade teflon filled silicon grease on the rotating bits. I might have missed previous posts on this but I googled Tri-flow. What I found is a drying type lubricant. Is this what people have had success with?
Blog is here:
http://www.cafebeemer.com.au/blog.htm
adrenal is offline   Reply With Quote
Old 06-29-2009, 07:56 PM   #104
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
Originally Posted by batoutoflahonda
Been following this thread and wondering how the fab is going. Thinking about doing the same thing on my '80 G/S because I want to go with the enduralast alternator.
An Enduralast is a good idea. I have two of them. On my G/S, it went through about 20 countries in 2006/2007. It's a "Honda" sort of experience... It never fails, never waivers and it makes the whole charging/battery discussion seem like some old dinosaur thing.
Malindi is offline   Reply With Quote
Old 06-29-2009, 08:12 PM   #105
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,851
I finally used the tri-flow dry but only used it on the sliding portion. Took it apart and cleaned with scotchbrite soaked in brake cleaner
I used the reg tri-flow liquid on the weights and the upper bushing
The bore of the sliding portion was a little scored up but the hope is the dry will kind of fill the grooves - works so far
Times are GMT -7.   It's 04:37 PM.
