Old 06-11-2012, 11:17 AM   #2266
GSMarc
GSMarc's Avatar
Oddometer: 1,006
I have fixed it like that, with zip ties :
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 06-18-2012, 08:45 AM   #2267
bikecat
bikecat's Avatar
Oddometer: 1,115
Hiya, just want to share a recent mod.
I bought a Woody's SS sidestand plate and fitted it. Be warned, the stand was too wide and I had grind down the holder of the stand somewhat, but that is another story ....
So after fitting the sidestand plate I found that the old plate was really bent, which brings a new problem .. the bike is now too upright at rest. The solution was to shorten the sidestand which will require cutting the sidestand down. Woody offers a good solution and since I am too far from Woody's, imitation is the best form of flattery, I got a welder to make my sidestand adjustable.
The next project was a footplate for the tiny stock sidestand base. 2 pieces of aluminium, many hours of elbow grease with grinder, blade, measuring tools and template, and with the sidestand adjustable, I now have the advantage of simply making a small hole to thread my sidestand through and fit the plates together. An elegant solution.
bikecat screwed with this post 06-18-2012 at 09:32 AM
bikecat is offline   Reply With Quote
Old 06-21-2012, 04:02 AM   #2268
hawideri
hawideri's Avatar
Oddometer: 47
Originally Posted by Macroenie View Post
back in one piece from the promised land...
Will report, of course, as time and kms progress. Like with a new bike I was told to have some patience before optimum performance has been achieved.
Cheers!
Great story Macroenie, very interested in the follow up!
hawideri is offline   Reply With Quote
Old 06-26-2012, 10:20 AM   #2269
Macroenie
Macroenie's Avatar
Oddometer: 205
fancy...
as a first step to rebuild the MM to this
Macroenie is offline   Reply With Quote
Old 06-26-2012, 10:44 AM   #2270
ViperJustin
Back in school...
ViperJustin's Avatar
Oddometer: 662
Damn! It looks like one of the machines from Terminator 4.
08 MegaMoto #99529 For sale. PM for details.
ViperJustin is offline   Reply With Quote
Old 06-26-2012, 10:59 AM   #2271
Macroenie
Macroenie's Avatar
Oddometer: 205
on second thought, it does not look very comfy or suiting my preferred riding position like the MM gives me now
more of these kind of bikes at http://www.seservice.se/mainpage_en.htm
Old 07-08-2012, 09:40 PM   #2272
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,102
Mega does not start
I've nit been able to ride the Mega recently so it had been sittin a bit. Long story, as well as crazy high temps.
Went out for a ride (battery on Tender, gas had a bit of Stabil), and it cranked well, dud not catch. Last year did this, and it was the fuel pump controller. I checked that item by swapping one from the GS (the Meganoto FPC worked in the GS), so it was not the FPS.
Without a GS-911 I'm unsure what to (try) diagnose next. I'm guessing fuel pump or ring antenna.
Anyone else have input? Thanks in advance.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 07-08-2012, 11:04 PM   #2273
hankgs
Oddometer: 1,838
deduct the ring antenna
If it's the ring antenna, it wouldn't even crank and would send a code on the speedo (at least my GS did).
hankgs is offline   Reply With Quote
Old 07-10-2012, 07:47 PM   #2274
bikecat
bikecat's Avatar
Oddometer: 1,115
I have a few questions on the MM, appreciate some feedback.
Question 1:
The tank range countdown; how accurate is it or should i ignore that? Today I got the countdown started at 78km to go. I then measured the distance on my odo (3 km) but when I checked the countdown again it was 72 km i.e. 6 km travelled. So it looks like the countdown is based on the fuel sensor strip and not actual distance travelled?
Also when I filled up, I had travelled 153km total and I pumped 8.7 litres of fuel i.e. I have a consumption of about 17.5 km/l. Based on a 13 litre tank (with fuel neck drill hole mod) I should have at least 4.3 litres or 75 km left. It seems that it is better to use the odometer as a more accurate fuel gauge?
Question 2:
How does the signal cancellation work? It works fine when I am changing lanes, but when I turn, sometimes it does not self-cancel?
Would like to know your experience?
Cheers
Old 07-11-2012, 06:45 AM   #2275
GSMarc
GSMarc's Avatar
Oddometer: 1,006
Originally Posted by bikecat View Post
Question 1:
http://jemelapetenflat.xooit.be/t3692-Autonomie.htm
GSMarc from BELGIUM
2008 HP2/MM ABS
2005 HP2E
Old 07-11-2012, 06:14 PM   #2276
bikecat
bikecat's Avatar
Oddometer: 1,115
GS Marc,
Thanks. So you managed 232 on 14.2 litres? That is about 16.3 km/l. I thought the bike's fuel capacity is only 13 litres. So the fuel tank neck modification get another 1 litre, huh?
Thanks.
Old 07-13-2012, 01:16 AM   #2277
GSMarc
GSMarc's Avatar
Oddometer: 1,006
GS Marc,
Thanks.
I did 247 km (153 miles) with 14,21 liters (3.75 gal), not 232 km.
Yes, the neck is with 2 little holes.
GSMarc from BELGIUM
2008 HP2/MM ABS
2005 HP2E
Old 07-21-2012, 11:26 PM   #2278
ktatlarge
Oddometer: 2
New to the HP2 MM
Hi guys I've had the privilege of picking up a used 08 MM, imported from Missouri, US with 1000miles on it.
Previous ride was a K12r. Loving every minute on it, only problem is not getting enough time to ride it.
This thread is a great resource, thanks for the valuable insights and discussions.
ktatlarge is offline   Reply With Quote
Old 07-22-2012, 04:05 AM   #2279
BashLash
BashLash's Avatar
Oddometer: 4
Ktat well does on the new wheels.
Can I ask how much you pay for a mm over there?
BashLash is offline   Reply With Quote
Old 07-22-2012, 01:12 PM   #2280
ViperJustin
Back in school...
Oddometer: 662
Are you from Las Vegas? I know of only one other MM here and it's the owner of the BMW dealer.
Times are GMT -7.   It's 10:05 PM.
