Old 02-15-2013, 01:08 AM   #2476
Spacematic
Oddometer: 16
Originally Posted by GSMarc View Post
Another guy did it also in Portugal.
I think that dealers are now more aware of all the electronic settings than at the time when the HP2s were built.
http://www.advrider.com/forums/showp...postcount=1418
Thanks a lot my friend, in my opinion it looks great!
Spacematic is offline   Reply With Quote
Old 02-15-2013, 01:13 AM   #2477
Spacematic
Oddometer: 16
Originally Posted by Macroenie View Post
No problem, just trying to help.
If you are able to get hold of the cables (check link below) its just a matter of following the instructions on the cd that comes with it. Remove headlight fairing to gain access to the wiring/connectors, disconnect current connector from dash, remove dash, connect then new wiring and install dash and switch. Test if dash works. Reinstall headlight fairing. Go for a ride.
I searched and found this for you, below the diagram are the partnumbers, scroll all the way down as the switch is part 7 mentioned below the infra-red stuff (parts 5&6) which you probably don't need.
If you are going to install it, will you get a new unit? If new then you might need to go to BMW dealer to pair it to your bike so all the functions will work via the switch. If they (Italian BMW) cannot help you then just ride to Germany and get it done there
A ride to Germany could be an option, but not in this weather!
Anyway, thanks a lot for the informations!
I am trying to get a second hand unit, so probably I will not have the CD rom with it.
Just a last question, if you can hel: is that cable the link between the original MM wiring and the dash?
Old 02-15-2013, 01:30 AM   #2478
RichBMW
RichBMW's Avatar
Oddometer: 2,206
please do explain
To put a screen or hugger on, or change the clocks I can understand, as all these bits can be taken off and the bike put back to standard relatively easily. But I cannot understand why on earth someone would turn such a rare and exotic bike such as a MegaMoto into a rig. There are plenty of bikes out there far better suited to run a sidecar, such as a 12GS, but a MM. You'd have to be CRAZY to do that.
2016 BMW S1000XR Sport SE
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 02-15-2013, 01:59 AM   #2479
Macroenie
Macroenie's Avatar
Oddometer: 208
ah, yes, I see. Thanks for clarifying.
I agree, most of my mods can be removed which will leave you with a 'standard' 1250cc HP2.
I keep all the bits for when the day will come that I would consider selling it. Finding them again or having to buy them new can be quite a task.
A sidecar is a mod I will never consider, I'd rather buy a nice cage then.
Macroenie is offline   Reply With Quote
Old 02-15-2013, 10:15 AM   #2480
Spacematic
Oddometer: 16
Old 02-15-2013, 10:18 AM   #2481
Spacematic
Oddometer: 16
Old 02-15-2013, 10:23 AM   #2482
Spacematic
Oddometer: 16
Old 02-15-2013, 12:33 PM   #2483
GSMarc
GSMarc's Avatar
Oddometer: 1,132
fine bike Space
tell us more about exhaust and radial brakes
thank you
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 02-15-2013, 02:50 PM   #2484
lousot
lousot's Avatar
Oddometer: 466
a link for that exhaust would be nice look so sweet how about a sound clip also
If you dump it in front of me.I promise I wont run you over.dit: And remember, "You can't drink all day if you don't start in the morning".
lousot is offline   Reply With Quote
Old 02-15-2013, 09:31 PM   #2485
ViperJustin
Retired HH60G Gunner
ViperJustin's Avatar
Oddometer: 697
+1
It's amazing how clean the MegaMoto looks without the exhaust can.
ViperJustin is offline   Reply With Quote
Old 02-16-2013, 03:53 AM   #2486
Spacematic
Oddometer: 16
fine bike Space
thank you
Hello mate,
I bought the exahust off a guy here in Italy who himself bought it in Germany during a trip.
He was made by someone dealing with exahust, but honestly the seller did not remember the name.
As fro the brakes, I have replaced the bottom of the forks with a couple of elements cnc made by a company here in Italy.
If you like I can get some others made
Brembo's M4 108 mm complete the package!
Old 02-16-2013, 03:54 AM   #2487
Spacematic
Oddometer: 16
I am doing all the work during the winter, so still I have not ridden it! But I will get a sound clip for you guys!
Old 02-16-2013, 03:56 AM   #2488
Spacematic
Oddometer: 16
Originally Posted by BMWJustin View Post
+1
I completely agree with you, I like the look of that rear wheel!
By the way, I am painting it in white...it will be even more neat in my opinion
Old 02-16-2013, 05:55 AM   #2489
GSMarc
GSMarc's Avatar
Oddometer: 1,132
Do you think it will fit with ABS ??
Are you also on Quellidellelica ?
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 02-16-2013, 09:54 AM   #2490
Spacematic
Oddometer: 16
Hello mate, yes, I am on Quellidellelica!
I think there is no problem with ABS, but if you like I can do some reaserch...
Times are GMT -7.   It's 05:29 AM.
