Old 11-25-2010, 12:23 AM   #1546
rocketron
Megamoto/990 SMR
rocketron's Avatar
Oddometer: 27
Ok Guys - many thanks for all your responses. I will start with setting everything back to standard on a high ride height and then see how it goes. Could be a while before I get to ride it though - the weather has turned cold and the salt gritters are out. I found this company from an internet search, they are fairly close to where I live so I could use them if major changes are required to spring ratings etc, looks like they also have links to Racetech.
http://www.moto-pro.co.uk/index.htm
rocketron is offline   Reply With Quote
Old 11-26-2010, 05:34 AM   #1547
air-cooled
air-cooled's Avatar
Oddometer: 229
marc, if you only turned back preload, i would say that this tuning is well within the range of what is possible with the standard spring. to say that the set up is completely out of range is than a bit to much. offcourse this was a very important change for you, why not try 1 turn more and see how that works out.
further i do agree with joe bar, as everywhere to find on the internet, do not take over the settings from somebody else, because you are not that some body. like hpsaucy did, you can let somebody ride on your bike but their findings are of no importance, so infact it is of no use to get any valuable information.
if you want any source of information regarding suspension for the mm, hpsaucy did make a start on his page, other information like weight, ride style, road/track, fast/ illegal, and more important how many turns is your preload , fast and slow inbound, what is your static and activ sag for front and back. only then one can start to compare or do something with the info for your own good.
it must be strange to read that rote eddy with his feather weight has no complains and that marc only needed to turn down his preload to have a bike that suites his needs. but with the other info maybe this can be put in a better respect. a spring works very light with little demping and harder with more demping, if this info is not known, there can be no comparison.
air-cooled is offline   Reply With Quote
Old 11-26-2010, 01:35 PM   #1548
GSMarc
GSMarc's Avatar
Oddometer: 1,120
well, you are right
I can check my settings and publish them. I assure that as it is now, even on tracks for education to circuit with De Radigues or Mertens school, the bike is just fantastic for me.
I don't want to sell it anymore as I have no passion with bikes, they are only tools for fun but no "blind passion".
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 11-26-2010, 01:43 PM   #1549
air-cooled
air-cooled's Avatar
Oddometer: 229
actually, i am interested in your settings marc, i carry just a little less weight than you and the riding conditions are comparable, track and ardennes etc.
Old 11-26-2010, 08:16 PM   #1550
HPSaucy
HPSaucy's Avatar
Oddometer: 291
I'd also love to hear your setting, the main reason I set up my site is to be an easy place to find things like that.
macfly
MM # 99526
S # 70020
www.HP2.info
HPSaucy is offline   Reply With Quote
Old 11-27-2010, 12:44 AM   #1551
GSMarc
GSMarc's Avatar
Oddometer: 1,120
Hi,
I did some pics, easier than to explain.
The fork & rear are fixed in original position, the higher ones.
Factory settings in first post.
My settings in last post.
The last sentence means that I soften the pre-load spring (rear) for 1 lap.
Hope you understand
http://jemelapetenflat.xooit.be/t133...part-usine.htm
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
GSMarc screwed with this post 11-27-2010 at 12:50 AM
Old 11-27-2010, 02:10 AM   #1552
air-cooled
air-cooled's Avatar
Oddometer: 229
thnx.
Old 11-27-2010, 11:48 AM   #1553
Megathumper
Megathumper's Avatar
Oddometer: 837
Originally Posted by GSMarc
Hi GSMarc, I can see your pics and understand what you are saying, what is the starting point? Is it + clicks until go no further and then - clicks back to your positions??
And... - clicks is anti-clockwise?
"A ham sandwich is better than nothing
Nothing is better than eternal happiness
A ham sandwich is better than eternal happiness"
Megathumper is offline   Reply With Quote
Old 11-27-2010, 11:49 AM   #1554
HPSaucy
HPSaucy's Avatar
Oddometer: 291
Thanks Marc, I've also added it to my database. I know it sounds funny to say this, but with so few of our bikes out there, and the water cooled boxers just a year or so away I think our bikes are going to become incredibly collectable classics, as well as being a blast to ride, so thats why I'm trying to keep as much long term info as I can.
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-27-2010, 11:57 AM   #1555
HPSaucy
HPSaucy's Avatar
Oddometer: 291
Megathumper, will all valve based suspension tuning it is always done by click out from the full shut or "+" postition,
The easy visualization is that it is a tap, and full "+" is shut. Each click open allows more fluid to flow. It is always a more accurate measurement from full shut than full open, thus always close the valve, and measure amount of clicks of the opening.
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-27-2010, 03:17 PM   #1556
Megathumper
Oddometer: 837
So that I get this right, like a tap, full "+" shut is all way in clockwise? Then, back it (anti-clockwise) from there the number of "-" clicks.
Old 11-27-2010, 04:26 PM   #1557
hankgs
Oddometer: 1,913
Well said...
Good job of the description Andrew...
hankgs is offline   Reply With Quote
Old 11-27-2010, 05:51 PM   #1558
HPSaucy
HPSaucy's Avatar
Oddometer: 291
In every application I am aware of yes, all the shock tuning I've done on cars at the track the screw diriction has been conventional - clockwise to close, anti to open, but alwasy check the '+' & '-' because someone out there may find a reason use a reverse thread for some reason.
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-27-2010, 06:00 PM   #1559
HPSaucy
HPSaucy's Avatar
Oddometer: 291
oh yes, and the '+' means stiffer, or less liquid passing through the valve.
The other thing not often explained but easy to understand is that the scale of flow through the valve is not linear. The difference in from -1 to -2 is almost 100% while the difference between -17 & -18 is only around 5%.
That is also why it makes the most sense to start things out in the middle of the range and adjust from there, all other things being equal.
After 10 years setting up track day cars I'm very familiar with suspension set ups for 4 wheelers, but honestly I'm still at the begining of the learning curve for bikes!
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-27-2010, 08:22 PM   #1560
szazbo
Oddometer: 199
New owner of MM 99583 today
Well after reading all 104 pages of this thread, what else could I do? Found this '08 w/ABS Megamoto at a dealer in Escondido CA today and added it to the stable. Also have a 09 RT and the wife picked up a '10 650 GS at the same time. Bike has 1900 miles and is in great condition except the stock Akra can was damaged in shipping. Anyone have one in the corner of their garage in good condtion that they want to get rid of? Sure is fun to ride! Add me to the list!
szazbo is offline   Reply With Quote
Times are GMT -7.   It's 05:10 PM.
