Old 02-26-2013, 10:16 AM   #2506
RichBMW
RichBMW's Avatar
Oddometer: 496
Originally Posted by szazbo View Post
Got home last night and the nice guy in the big truck delivered my latest Megamoto upgrade.
That looks awesome
2013 BMW R1200GS LC TE
2010 BMW HP2 MEGAMOTO
RichBMW is offline   Reply With Quote
Old 02-26-2013, 10:57 AM   #2507
hankgs
Oddometer: 1,441
Nice Eric, It's even the right color blue!!!
hankgs is offline   Reply With Quote
Old 02-27-2013, 07:35 AM   #2508
RichBMW
RichBMW's Avatar
Oddometer: 496
I was in my garage this morning messing about, and kept looking at the MM. I really want to ride it NOW, but there's still too much salt on the roads here.
Old 03-03-2013, 01:24 PM   #2509
wcisse
wcisse's Avatar
Oddometer: 66
Carbon Cylinder head Covers
Hi Folks,
I'm looking for relatively cheap set on carbon cylinder head covers for my HP2 Enduro. The mounting points snapped off in a couple of places where a set of GSA aluminum covers were mounted. The carbon covers I've seen mount to the face of the head so I think they'll do the trick. Since this is an enduro, I'm good with a pair that are banged & scratched up. Anyone have a lead on a set?
Wayne
wcisse is offline   Reply With Quote
Old 03-03-2013, 10:44 PM   #2510
szazbo
Oddometer: 31
Stahlbus brake bleeders on the Megamoto
Not sure if anyone else has seen these or not, as Stahlbus is pretty new in the US. They have been in Europe for a while but until late last year did not have a US distributor. A fine German guy Thomas Modlmeier decided that he didn’t want to continue life as a Mercedes tech and was going to bring the Stahlbus products to the US market.
Basically they make 2 different products, a quick oil drain valve and brake bleeder valves. Applications to fit whatever your needs are, though their online catalog is in the process of being translated from German to English.
The Stahlbus drain valve is not ideal on a Megamoto as it would hang down beneath the engine in harms way, but works great on a HP2 Sport. No mess. I have installed this on my Tdi Jetta.
Their brake bleeder valves are great and easy to install. Essentially replaces the existing valve but is a little taller due to the design. There is a base that screws into the caliper and then the bleeder screw with check ball and o ring is installed into the base. So the way they work is as follows. Open the bleeder up 1 ˝ turns and you can use a vacuum pump to extract the old fluid in the usual way if you are changing the fluid. Open the valve ˝ turn and use the master cylinder to push the fluid out. The check ball closes and stops the air from coming in as does the o ring that seals the outside of the bleeder. Keeping an eye on the fluid level continue pumping until you are happy with the fluid coming out. There is a similar product on the market, a Speedbleeder but these do not have o ring seals and cannot be put into flush mode.
Maybe these are overkill, but brake fluid flushes are something that I tend to ignore as they can be messy and a pain. Brake fluid is easy to forget about as what happens if you don’t change it. Usually nothing unless you ride on the track and the fluid boils. If you havent changed your brake fluid yes, I can tell you that the fluid in the rear brake comes out BLACK! and I have changed it several times. Possilbly the rear brake hose is deteriorating.
They are available with different colored anodized caps and are simple to install. If anyone is interested in them I can get them for you at a discount or you can call Thomas and he will hook you up.
Here is the link to their website for all the info that you might want.
www.stahlbus-us.com
szazbo is offline   Reply With Quote
Old 03-04-2013, 10:16 AM   #2511
Macroenie
Oddometer: 158
HP2 Dash only, kind of cheap on ebay
Macroenie is offline   Reply With Quote
Old 03-06-2013, 08:46 AM   #2512
Macroenie
Oddometer: 158
1st ride of the year so spring is here, sort of
14 Degrees today but predication of sub zero temperatures later on this week
Old 03-06-2013, 05:22 PM   #2513
hankgs
Oddometer: 1,441
That is a "twisty" Dutch road right there
Old 03-06-2013, 10:31 PM   #2514
Macroenie
Oddometer: 158
It actualy is somewhat twisty as it follows the contour of the lake, but yeah no curve in this shot. Will try to make a small movie out the raw material I captured.
Old 03-06-2013, 10:56 PM   #2515
szazbo
Oddometer: 31
HP2 Dash
Hey Macroenie, did you ever get the odometer sorted out on the dash yet? I really want one but dont want to spend the $$ unless it is fully functional.
Old 03-07-2013, 04:13 AM   #2516
Macroenie
Oddometer: 158
Getting that done at next service interval so not yet
Old 03-08-2013, 12:41 AM   #2517
GSMarc
GSMarc's Avatar
Oddometer: 720
@Macroenie,
do you still have the original dash ?
I'm searching just a LCD display
Thank you,
GSMarc from BELGIUM
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2000 R1150GS (sold)
GSMarc is offline   Reply With Quote
Old 03-08-2013, 04:34 AM   #2518
Macroenie
Oddometer: 158
yes I have the original dash but I'm sorry to say that it is not for sale.
Old 03-12-2013, 07:11 PM   #2519
hankgs
Oddometer: 1,441
Spring has Sprung...
Old 03-14-2013, 07:27 PM   #2520
hankgs
Oddometer: 1,441
Carbonfiber Megamoto Farring FS on eBay de
http://www.ebay.de/itm/Carbonfrontma...item257ba0bcfa
Times are GMT -7.   It's 03:21 PM.
