Old 05-06-2012, 12:42 PM   #2191
hawideri
hawideri's Avatar
Oddometer: 47
Hey Tony, (almost) welcome to the club
I only did drilled the tank "nek" and had my mirrors done (page 127 and 131 of this thread, i believe).
I like the "hard" suspension as it is, but many are tweeking it. But, this is not a mod, since the suspension can be adjusted.
Have fun with your bike!
hawideri is offline   Reply With Quote
Old 05-06-2012, 10:57 PM   #2192
GSMarc
GSMarc's Avatar
Oddometer: 1,053
I drilled the nek too and decided to control the autonomy.
I drove until my bike stopped (I have the underseat-tank of Markus).
Here is the result : 247 km = 153.48 miles
I had the chance to be stopped (by case) near a fuel station :-)
I re-filled the tank with the bike on side stand until full-full :
14,21 litres = 3.23 gal
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 05-06-2012, 11:11 PM   #2193
Macroenie
Macroenie's Avatar
Oddometer: 205
Yes, that is US $ 8.18 per gallon. In the Netherlands we even get ripped off more than that
Macroenie is offline   Reply With Quote
Old 05-07-2012, 02:18 AM   #2194
bikecat
bikecat's Avatar
Oddometer: 1,115
GS Marc,
Your 17.30 km/l is based on what sort of riding? I cannot imagine going slower than 90 km/h on this bike :)
Any comments about the Markus tank? Is there a big weight difference with that? Can the underseat tools still fit?
Cheers
bikecat is offline   Reply With Quote
Old 05-07-2012, 02:36 AM   #2195
GSMarc
GSMarc's Avatar
Oddometer: 1,053
@bikecat,
I was riding like a MM must be, not like a R1200GS...
When the counter reached zero, I decided to run in an 'economical way', without pushing the rev higher than 4.000 rpm.
My MM is cat free with a complete REMUS line, K&N filter, Wunderlich air intake and RapidBike EVO.
Markus underseat-tank is fine, the weight is nothing compared with the service it gives. Our body is often the first place where to save weight
Yes, you can keep the tools set under you seat
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 05-07-2012, 07:25 PM   #2196
szazbo
Oddometer: 205
Fuel Range
How many more miles did you get after the countdown mileage read "0" before you ran out of gas?
szazbo is offline   Reply With Quote
Old 05-07-2012, 10:41 PM   #2197
GSMarc
GSMarc's Avatar
Oddometer: 1,053
160 km (99.4 miles) I got the yellow triangle with
083 Km (51.5 miles) remaining range ==> theorical 243 km (150.99 m)
I got the zero display after 72 km (44.7 m) so at 160+72 = 232 km (144.15m)
I continued until 247 km (153.47m) so I could do 15 km (9.3m) after zero was displayed.
all here :
http://jemelapetenflat.xooit.be/t3692-Autonomie.htm
I will do the same experiment with the HP2E too
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 05-08-2012, 01:30 PM   #2198
hawideri
hawideri's Avatar
Oddometer: 47
My results: economy range is ~22km after the zero is displayed by the tankindicator.
I pre-tested with a jerrycan as back-up. But am trusting it fully by now and often push it to the 20km on spare. Although, last ride to Belgium my palms did get sweaty: I was driving on the highway when the bike hitted "zero" and was about to pass a 25km fuel sign to the next station...(I made it.).
I am convinced that the indicator "predicts" the fuelconsumption on your current driving style. Changing to "economy-mode" can change things drastic. Came to think of it, is 90km/6 gear the most efficient for the MM? Anybody knows this or have data on? You micht save my day one time!
Old 05-08-2012, 11:59 PM   #2199
GSMarc
GSMarc's Avatar
Oddometer: 1,053
Well, it's clear that the MM isn't forseen to be ridden like a R1200GS
Economy mode is only when the 'zero' appears, to be able to reach a next gas station.
I solved this with the underseat tank of Markus as an emergency feature
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 05-09-2012, 03:31 AM   #2200
bikecat
bikecat's Avatar
Oddometer: 1,115
GS Marc, ... how heavy is the Markus tank? I reckon not more than 5 kg without fuel? I now have tools under the seat (screwdriver + small pouch of wrenches etc). I am worried that with the Markus tank cannot out tools any longer. How much space of tools do you have under the seat?
Cheers
Old 05-09-2012, 04:23 AM   #2201
GSMarc
GSMarc's Avatar
Oddometer: 1,053
I cannot dismount my tank to weight it, I don't know.
I was speaking about the tools which are with the bike, pratically nothing in fact.
You should contact Markus to the answers to your questions.
http://www.gs-equipment.de/
When installed :
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 05-09-2012, 07:04 AM   #2202
air-cooled
air-cooled's Avatar
Oddometer: 229
fuel
for all you "empty your tank complete before fuelling", i was riding close to Paris (France) on one of the main roads, complying with the speed limit, sort of, when i was passing a fuel station with still 40 km to go. No problem, next one will be the next stop to fuel. so i thought. with still 8km in the tank the next fuel station came up, state of the art and completely new, really France. But i didn't work. next station in the village was out of service. some kind person brought us back to a working station, but this was still the state of the art first station and that one didn't work the second time either, not only for me but also for the locals as well. On the nav the next place was 6km and there was a gasstation, up we go. 2km to go and up a steep hill to the gasstation, it would be too easy if that one did work or was open, neither offcourse. computer now said 0km. this was my first time with zero and i did not know how far it would take me before shutting down, so engine off and rolling down the hill going to a station which i had seen on the way to this place. so with -5km and further no problems at all i could refill and continue, but lesson learned; even in a crowded and busy environment it's possible to have some misfortune with fuel stations.
air-cooled is offline   Reply With Quote
Old 05-09-2012, 01:51 PM   #2203
hawideri
hawideri's Avatar
Oddometer: 47
Originally Posted by air-cooled View Post
for all you ..... this was my first time with zero and i did not know how far it would take me before shutting down, so engine off and rolling down the hill going to a station which i had seen on the way to this place. so with -5km and further no problems at all i could refill and continue, but lesson learned; even in a crowded and busy environment it's possible to have some misfortune with fuel stations.
:) oke, I admit it. Had a similair experience before I did my pre-test
Old 05-10-2012, 08:17 AM   #2204
GSMarc
GSMarc's Avatar
Oddometer: 1,053
Does the ASC can be added on a MM with ABS ?
Thank you
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 05-12-2012, 07:21 AM   #2205
bikecat
bikecat's Avatar
Oddometer: 1,115
GSMarc, I think you have to make sure that the ZFE can handle that too.
Cheers
Times are GMT -7.   It's 06:13 PM.
