Old 04-07-2012, 03:10 AM   #2116
Macroenie
Macroenie's Avatar
Oddometer: 206
Finally it arrived from M-Tec. Way better looking than the original sucker and a bit larger too
Macroenie is offline   Reply With Quote
Old 04-07-2012, 06:01 AM   #2117
schlim66
Loner
schlim66's Avatar
Oddometer: 693
We need more pics!
Schlim66
'15 R1200GSA
'14 S1000R
'09 HP2 MegaMoto
schlim66 is offline   Reply With Quote
Old 04-07-2012, 06:02 AM   #2118
GSMarc
GSMarc's Avatar
Oddometer: 1,120
Megamoto 2007 : ZFE replacement
I had a ZFE broken and I found another one, almost same Ref numbers.
I replaced it but the front light doesn't ligth up when the engine is running for example.
Does the ZFE must be reset by a BMW dealer ?
Thank you,
Original :
ZFE Basic Low
106 818 10 001 07 38
HW: C7
SW: 2.0.0
BMW : 6135 770 96 85
Other one :
ZFE Basic Low
106 818 10 001 08 03
HW : C7
SW : 2.0.0
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 04-07-2012, 04:08 PM   #2119
Macroenie
Macroenie's Avatar
Oddometer: 206
Originally Posted by schlim66 View Post
We need more pics!
Schlim66
This is the only other one I have at this moment.
Old 04-07-2012, 05:14 PM   #2120
hankgs
Oddometer: 1,913
Looks like the ZFE controls the light sensor, if it's not reading, it may be faulty
hankgs is offline   Reply With Quote
Old 04-07-2012, 11:50 PM   #2121
GSMarc
GSMarc's Avatar
Oddometer: 1,120
I installed the ZFE of my other MM (working fine).
At the moment of contact, you must have the rear red light on and the small position light front on too.
I got the headlight on and no rear red light...
I'm sure now that the ZFE must be reset by a BMW Dealer (if it's possible).
Some Dude, have you experienced that ?
Thank you
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 04-08-2012, 01:24 AM   #2122
hawideri
hawideri's Avatar
Oddometer: 48
Wow that m tec sucker looks great, was it easy to install?
hawideri is offline   Reply With Quote
Old 04-08-2012, 03:22 AM   #2123
Macroenie
Macroenie's Avatar
Oddometer: 206
Yes, it is very easy. Take of the panel, remove two clips holding the tube to the airbox with a screwdriver.
Then take away the tube which is then still hold in place by a small plastic pin in a rubber ring so pull it through the resistance of the ring...sounds weird doesn't it
Install in reverse order.
Old 04-08-2012, 05:54 AM   #2124
GSMarc
GSMarc's Avatar
Oddometer: 1,120
I have bought 2 Air intake (as on left) from Wunderlich and they have been installed with K&N air filters.
I have pushed the 2 clips only a half way, was becomming too hard (also with Teflon spray). I'm sure the air intake is fixed but it seems a little bit too thick for the clips.
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 04-08-2012, 09:13 AM   #2125
Macroenie
Macroenie's Avatar
Oddometer: 206
True, it's seems a bit tighter than stock but I can get the clips in completely.
I just checked mine and it does not have such a notable line running at the underside of the tube. Maybe they are not completely the same?
Old 04-09-2012, 09:00 AM   #2126
bikecat
bikecat's Avatar
Oddometer: 1,122
Thank you
GSMarc, I had an investigation into this when my MM's ZFE failed. The answer is yes, the dealer needs to run a new blank ZFE on a MM then dial in to Germany to get data into it. You will need also the VIN number etc.
Interestingly, the same ZFE is used for the new R, K, F series. The process will sense all of the gadgets on your bike and then update the ZFE accordingly. There is no rear light because the rear light goes through the ZFE, as the ZFE also controls the ABS, speedo etc. If you installed the ZFE from the ABS-MM to the non-ABS MM, ride the bike now and I think you will not have speedo too, even if the RPM works.
Cheers
bikecat is offline   Reply With Quote
Old 04-09-2012, 10:00 PM   #2127
GSMarc
GSMarc's Avatar
Oddometer: 1,120
Thank you Bikecat.
I have found a used ZFE from another crashed MM.
I was just wandering if I had to buy a new virgin ZFE or if a dealer could update the used one.
You gave me the answer, yes I can have it re-programmed
I couldn't have a ride with the MM2 because...
http://www.youtube.com/watch?v=sXe_6...layer_embedded
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 04-10-2012, 05:29 PM   #2128
bikecat
bikecat's Avatar
Oddometer: 1,122
You are welcomed, GSMarc.
Nice collection you have there. How many HP2E/MM are in your country?
What is the red one at the back?
Old 04-10-2012, 09:22 PM   #2129
GSMarc
GSMarc's Avatar
Oddometer: 1,120
well, how many MM or Hp2E, I don't know, only a few as everywhere
The red one is a Triumph Daytona 675 and the black one is a Aprilia 125cc 2 strokes
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 04-12-2012, 10:18 AM   #2130
ViperJustin
Retired HH60G Gunner
ViperJustin's Avatar
Oddometer: 676
I took a small 480 mile trip up to Zion NP, Cedar City, and the surrounding southern Utah areas. Elevations went from 1800' to 9700', where we ran into a road block. It was snow. I didnt take a camera, so no pics.
Conclusions: Take a camera. Head winds SUCK on the hiway (200+ miles of the trip). I still wish I had a bigger tank. The ride was awesome
Edit: These are the kind of trips where I wish I had a GSA. And once again, (sigh...), I'm pondering on trading in for one.
ViperJustin is offline   Reply With Quote
Times are GMT -7.   It's 11:25 PM.
