Old 12-22-2012, 02:14 AM   #2386
GSMarc
GSMarc's Avatar
Oddometer: 1,082
Just a question :
I've read that some BMW Dealers can do Remap of injection for better engine output (with adapted exhaust etc).
But the solution also exists with Power Commander, Rapid Bike etc
Can somebody tell me the + & - of each solution :
Remap vs external box ?
Thank you
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 12-24-2012, 07:05 AM   #2387
Macroenie
Macroenie's Avatar
Oddometer: 206
My guess would be adjustment via one of these or for you in french
Macroenie screwed with this post 12-24-2012 at 07:08 AM Reason: french
Macroenie is offline   Reply With Quote
Old 12-25-2012, 12:51 AM   #2388
GSMarc
GSMarc's Avatar
Oddometer: 1,082
Thank you
Does somebody has experience with that ?
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-26-2012, 11:55 PM   #2389
Macroenie
Macroenie's Avatar
Oddometer: 206
No personal experience just a general opinion from what I've read on some German boards while searching for the big-bore options.
There are a few BMW tuners that use the Rexxer for their projects and they seem to prefer this above external units because there will be no latency as it is programmed right into the ECU.
My fear is that when you would visit the BMW dealership for maintenance and they decide to update your ECU with new firmware the program will get overwritten and then you will need to revisit the tuner company unless you buy the Rexxer unit and manage to get the tuning map onto it. I'm not sure one of the default or pro maps would be sufficient for you, my guess is you want one custom made to your bike
So maybe your best bet would be to inform a tuner about this.
Good luck!
Old 12-27-2012, 02:51 AM   #2390
GSMarc
GSMarc's Avatar
Oddometer: 1,082
thank you for the reply
I had in mind just saving the weight of the RapidBike Evo installed
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-27-2012, 11:24 AM   #2391
Macroenie
Macroenie's Avatar
Oddometer: 206
no problem.
Saves a lot of extra wires too.
Let us know how it goes, always interested
Old 12-28-2012, 09:08 PM   #2392
ViperJustin
Retired HH60G Gunner
ViperJustin's Avatar
Oddometer: 686
Is there a tank bag out there that I DON'T have to take off during refueling? With the MegaMoto's short fuel range, it's an extra pain in the ass to take my current bag off every 100 miles. (Doing so, I lost a clip for the bag!)
ViperJustin is online now   Reply With Quote
Old 12-28-2012, 10:04 PM   #2393
hankgs
Oddometer: 1,891
Justin,
They way you long distance ride your MM, I would look into buying the HPN fuel tank...
hankgs is offline   Reply With Quote
Old 12-28-2012, 11:21 PM   #2394
GSMarc
GSMarc's Avatar
Oddometer: 1,082
I would prefer the underseat-tank of Markus.
Less weight on the front, doesn't break the line of the MM.
http://www.gs-equipment.de/page5.php
I did a test. Result : 365 km (227 miles) with the 2 tanks.
http://jemelapetenflat.xooit.be/t3692-Autonomie.htm
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
GSMarc screwed with this post 12-28-2012 at 11:28 PM
Old 12-30-2012, 11:37 AM   #2395
ViperJustin
Oddometer: 686
As of now, there's no plans for adding a second tank or the larger hpn tank. Besides, I don't have much going on this winter, so trip planning (mapping out gas stations) is about all I'll be doing the next couple months. The only areas that I'm concerned about is hiway 1 north of San Fransisco and south of Monterey.
Old 12-30-2012, 05:07 PM   #2396
hankgs
Oddometer: 1,891
I have made it from Cambria to Monterey no problem...! There is a gas station/bakery in Big Sur too...
As a matter of fact, I spent the night in Monterey and got up early to take HWY 1 South. Apparently, there had been a fatal accident the night before and CHP had closed the Southbound traffic, just north of Big Sur, for the accident investigtion.
Being that it was 7AM mid-week, there were about 20 cars waiting for the CHP to open the HWY. I "bridged" the lanes of parked cars to the front . The CHP said that I was about to have an epic ride down HWY 1 ! IT WAS!!! I blasted down with virtually NO traffic all the way to Cambria-Probably never have that opportunity again...
Old 12-30-2012, 06:19 PM   #2397
ViperJustin
Oddometer: 686
I'll be going South during Memorial Day weekend. It'll be crazy, but still an amazing ride. Thanks for the info.
Old 12-30-2012, 10:39 PM   #2398
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
So how far can a MM go on a stock tank?
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 12-31-2012, 12:38 AM   #2399
GSMarc
GSMarc's Avatar
Oddometer: 1,082
I did 247 km (153.5 miles) driving a little bit slowly when the counter indicated zero km remaining.
The MM was on side stand when filled to maximum.
The engine stopped, no more fuel.
I filled the tank with MM on side stand again.
14,21 liters = 3,75 Gal
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
GSMarc screwed with this post 12-31-2012 at 12:43 AM
Old 01-01-2013, 09:15 PM   #2400
szazbo
Oddometer: 202
Megamoto Tank and Tail Bag
I have used the SW Motech tank bags. I mounted the quick release tank ring to the little rear rack and usually use the tank bag as a tail bag. When taking a overnight trip on the MM I mount another tank ring on the tank and use 2 of their bags. A quick pull of the string and the bag is off. They won't let me post any photos yet so check out the link
http://www.hp2.info/phpBB3/viewtopic.php?f=7&t=104
szazbo is offline   Reply With Quote
Times are GMT -7.   It's 09:41 AM.
