Old 05-21-2012, 05:08 PM   #2236
bikecat
bikecat's Avatar
Oddometer: 999
I'll send the pics to a friend of mine in the IT industry and see if he has any leads. Frankly I am not optimistic because the original lead is only 8-pin and the GS's is 30-pin, I can't see how the conversion can be done.
Will reply ya by PM, likely take up to a week or so.
Cheers
bikecat is offline   Reply With Quote
Old 05-21-2012, 05:37 PM   #2237
ludger
Oddometer: 16
akro pipes
Originally Posted by Megaman View Post
Here are some picks of the bike with HPN tank and Akrapovic system.
http://www.hpn.de/bilder/high_resolu..._megamoto1.jpg
obivously y.ou haven't ridden it yet.no colour on the pipes
ludger is offline   Reply With Quote
Old 05-21-2012, 10:04 PM   #2238
GSMarc
GSMarc's Avatar
Oddometer: 722
Originally Posted by bikecat View Post
Will reply ya by PM, likely take up to a week or so. Cheers
Thank you in advance,
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
GSMarc is offline   Reply With Quote
Old 05-24-2012, 04:08 PM   #2239
johnny moped
learner
johnny moped's Avatar
Oddometer: 142
selling my hp2
http://advrider.com/forums/showthrea...&highlight=hp2
johnny moped is offline   Reply With Quote
Old 05-27-2012, 05:00 PM   #2240
bikecat
bikecat's Avatar
Oddometer: 999
GS Marc,
As I suspected, the connectors are different and it is hard to replace with a adaptor because the number of pins are different. It looks like the LCD screen was changed by BMW for GS/MM or for different production years.
Sorry that I can't help ya. Looks like an actual MM cluster is your only option.
Cheers
Old 05-27-2012, 09:43 PM   #2241
GSMarc
GSMarc's Avatar
Oddometer: 722
Thank you Bikecat
The HP2E cluster and R1200GS have the same 30 pins connectors.
The MM has only a 8 pins
I'm still searching a LCD but it's quite difficult to find...
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
Old 05-29-2012, 11:12 PM   #2242
diranne
Oddometer: 28
Carbon Belt Cover
Just installed a carbon belt cover - these used to be a nigh on A$1200 option at new in Australia and for some reason they are now down to $400 - and thats from the local BMW dealer!
Australia - BMW HP2 Megamoto
diranne is offline   Reply With Quote
Old 05-30-2012, 01:24 AM   #2243
bikecat
bikecat's Avatar
Oddometer: 999
My experience with CF being in that area is that it is prone to pitting and damage.
Cheers
Old 05-30-2012, 12:56 PM   #2244
hawideri
hawideri's Avatar
Oddometer: 47
b[/IMG]
Some serious eyecandy
I hope they will throw that in the discount corner here in the EU as well.
Regards, hawideri
hawideri screwed with this post 05-30-2012 at 01:08 PM
hawideri is offline   Reply With Quote
Old 06-04-2012, 04:33 AM   #2245
GSMarc
GSMarc's Avatar
Oddometer: 722
Originally Posted by GSMarc View Post
2007 MM speedo LCD
I'm searching a new LCD for my speedo.
Does anybody know where I can find it before buying a new tachy ?
LCD connector is under the green light.
I have opened another MM tachy to see the LCD.
Written on the LCD upper left side : 07 12 25 MA
only 8 connectors
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
Old 06-04-2012, 08:29 AM   #2246
bikecat
bikecat's Avatar
Oddometer: 999
Anyone used or using a BoosterPlug or Wunderlich controller?
I am curious ... very curious .... I know the BMWs run lean, and want to improve on that.
Cheers
Old 06-04-2012, 11:20 AM   #2247
GSMarc
GSMarc's Avatar
Oddometer: 722
Hi Bikecat,
I went with RapidBike EVO 019L and K&N filter and Full Remus exhaust.
I'm VERY satisfied
http://jemelapetenflat.xooit.be/t322....htm?q=dyno%2A
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
Old 06-04-2012, 06:37 PM   #2248
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 4,359
Cheers
+1, especially in the blast radius of that front wheel. Lay on some 3M stone chip film, you'd protect it as well as be able to enjoy the carbony look.
I found Jesus. He was behind the sofa the whole time.
1996 M900, "Patience" 2012 GS "Sonar" 2008 Megamoto "Big Blue" 2008 S2R "WTF"
hillbillypolack is offline   Reply With Quote
Old 06-04-2012, 09:24 PM   #2249
Ron50
Oddometer: 78
Cheers
I'm very happy with the results from the Accelerator, especially at the price. Check out my post from 6 September last year. No noticeable increase in fuel consumption either.
Ron50 is offline   Reply With Quote
Old 06-05-2012, 06:48 AM   #2250
Macroenie
Oddometer: 158
Cheers
See my post here
The wunderlich controller gives you more options over the rev-range. The other one just fools the injection by use of a temperature related resistance, making it think it is about 10 degrees celsius colder en thus it will richen the mixture.
If you take away the cat. or put a 'sport' exhaust on the MM you will have to take measures for it not running to lean.
Macroenie is offline   Reply With Quote
Times are GMT -7.   It's 07:11 PM.
