Old 07-19-2009, 03:29 PM   #241
mrb3w
Oddometer: 74
Originally Posted by Jack90210
I always recommend Tim Morris in Stanardsville (Morris Cycle), but that's not exactly "close." What kind of clutch work?
Looks like about ~30 mins on a good day... not too bad. I don't feel the clutch slipping at all, it's just a bit sloppy to (dis)engage.
mrb3w is offline   Reply With Quote
Old 07-22-2009, 06:51 AM   #242
HBN
lostwithmike.com
HBN's Avatar
Oddometer: 11,984
Riding and Camping on DS bikes this weekend if any of you folks are interested:
(Link in my sig line)
Lost with Mike
12' Ruckus, 01' R1150GS, 75' XL250
Old 08-15-2009, 07:18 PM   #243
HBN
lostwithmike.com
HBN's Avatar
Oddometer: 11,984
Hello...anyone home?
Crozet Pizza, Sunday @ Noon.
HBurgNinja
Kawikazi (&wife)
mikeinrichmond
FOXedupONE
hppyfngy (maybe?)
Lost with Mike
Old 08-17-2009, 12:00 PM   #244
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,281
I'm working this weekend.
Avoid Charlottesville if you can, it's "Move-In Weekend" at UVA. Do not, repeat DO NOT, go shopping in Charlottesville this weekend.
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 is offline   Reply With Quote
Old 08-22-2009, 10:34 AM   #245
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,127
Hey Guys, who has a metric tap set? (M6-1.0)
I need to open up a messed up nut on the frame of the Versys...
Some say I'm apathetic, but I don't care. - Randy
'13 KLR 650 For Sale!
'07 KLX250s
hppyfngy is offline   Reply With Quote
Old 08-22-2009, 11:12 AM   #246
FOXedupONE
Momafox can I ride?
FOXedupONE's Avatar
Oddometer: 2,546
I have extractors that work if you drill into it for like messed up philips heads but for a tight bolt it might be time to go to sears and get the special kit for the rounded off bolts.
Just return it when you're done if you don't want to keep it. It's just like borrowing tools.
FOXedupONE is offline   Reply With Quote
Old 08-22-2009, 11:19 AM   #247
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,127
The bolt is out but the nut (welded to frame) is cross threaded.
It only holds the cowl on so if I can get some thread grip I think it will be okay, but I don't have a tap...
'07 KLX250s
Old 08-22-2009, 11:24 AM   #248
mtnflow
LFC, more pie please
mtnflow's Avatar
Oddometer: 2,327
Is it into aluminum? I've used the bolt to "retap" the nut by screwing it in until it gets tight, then back it out and spray with wd40 and screw it in again. Just screw it in deeper and deeper until you have an orgasim or it's fixed which ever.
mtnflow is offline   Reply With Quote
Old 08-22-2009, 11:44 AM   #249
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,127
Aluminum? Pig iron is more like it. This is a Kawasaki, man...
I tried that until I stripped the allen head out of the damned bolt...
One of those episodes
'07 KLX250s
Old 08-22-2009, 12:31 PM   #250
FLASH-GS
FLASH-GS's Avatar
Oddometer: 178
hppyfngy>If you have a spare bolt & nut the same diameter & thread pitch you could fabricate a make shift tap AKA "thread chaser". Better than a tap in most cases for repairing buggered threads.>>step 1>Thread nut on bolt(to clean up bolt threads) 2>carefully grind or file one side of bolt threads flat just past the thread depth. 3> remove nut from bolt working back & forth to clean up bolt threads of any burs. 4>oil up & chase threads to be repaired.(carefully working thread chaser bolt back & forth)>>This works better on coarse threads but will also work on fine threads if careful.......... Flash >>>P.S. > Might be able to find one I've made for a pic if you need it. I know the few I have made are standard/fractional threads or I'd be looking for size you need.
FLASH-GS is offline   Reply With Quote
Old 08-22-2009, 12:43 PM   #251
FLASH-GS
FLASH-GS's Avatar
Oddometer: 178
Just checked in my metric set & also have the tap if you need it. .............Flash
Old 08-22-2009, 01:25 PM   #252
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,127
Thanks Flash, I'll have to try that! Excellent solution.
'07 KLX250s
Old 08-23-2009, 04:40 PM   #253
Bowtie76
Bowtie76's Avatar
Oddometer: 320
If that doesn't work I've got metric taps you could borrow.
Bowtie76 is offline   Reply With Quote
Old 08-23-2009, 06:44 PM   #254
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,127
thanks
in-laws in the area...time is not my own...
'07 KLX250s
Old 08-23-2009, 08:28 PM   #255
big_sur
Tarded
big_sur's Avatar
Oddometer: 715
So I've been lurking around for a while but I thought I'd finally come out and see where y'all are riding around here. I just moved back to cville to finish up school, thought I'd get back into the whole bike thing, and so now I'm looking for some good sunday rides.
I just picked up a drz sm, so while I'm not strictly limited to pavement, I'm not terribly confident in the dirt having come from street bikes. That and I went down to the south pedlar atv trails and learned the hard way that pilot powers don't shed mud terribly well. That said, I'm definitely open to trying out the dirt\gravel if y'all have some must-do dirt rides.
I started exploring a little today and did 53 to carter's mtn rd down to Scottsville this morning. Then after lunch I headed back up and then over to crozet and up 810 to 33; so I've got those knocked off the list. What's next?
big_sur is offline   Reply With Quote
Times are GMT -7.   It's 05:45 AM.
