Old 11-03-2009, 12:44 PM   #676
RoteEddie
Oddometer: 531
Originally Posted by funhouse
Don't, repeat, DON'T put an Exide in your HP2...even if it's free/warranty! They are all junk.....The BMW dealer in Eugene squared me away on this after going thru four Exide's in two years......They installed a Yuasa two months ago and I've had no issues since...Bruce
The original is an Exide. Exide makes a lot of very good batteries. The SLA12-12 belongs to the top range unlike the original.
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is online now   Reply With Quote
Old 11-04-2009, 09:38 PM   #677
HPSaucy
HPSaucy's Avatar
Oddometer: 291
Touratech tail tidy...
I bought one, and stuck it on the bike today. Pix over here.
macfly
MM # 99526
S # 70020
www.HP2.info
HPSaucy is offline   Reply With Quote
Old 11-05-2009, 09:15 AM   #678
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 832
Is there a provision for a plate light Sauce?
Steve
Maineroads is offline   Reply With Quote
Old 11-05-2009, 10:28 AM   #679
bingbong
bingbong's Avatar
Oddometer: 798
Thumb
Peronnaly, I think it loks allot better. Nice job.
R Nine T
"you're never too old to learn something stupid" -- unknown.
bingbong is offline   Reply With Quote
Old 11-05-2009, 10:30 AM   #680
bingbong
bingbong's Avatar
Oddometer: 798
nothing comes "in the box", an after market solution is needed. Which I still have to do with mine. But its not a legal requirement here so I have been a bit slow to sort it out on mine.
R Nine T
Old 11-06-2009, 03:23 AM   #681
Bruno Brasletti
Bruno Brasletti's Avatar
Oddometer: 56
Be radical: live on the "Legal Limbo"!!!!!....
... sometimes grey is good.
I suppose that over here, everything is quite grey when it comes to legal matters...
Bruno Brasletti is offline   Reply With Quote
Old 11-06-2009, 08:04 PM   #682
HPSaucy
HPSaucy's Avatar
Oddometer: 291
Anyone tried Wilburs front springs?
I ordered a set as they are pretty inexpensive, so I figured its worth giving them a try.
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-07-2009, 09:38 AM   #683
bingbong
bingbong's Avatar
Oddometer: 798
Thumb
looking forward to hearing the ups and downs of this mod
R Nine T
Old 11-10-2009, 10:49 PM   #684
sunandsand
Oddometer: 87
I remember seeing a magazine at a local Barnes and Noble store several months ago that had a comparison of the BMW MM vs Buell vs Ducati Hypermotard vs KTM superduke. I believe it was a British Mag but am not sure. I have searched the net and cannot find which magazine did that comparison. Someone here must remember which magazine that was!!!??
thanks
sunandsand is offline   Reply With Quote
Old 11-11-2009, 12:55 AM   #685
HPSaucy
HPSaucy's Avatar
Oddometer: 291
I think I read it too....
I'm pretty sure it was Bike, buy can't be 100%. They gave the KTM top nod, and the BMW came in close second, the Ducati was third because the throttle response was too on/off making it hard to ride smoothly, and the Buell was not in the same class if it was the same story.
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-11-2009, 02:23 PM   #686
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 832
SNS, I'll take the headers. Sent $$$. Thanks, Steve
Steve
Old 11-11-2009, 05:00 PM   #687
hankgs
Oddometer: 1,925
BMW MM vs Buell TT vs Duc HM vs KTM SM
Hey Sandandsea...
Motorcyclist Magazine June 2008 Issue
To order back issues; www.primediabackissues.com
$6.00 each plus $3.00 shipping and handling
hankgs is offline   Reply With Quote
Old 11-11-2009, 07:08 PM   #688
sunandsand
Oddometer: 87
I originally saw the paper issue at the news stand and for some reason, I thought it was in a euro mag. I've seen this online review already and just did not think that it was the same test as the paper issue I read, but now that you point it out, I believe that you are correct. I will go ahead and order the June 08 issue. Thanks very much.
Old 11-15-2009, 06:21 PM   #689
HPSaucy
HPSaucy's Avatar
Oddometer: 291
More pix up from today's ride over here.
Also anyone have the actual, final sag info for the MM, I'm going to send mine off to get the Wilburs front springs and the up-rated Olins rear spring put on this week, and want to make sure that the guys have the exact correct info.
macfly
MM # 99526
S # 70020
www.HP2.info
Old 11-15-2009, 10:46 PM   #690
sunandsand
Oddometer: 87
Are you taking the bike to get the work done or taking the parts off?
From what I understand about how you'd like the bike to ride from our conversations, I'd set the front around 40-45mm and the rear around 35mm. You might have an issue with sag numbers using a progressive front spring, if I'm correct in recalling that wilburs recommends/sells progressive fork springs. From what I've found out, the stock fork springs are stiff compared to the stock ohlins spring on the MM.
A setup with nothing else changed except going from straight rate to progressive rate springs will not result in the same suspension action using the same sag number. You might take that into consideration.
You should really notice a difference in the way the bike will feel with the proper spring for your weight though it will be more difficult to know which change did what for the handling changing both at once. Best of luck.
Let us know how it goes.
Times are GMT -7.   It's 05:22 AM.
