Old 12-21-2009, 04:10 PM   #826
NakedRider
NakedRider
NakedRider's Avatar
Oddometer: 664
Originally Posted by hankgs
Kind of an interesting video of an HP2 / Japanese style. The riding is pretty mild-mannered, but a nicely done video...
http://www.youtube.com/watch?v=CTmkd...esh+div-f-7-HM
You can tell it's faked. You can't get that far on one tank of gas.
I found it interesting in how he mounted the bike. Start the engine, kick up the stand, then hop on the bike. Might be vertically challenged (no offense to anyone) I just found it interesting.
'09 BMW R1200R
NakedRider is offline   Reply With Quote
Old 12-22-2009, 02:01 AM   #827
Audacious Nick
Forever indecisive
Audacious Nick's Avatar
Oddometer: 656
Originally Posted by Ron50
If it's the Bike report previously posted by Fixinbones we're talking about the outstanding aspect to me was the difference in real world, twist the wrist top gear acceleration -- about 20 seconds for the others and 15 for the MM:
RWHP
HM 79.8
MM 101.2
950SM 95.7
Torque
HM 66.6
MM 78.4
950SM 63.5
1/4mile
HM 12.11@114
MM 12.06@119.8
950SM 12.34@117.9
Top gear roll on 40-120mph
HM 19.52
MM 14.83
950SM 20.41
Fully fueled weight
HM 193.5kg
MM 198.2kg
950SM 205.6kg
Someone needs their dyno checked. All three make around 95hp.
Bikes:
2006 Husky SM610
2000 Honda Superhawk
Audacious Nick is offline   Reply With Quote
Old 12-22-2009, 08:12 AM   #828
sunandsand
Oddometer: 87
Around 95 hp +/- 16?
sunandsand is offline   Reply With Quote
Old 12-22-2009, 08:50 AM   #829
ViperJustin
Retired HH60G Gunner
ViperJustin's Avatar
Oddometer: 672
A good friend of mine has the HM S model with the full Termi exhaust. My bike still walks away from him with ease. My bike is completely stock. So yes, mine makes more than 95 hp because his HM was dynoed in at 90+ hp after all the mods. Oh, and I also weigh 40 pounds more than him...
ViperJustin is online now   Reply With Quote
Old 12-22-2009, 09:23 AM   #830
Audacious Nick
Forever indecisive
Oddometer: 656
I looked around and checked dyno charts, they all made around 95 HP with +/- 3hp variance between charts.
Bikes:
2006 Husky SM610
Old 12-22-2009, 11:14 AM   #831
Patrick HP2
Oddometer: 7
my MM with standard exhaust and Rapid Bike 3
108 rwhp
124 Nm
Patrick HP2 is offline   Reply With Quote
Old 12-22-2009, 02:53 PM   #832
sunandsand
Oddometer: 87
Final hp numbers vary between dynos of different brands and models. Correction factors used in arriving at the numbers also affect final numbers. What I thought you meant originally was that they all make around 95 hp. "Around" to me is +/- 3 or so hp. 80 hp and 101 hp are not nearly the same. I've seen numbers for MM anywhere from 100 to 110 peak hp. If yours made only 95 peak hp, then all the other dynos around are poorly calibrated, are using an inaccurate correction factor, or all the other MM dyno charts came from modified bikes, or your bike might be out of tune. I would tend to assume that if yours was tested on the same day at roughly the same time as other MM's, it would produce similar numbers to other MMs.
With a stock exhaust, mine made 101 hp and made 105 hp with a good fuel map, at the rear wheel. Those numbers would be reasonable compared to factory specs of 115 hp at the crank.
So I'm trying to understand the "all make around 95 hp" but your bike still runs away with ease. It would make sense then that they all don't make around 95 hp unless your "around" is, once again, +/- 10 or more hp.
15 hp is a lot and 15 lb/ft of torque is also A LOT of difference in a 400 lb bike.
Old 12-22-2009, 02:59 PM   #833
NakedRider
NakedRider
NakedRider's Avatar
Oddometer: 664
Let's not forget the torque factor here. Regardless of HP when you first twist the wrist it's the torque that gives you the shove.
Coming out of turns I could easily out pull a 600cc sport bike because I had way more torque. Had the run been longer they would have caught up because they had more HP.
'09 BMW R1200R
Old 12-22-2009, 10:22 PM   #834
fixinbones
Tarmac Adventurer
fixinbones's Avatar
Oddometer: 2,012
Anybody install a power commander their MM. Im looking to get one to compliment my Akra exhaust system. Any info regarding who makes them and where to get them would be appreciated. I'm not looking to completely rework the fuel map, I just want to have a basic setup for a header/aftermarket exhaust sans cat. Thanks in advance.
'13 Ducati Diavel AMG #163
'09 KTM 65XC (son's ride)
Gone: '10 Ducati Multistrada 1200S, '11 BMW R1200GS, '10 BMW S1000RR, '08 BMW HP2 Megamoto, '07 KTM 950SMR, '05 BMW R1200GS, '94 BMW R1100R
fixinbones is offline   Reply With Quote
Old 12-23-2009, 07:34 AM   #835
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 831
Check here Jay.
http://www.advrider.com/forums/showt...r#post11453048
Steve
Maineroads is offline   Reply With Quote
Old 12-28-2009, 02:34 PM   #836
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 831
Has anyone fitted a Bags Connection tankring to their bike. I cant verify which one I need as my bike is in storage. Thanks, Steve
Found it....
Steve
Maineroads screwed with this post 12-28-2009 at 03:25 PM
Old 12-29-2009, 04:23 AM   #837
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,255
Curious if anyone has ridden the MM back-to-back with a GS. I'd like to know some impressions about the MM gearbox.
Does it seem more refined, tighter? What about dropped shifts? Just looking for some comparisons and impressions.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 12-29-2009, 06:41 AM   #838
RoteEddie
Oddometer: 531
The gearbox is an improvement over the other gs boxes I've tried. I've owned a 04' GS, 07' GS and 07' GSA. No dropped shifts for me, but then I can't recall any on my previous GS'es either. The MM shift simply feel more positive :-)
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is online now   Reply With Quote
Old 12-30-2009, 01:16 PM   #839
fixinbones
Tarmac Adventurer
fixinbones's Avatar
Oddometer: 2,012
Definitely a much better box then my 05 GS. much eaiser to find neutral, shifts very crisp for a The MM will turn higher RPMs in any given. gear than the GS. I find myself the next higher gear in the MM compared to the GS in many situations.
Old 01-07-2010, 12:08 AM   #840
bingbong
bingbong's Avatar
Oddometer: 792
Question MM fly screen
Happy new year all
I am trying to get one of these manufactured as the person(s) are not contactable who made this one.
I have been in contact with a company in the UK that said they can make them with some help. The biggest step is getting a mold made up of what I want, (something very close to this). I am investigating if I can make the mold myself then send it to them for manufacturing only. But if that is not possible then they will make the mold. For them to do this I need a UK volunteer that would be willing to take their MM to the company for measuring/mold making. I'll confirm what is involved first of course .
The company is based in Stokesly, Cleveland. Is that near anybody?
The next thing to ask of course is....
who would be interested in having one of these? the more people the cheaper it gets and if I can make my own mold it should be cheaper still. In any case I am hoping to keep the price to around 200 pounds but certainly under 300 but that is all guess work at this stage.
any interest?
cheers
R Nine T
"you're never too old to learn something stupid" -- unknown.
bingbong is offline   Reply With Quote
Times are GMT -7.   It's 02:34 PM.
