01-02-2012, 05:53 AM
#2011 |
Oddometer: 716
Interesting. It looks lie the bike Pepot owned or still owns. He did post on this forum a while back.
Ducati Multi1200 ![]() "you're never too old to learn something stupid" -- unknown. |
01-02-2012, 06:00 AM
#2012 |
Oddometer: 722
yes, here is the subject in italian
He puts a HP2S engine but kept some MM parts too http://www.quellidellelica.com/vbfor...=342744&page=6
GSMarc from BELGIUM 2008 HP2/MM ABS 2008 HP2/MM 2005 HP2E 2000 R1150GS (sold) |
01-02-2012, 07:33 AM
#2013 |
Oddometer: 1
Another Australian MM
A belated thanks to all the owners for the info and comments contained in this thread. Its a great archive for any one interested in this bike.
I bought mine new (non ABS) in December 09 in Melbourne and have just done a 1300 km ride this last week on a lap of Tasmania. Despite all the options discussed here in thread, I haven't changed anything except baffle removal and am evolving it to soft rubber on both ends. Suspension is dialed to "hard". Its all good. I have other riding choices as many here do, so it doesn't always get the consistent use that it deserves. At the moment I am fresh off it and it is again my favored bike. Except for the little engine rest area between 5.5k and 6, it is easy, fast enough and fun in tight corners and short straights. For the record and maybe of interest to the other Australian owners In 2 years I have only seen 3 other MMs about in Victoria, I am sure that they were all different bikes, one was parked and had been recently dropped (Looked like a dirt accident) which impressed me at the time. The other was in traffic but the opposite direction. The other was a shop front trade in for a Victory (took a while to sell). I'm going back to pages 50 to 100 for a bit of MM nostalgia. Cheers |
01-07-2012, 06:38 PM
#2014 |
Oddometer: 10
Test Run
Well, thanks to Ron50 and Co Ive been lucky enough to put another 800 km in a day on some of the best Megamoto twisty roads in SE Victoria. Im getting the measure of the bike and all I can say is Im totally hooked. I love the power and torque but will be going through the tread to work on the suspension settings, as Im finding the front end gets a little vague at speed in the rough.
Glenn
2011 XT660Z Tenere |
01-07-2012, 09:54 PM
#2015 | |
Oddometer: 722
I could stabilize the front by setting the rear spring softer (preload).
01-08-2012, 12:53 PM
#2016 | |
Oddometer: 10
Glenn
01-08-2012, 01:20 PM
#2017 |
Tarmac Terrorist
Oddometer: 43
Ti & Carbon Megamoto (Now with added CF and Billet)
Infrequent Updates seem to be a recurring theme of this Thread . Anyhow, fresh from another Blingfest, Whaddyareckon ? Offside; ![]() Nearside; ![]() BST Carbon Fibre Rear Wheel and Braking Disc; ![]() HP2 Parts Billet Rear Brake Pedal; ![]() HP2 Parts Billet Front Brake Lever,hiding inside Carbon Fibre Handguard; ![]() BST Carbon Fibre Front Wheel with Braking Disc; ![]() Front Wheel with Braking Disc; ![]() HP2 Parts Billet Clutch Lever,hiding inside Carbon Fibre Handguard; ![]() HP2 Parts Billet Gear Lever; ![]() Rear Wheel; ![]() Absolutely NO reflection on the Dealership,but the Bike had spent quite a while at Pidcocks,i'd ordered a pair of Renthal Bars which arrived but the Bar end-weights were on Back Order,i'd ordered Titanium Disc Bolts which were sent,but did not fit. The Renthal Bars got fitted but the Handguards were not compatable with the End-weights. Various options were explored but to no avail so the Std Bars went back on.I'd asked about some Bespoke Handguard Mounts but the Parts Department managed to source a set of BMW Items, which i was pleased about. The New Battery that got fitted under Warranty died,so a replacement was fitted. The Job was finally Finished and i have to Thank Keith and the Pidcocks Service Department for their Efforts (And Patience). I Took the Bike out and was Blown Away by the Difference. I'm no John McGuiness but i was stunned at the transformation. Left-Right-Left Combinations were much sharper,the Bike Turns-in much easier and more accurately to the extent that ,to start with,i was turning in as previously but the Bike went in quicker,leading me to have to pick-up and drop-in again. Once i had got to grips with things,i had a Blast ![]() .
TOO SOFT TO CAMP,TOO POOR TO TOUR. |
01-08-2012, 04:32 PM
#2018 | |
Grumpy Old Goat
Oddometer: 4,360
I don't think so. Look CLOSELY. That's a camhead engine.
I found Jesus. He was behind the sofa the whole time. 1996 M900, "Patience" 2012 GS "Sonar" 2008 Megamoto "Big Blue" 2008 S2R "WTF" |
01-08-2012, 09:43 PM
#2019 |
Oddometer: 722
Pepot :
http://www.quellidellelica.com/index...-by-pepot.html but it's for sure that you must start from a MM in order to put a HP2S engine. Could have been the one of Pepot even if in this case, it think it is not
01-08-2012, 10:04 PM
#2020 |
Aerial Gunner
Oddometer: 348
DeeTee,
Your MM looks great! Any idea how much weight your bike shed from the build?
08 MegaMoto #99529 |
01-22-2012, 01:28 AM
#2021 |
Oddometer: 10
Love the MM
Well I've put nearly 3000km on my MM in the last 3 weeks, on some of the best twisty roads in SE Australia and I have to say I'm enjoying it more than the S1000RR. The RR has been stting the garage gathering dust over this time. Note to self I must take it out for a run tommorrrow, if the showers stay away.
The MM suspensions just about dialed in, thanks to the posts in this thread and it's now sitting on the the lowest hieght settings so I'm not on tippy toes anymore. The front end is still a little light for me and I guess some revaluing may be in the mix down the line. Drilled out the filler neck and fixed an annoying leak in the tank and can now manage around 270- 290km per tank. Well it's back to planning more rides Cheers Glenn
01-24-2012, 01:06 AM
#2022 |
Oddometer: 10
The Bike
At Tathra Wharf NSW
01-24-2012, 01:08 AM
#2023 |
Oddometer: 10
Another Shot
Maffra NSW
01-24-2012, 06:50 PM
#2024 |
Oddometer: 10
And Another
02-12-2012, 09:11 AM
#2025 |
Oddometer: 291
I need just a replacement screen, can you sell those?
