Old 05-02-2013, 01:24 PM   #2566
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
speed wobble
Hi MM riders. I've got a problem with the front suspension. When I accellerate up to about 100 mph (only on German Autobahn of course ) the front starts to wobble. Sort of a headshake. Not violent and if I slow down it goes away, but still it's quite annoying.
That is with:
- front and rear highest setting
- oil 7.5W
- damping in and out oem settings front and rear
- tires Michelin Streetpilot 3, different pressures tested
Also tried:
- damping in and out GSMarc's settings front and rear
> no change
- damping in and out front on the toughest setting
> somewhat better but not ideal
- front height middle setting
Am I looking in the wrong place perhaps? Can it be caused by something differenent like wheel balance, wheel bearings, wind screen (Isotta fitted), global warming, bad karma, ...
On a steel horse I ride...
Accessories are at www.migsel.com
MiGSel is offline   Reply With Quote
Old 05-02-2013, 01:51 PM   #2567
hankgs
Oddometer: 1,843
Are you the original owner? Perhaps your MM was in an accident where the bike may have sustained minor front end damage(?)
I have the Isletta screen as well and have never experienced any instability, even over 100
hankgs is offline   Reply With Quote
Old 05-02-2013, 02:30 PM   #2568
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
No I bought it last year with about 20k on.
But there are no signs of frame damage or such.
Old 05-02-2013, 02:41 PM   #2569
air-cooled
air-cooled's Avatar
Oddometer: 229
Migsel, to rule out some possibilities, I guess that you don't ride with a loose jacket and keep your handle bars with a strong grip.:-)
May be it is possible to ride the bike of gsmarc and feel the differences and set your bike accordingly.
Are your tires okay and what pressure do you use?
I do regular speeds above 160kmh without a moving front, so it is possible off course. Mine findings are that lowering the front will make the bike generally more unstable at speed.
All though a lot of riders are complaining about the front suspension, setting it to standard setting should by it self not cause your complaints. So if the front fork is okay, that can be ruled out.
Remove your windshield and ride without.
I think that balancing your wheels if necessary, can be ruled out as cause of the problem, because I did ride with and with out balanced wheels without a problem.
Because you already did a lot and if the bike is in good condition, do things step by step, removing the wind shield and wear a leather jacket can be done at the same time :-) but regarding the changes to the suspension, one at a time and write things down and not more than two or three clicks a time.
Mine guess is that the pressure of the pr3 will make a lot of difference.
ps, I am just above Amsterdam, you can always drive by.
air-cooled is offline   Reply With Quote
Old 05-03-2013, 12:45 AM   #2570
schlim66
Loner
schlim66's Avatar
Oddometer: 683
That is with:
- oil 7.5W
Also tried:
> no change
I have the same thing happen at around 105mph, if I let off slightly it goes away. A few friends who have been behind me when it occurs, tell me they see my rear tire weaving side to side. I have had the suspension set by a professional suspension tuner and it handles fantastic up to that speed. I am 6'6" and I like the bike set up at it's max height, so I have the fork tubes dropped completely flush with the top triples. The effect of this adjustment should be to slow the steering down and make it more stable, but it doesn't help at that speed. I've become used to gripping with my knees more and relaxing my hold on the grips a bit when it happens, but I still cant get much faster than that without it becoming more pronounced. I'm religious about the condition of my tires and check the tire pressure before every ride. I run 32 F+R for aggressive riding and 32F and 36R for just cruising around. It does the same thing with either pressure setting. I have the Isotta screen as well as GS hand guards and I also have a Scotts steering damper mounted. Since there are only a few places where I ride at that speed and most of the time I ride a bit slower, I just deal with it by sprinting through the twistys and keeping ahead of my friends on their liter bikes. ;-)
Schlim66
'14 S1000R
'11 R1200GSA
'09 HP2 MegaMoto
schlim66 is offline   Reply With Quote
Old 05-03-2013, 01:34 AM   #2571
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
Hmm, interesting.
I am going to have a closer look at:
- tires: pressure and balance
- wheel bearings (could be a bit worn)
- head stock bearings (are almost new but may need adjusting)
Old 05-03-2013, 08:11 AM   #2572
GSMarc
GSMarc's Avatar
Oddometer: 1,007
"When I accellerate up to about 100 mph the front starts to wobble"
I bought my MM new and had the same effect. I wanted to sell it back immediately, was horrible.
I also bought a steering damper from Scoot, was a little better but...
Finally, I found the cause :
I decreased the preload of the rear yellow spring and the bike became very stable, no more wobble during acceleration
I unmounted the steering damper and put it on the HP2E
Even with the RapidBike setting wich gives far more accelerations, no more wobbles, a real pleasure
Hope this helps
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc screwed with this post 05-03-2013 at 08:34 AM
GSMarc is offline   Reply With Quote
Old 05-03-2013, 12:55 PM   #2573
air-cooled
air-cooled's Avatar
Oddometer: 229
I remember setting the rear spring with more pre load and having more or less the same effect, setting it back to standard static sag was the cure.
So I'm with Marc
Old 05-03-2013, 02:40 PM   #2574
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
Today I have removed the screen and the handguards and it was much better already.
I'll try the spring preload tip as well, to see what that does.
Old 05-04-2013, 12:07 PM   #2575
schlim66
Loner
schlim66's Avatar
Oddometer: 683
So I'm with Marc
I'll have to give that a try, thanks.
Schlim66
'14 S1000R
'11 R1200GSA
'09 HP2 MegaMoto
Old 05-04-2013, 11:16 PM   #2576
diranne
Oddometer: 32
Wobble
I fitted a Scotts damper some time ago and it seemed to help... might have to fiddle with the preload now!
Australia - BMW HP2 Megamoto
diranne is offline   Reply With Quote
Old 05-05-2013, 01:44 AM   #2577
RichBMW
RichBMW's Avatar
Oddometer: 1,993
Just had the annual service done yesterday at my local BMW dealer. It was good to be back out on it.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 05-05-2013, 09:02 AM   #2578
hankgs
Oddometer: 1,843
Dude, Mine has the screen and handguards - DON'T have a steering stabilizer (why?), and I have NEVER experienced ANY kind of wobble or high speed head shake - EVER.
You might want to get yor bike checked out by a professional, there is some shit wrong...just sayin'
Old 05-05-2013, 04:09 PM   #2579
ViperJustin
Back in school...
ViperJustin's Avatar
Oddometer: 667
Ditto!
On another note, I washed my bike today. Although I'm still two weeks out, I'm really excited for my trip.
Edit: Heres a couple pics from a "test" ride a couple weeks ago. I rode up to Mt Charleston, near Las Vegas. I rode up there because not only was I testing the way my bike would handle, but how well my Klim Latitude gear would work. Ive never ridden two up before, so the extra weight (about 40 lbs, total) made the bike feel a little interesting. The temps in the valley were about 90 and the temps up on Charley were around 50. Im VERY happy that I bought my Klim gear. Its very comfortable in both temps (with openings closed and open). Anyways, heres the goods!
Bike loaded up... I was bored and I was playing with the photo options...
The real pic...
One more...
[/URL]
08 MegaMoto #99529 For sale. PM for details.
ViperJustin screwed with this post 05-05-2013 at 06:36 PM
ViperJustin is offline   Reply With Quote
Old 05-06-2013, 06:35 AM   #2580
Ron50
Ron50's Avatar
Oddometer: 173
My bit for what it's worth: Had exactly the same problem from new with stock settings and lowest height -- no damper and no screen.
Just backing the damping off front and back 4 clicks improved the ride and got rid of the head shaking.
Ron50 is offline   Reply With Quote
Times are GMT -7.   It's 04:02 AM.
