Old 09-22-2008, 02:27 PM   #1
PRJKTM OP
Oddometer: 63
990 Vibration
I took my new 990 Adventure up the motorway for the first time today and was amazed at the terrible engine vibration I get through the handlebars.
Cruising at anything about 4500 revs its so bad that it vibrates right up my arms.
The 950 I just traded in didn't have any vibration.
Any Ideas ?
PRJKTM is offline   Reply With Quote
Old 09-22-2008, 02:40 PM   #2
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
I just tested one and I thought it was very smooth. Then again I drove in on a thumper.
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is offline   Reply With Quote
Old 09-22-2008, 02:48 PM   #3
mookymoo
Mookish Mook
Oddometer: 4,396
Originally Posted by PRJKTM
Any Ideas ?
Throttle body balancing (still relavent on the 990, no?)
mookymoo is offline   Reply With Quote
Old 09-22-2008, 02:50 PM   #4
Pax
shazam.
Pax's Avatar
Oddometer: 812
Mine is very smooth. I would drive right back to the dealer and ask them to test it out for you if you can't get it sorted immediately. Have you checked all fasteners, engine oil, chain tension, etc?
Any Ideas ?
Pop & Pax - West TAT 2009
The Dean of Adventure Routes
“Character is much easier kept than recovered.” –Thomas Paine
Pax is offline   Reply With Quote
Old 09-22-2008, 06:45 PM   #5
nunzo
nunzo
nunzo's Avatar
Oddometer: 306
Engine Vibration through the bars?? How about tire balance issue?
nunzo is offline   Reply With Quote
Old 09-23-2008, 01:58 AM   #6
minusone
minusone's Avatar
Oddometer: 1,295
I reckon that might be a problem with mine.
minusone is offline   Reply With Quote
Old 09-23-2008, 03:54 AM   #7
PRJKTM OP
Oddometer: 63
Definately not tyre balance because if you clutch in it goes, the vibration is also just as bad when you just rev the engine at a standstill.
The dealer said to let the engine run in and loosen up and bit because it's only done 750 miles but I'm not convinced as my 950 never had this problem.
Old 09-23-2008, 08:03 AM   #8
fnfalman
fnfalman's Avatar
Oddometer: 221
Any Ideas ?
A lot of that vibration comes from both the windshield and the handguards too.
2004 BMW Rockster (Tiger Stripe, baby!)
2006 Aprilia SR50 Factory
2009 Aprilia RS125 (USA model)
2007 Aprilia Tuono
2007 KTM 990 ADV
fnfalman is offline   Reply With Quote
Old 09-23-2008, 01:28 PM   #9
Pax
shazam.
Pax's Avatar
Oddometer: 812
If you hadn't had a 950 I'd wonder if you were just touchy. However, the 990 should be just as smooth. It just doesn't sound right. Mine was smooth from day one. I'd go back to the dealer and ask them to look it over top to bottom again.
Old 09-23-2008, 02:37 PM   #10
PRJKTM OP
Oddometer: 63
I did think when I bought the bike that there was more vibration than my 950. But its definitely worse after I picked it up from the first service.
You can even feel it through the seat and when I got off the bike tonight my arms actually ached.
I hope this isn't 'just one of those things' because it will drive me mad !
Old 09-23-2008, 03:15 PM   #11
Mad Kaw Disease
Dual Sport Diseased
Mad Kaw Disease's Avatar
Oddometer: 534
Something definitely wrong with THAT bike (I know ....duh), I just mean it's not common to the model. Mine lugs like any V-twin at low RPM but really gets and stays it's smoothest starting about 4000 rpm.
2007 KTM 990 Adventure
2014 BMW R1200RTW
"I was going faster than I ever went in my whole life and I fell off...." Little Fauss
Mad Kaw Disease is offline   Reply With Quote
Old 09-24-2008, 08:36 AM   #12
Tripndrag
Tripndrag
Tripndrag's Avatar
Oddometer: 76
06 950 - Try adjusting the suspension. I went through all the settings listed in the owners manual and found the setting everything to comfort was the best when it was new. The performace setting gave lots of vibration. After a couple thousand miles I was able to crank everything to performance with no vibration. I also found going 45-55 MPH in top gear results in lots of vibration due to the motor lugging. My speedo is off 5 MPH when compared to my GPS also. Some roads around me are 50 MPH and I was really riding around at 45 MPH thinking I should re-gear the thing. 50 MPH is about as slow as I go in top gear before shifting down on flat ground. Hope that helps.
Tripndrag is offline   Reply With Quote
Old 09-24-2008, 09:15 AM   #13
emerson.biguns
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 10,426
I've got the same problem with my '04 Adventure. 4200-4500 there's a horrible vibe.
Can't be tires/suspension. It's RPM related not speed related.
Tell me about throttle body adjustments? Cause and effect?
Thanks,
John
Owner of the Fainting Goat (a 950 Adventure that spends a lot of time on its side...)
(BTW, it's more jiggly than my DR350!)
emerson.biguns is offline   Reply With Quote
Old 09-24-2008, 09:51 AM   #14
lc8john
lc8john's Avatar
Oddometer: 535
Do one trip on highway above 6k rpm and 16x45 transmission and you will see what is vibration!
Husaberg FS 570
lc8john is online now   Reply With Quote
Old 09-24-2008, 10:30 AM   #15
emerson.biguns
Oddometer: 10,426
I read CP's article on carb syncing and have some questions...
The STE flow meter that CP recommends comes in two sizes and an adapter is available. Which parts do I need?
Using that flow meter, it sounds like I don't need to tap into the vacuum connections on the carbs? Just measure the flow at the intake? Do you need two to measure both simultaneously?
Times are GMT -7.   It's 01:24 PM.
