Old 07-20-2011, 04:33 PM   #1891
diranne
Oddometer: 32
Abs
Thanks guys - I knew it would be complex!
I live in Perth WA and for 90% of the time we have beautiful dry roads; however, when it rains they turn to oilly slickness. Not fun at all!
diranne is offline   Reply With Quote
Old 07-21-2011, 08:29 AM   #1892
Macroenie
Macroenie's Avatar
Oddometer: 206
I just installed one of these (the long version) and did a quick test run. Conclusion, the bike runs much smoother from the get go. I can go around roundabouts in 2nd without having to use the clutch or ride like a madman
The pesty lean range between 3k and 4k seems to have vanished, the pull is much stronger. All in all the engine just runs smoother at lower revs and seems to have gained some extra punch when accelerating. A 43 Euro's well spend, best addition to the bike so far.
Regarding installation: it comes with a sheet of install instructions in english, dutch and french.
Although some of the images do not resemble the megamoto and instead of only having to remove the left side panels you also have to remove the other side and raise the back-end of the tank to get access to the plug that you need to switch. I just stuck a pair of pliers between the tank and the frame, the slack in the fuelline is just enough to do this.
Then its a matter of unplugging the connector from the airbox, plugging the one from the cable in the airbox and connect the two remaining plugs. I then brought the temp. thingy to the front and tied it to one of the upper frame tubes.
About a ten minute job when you know what I had to find out.
Cheers
Jeroen
http://www.sol2.be/Performance/ENG/Home/index.html
Macroenie is offline   Reply With Quote
Old 07-21-2011, 09:02 AM   #1893
Joe Bar OP
Middle England
Joe Bar's Avatar
Oddometer: 1,369
I fitted one of these to my F800R, ten minute fit, definite improvement in running, and the fuel consumption has improved by about 10%. I must admit I was sceptical for the price, but it does seem to do what it says.
"Style is not a decoration added to a functional structure, it's a work of art."
Joe Bar is offline   Reply With Quote
Old 07-27-2011, 04:54 AM   #1894
Macroenie
Macroenie's Avatar
Oddometer: 206
hmmm...this is something I am going to consider
I´m not so sure about the connection of the lambda sensors though, that looks rather strange to say the least.
Prices as quoted by SR-Racing
I think this is the steel version: Komplettanlage 3DVA VK inkl. 1094,90€
The complete Titanium system: Komplettanlage Titan VK inkl. 1190,10€
SR-Racing GmbH & Co.KG
Auspuffanlagen
Königslachener Weg 9
86529 Schrobenhausen
Tel. : + 49 8252 9055 40
Fax. : + 49 8252 9055 39
<http://www.sr-racing.de>
<mailto:info@sr-racing.de
Macroenie screwed with this post 07-27-2011 at 04:59 AM
Old 07-27-2011, 07:33 AM   #1895
HPSaucy
HPSaucy's Avatar
Oddometer: 291
Not bad looking at all, but I still like my Remus system better visually.
macfly
MM # 99526
S # 70020
www.HP2.info
HPSaucy is offline   Reply With Quote
Old 07-29-2011, 09:25 AM   #1896
ladirt
Oddometer: 43
Stock Exhaust
Anyone have a stock pipe lying around that you would part with? I placed a ding in mine and am interested in staying with the stock setup if anyone wants to part with one. Thanks
ladirt is offline   Reply With Quote
Old 08-01-2011, 07:44 PM   #1897
bikecat
bikecat's Avatar
Oddometer: 1,122
Hiya,
Is the blue on the rims powdercoated or painted?
Cheers
bikecat is offline   Reply With Quote
Old 08-02-2011, 03:04 PM   #1898
fastbruce
Oddometer: 14
wtb wtt megamoto
I have a one owner, like new 2006 k1200 gt for sale or trade for mega moto. looking for mega moto
fastbruce is offline   Reply With Quote
Old 08-02-2011, 07:05 PM   #1899
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,303
How big is the ding? You'd be amazed at what a paintless dent removal place can do to tortured metal.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 08-25-2011, 12:06 AM   #1900
RoteEddie
Oddometer: 531
Megamoto doing what it does best!
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is offline   Reply With Quote
Old 08-25-2011, 07:12 AM   #1901
HPSaucy
HPSaucy's Avatar
Oddometer: 291
Lovely ride and lovely land, thanks for sharing!
macfly
MM # 99526
S # 70020
www.HP2.info
Old 08-28-2011, 05:19 AM   #1902
hawideri
hawideri's Avatar
Oddometer: 48
how to: drill the tank
Just have finished this job myself, thought I might share it with those considering to do it themself.
Pro's: I refuell 13 liter now instead of 11 something, rang increases by 30-40 km .
Con's: Remeber: after a complete refuell do not get lazy and stop for a drink: refuell and leave your MM standing in the sun is not longer a smart option. Fuell may expand. No problems after refuell and ride along even in 30+ degrees celsius .
step by step:
remove sheet
remove site pannels left and right,
remove middle pannel
remove tank cover
remove carbon tank pannel
place tank "nek" on the tank.
cover the tank opening to prevent dirt/metal going into the fuel
drill the hole's
(tip start with a small drill, 5 mm below the nek rim, then increase it size just a little bit).
hawideri is offline   Reply With Quote
Old 08-31-2011, 08:56 AM   #1903
bikecat
bikecat's Avatar
Oddometer: 1,122
Has anyone tried a different air height in the forks other than the stock 80mm?
I am thinking of starting at 120mm and then topping off the fluid incrementally until I am happy.
Cheers
Old 09-01-2011, 10:13 AM   #1904
Bruno Brasletti
Bruno Brasletti's Avatar
Oddometer: 56
Cry It's gone....
With much regret, I must report that my beloved MM is now gone....
It's now time to move on and the best way is by starting cleaning up the garage.... Here's a few things I was left with that may come handy to someone:
- Hand protections (Enduro version): in very good condition with just a very small scuff on the right hand side - 100€
http://i565.photobucket.com/albums/s...HP2/HP2006.jpg
http://i565.photobucket.com/albums/s...HP2/HP2007.jpg
- Engine protections: again the right hand side shows some markings but it's still usable (good for a track day?!...) - 50€
http://i565.photobucket.com/albums/s...HP2/HP2008.jpg
http://i565.photobucket.com/albums/s...HP2/HP2009.jpg
- Shaft bobbin: light marks - 15€
http://i565.photobucket.com/albums/s...HP2/HP2018.jpg
- Pillion foot rests: very good condition - 170€
http://i565.photobucket.com/albums/s...HP2/HP2014.jpg
- Tank bag: excellent condition - 150€
http://i565.photobucket.com/albums/s...HP2/HP2001.jpg
- Big soft bag: used two times - 150€
http://i565.photobucket.com/albums/s...HP2/HP2002.jpg
- Wunderlicht levers (black/chrome): like new - 180€
http://i565.photobucket.com/albums/s...HP2/HP2011.jpg
- F800 mirrors: excellent condition - 90€
http://i565.photobucket.com/albums/s...HP2/HP2013.jpg
- front mud guard: small dent on the right side but not very noticeable (ideal for a track day) - 200€
http://i565.photobucket.com/albums/s...HP2/HP2004.jpg
- HP2 Sport dash: like new with all accessories for installation - 1.100€
http://i565.photobucket.com/albums/s...HP2/HP2017.jpg
All prices plus P&P.
All the best!
Bruno Brasletti screwed with this post 09-01-2011 at 03:12 PM Reason: Posting pictures
Bruno Brasletti is offline   Reply With Quote
Old 09-01-2011, 05:38 PM   #1905
bikecat
bikecat's Avatar
Oddometer: 1,122
PMed on engine guards and bobbin.
Cheers
Times are GMT -7.   It's 08:58 AM.
