Go Back   ADVrider > Riding > Regional Forums > Central From Da Nort Woods to the Plane States
Old 10-09-2012, 04:53 PM   #7216
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 11,410
That would be an awesome plan.
all around good guy
barnyard is offline   Reply With Quote
Old 10-09-2012, 05:25 PM   #7217
propforward
PIE!romaniac
propforward's Avatar
Oddometer: 12,989
Right. Unless you have specific requirements I'll figure out some sort of route out and back.
Meet for breakfast?
Suggest Merlins Family Restaurant on 169 and 95 at 9 am?
Otherwise, just head out from my place if'n ya want.
You're beginning to damage my calm.
propforward is offline   Reply With Quote
Old 10-09-2012, 05:27 PM   #7218
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 11,410
I can meet at your place and we can go from there.
all around good guy
Old 10-09-2012, 05:42 PM   #7219
propforward
PIE!romaniac
Oddometer: 12,989
Righty ho then.
Old 10-09-2012, 06:24 PM   #7220
propforward
PIE!romaniac
Oddometer: 12,989
OK, got a 300 mile round trip idea that should work well. Gets us to the Pie Shoppe mid day ish (depending on brekky arrangements), and so gives us plenty of sit around eating pie time, coffee stop time and the like.
If pmd hasn't nabbed the tag we can add that to the route, but I expect it will have moved by thursday.
Also gets us home before prime forest rat hour.
propforward screwed with this post 10-10-2012 at 05:52 AM Reason: Quickly! Before the Kleigh sees!
Old 10-09-2012, 06:51 PM   #7221
barnyard
Verbal tactician
barnyard's Avatar
Oddometer: 11,410
I should find my camera and make sure the battery is charged.
all around good guy
Old 10-09-2012, 08:12 PM   #7222
Powershouse
Flower Sniffer
Powershouse's Avatar
Oddometer: 2,252
My nut's too big.
Enough of the crankshaft talk....I've got a problem, my nut's too big.
From Camera Awesome Photos
The nut on the left is what the engineers at BMW designed to hold the axles on. It's a 26mm nut. Have you got a 26mm in your tool box? I don't. So I would like to replace that with a 27mm nut that I do have wrenches for. Which brings us to the right nut; the one that's too big. The right nut is a KTM 27mm with the same thread as the left nut. Problem is that the BMW axle nut fits into another piece that is the diameter of the collar at the base of the nut. So I need to take about 2mm off the diameter of the collar at the base of the KTM nut. The KTM nut is aluminum so I could work on it with a file but if anyone has a way to turn it properly it would probably come out better.
Anyone? Buehler?
Wisconsin Rustic Road Century
Powershouse is offline   Reply With Quote
Old 10-09-2012, 08:34 PM   #7223
Spikehead
Two-Bit Throttle Bum
Spikehead's Avatar
Oddometer: 6,306
Mike Weston
Lee Bruns
Originally Posted by Powershouse View Post
Anyone? Buehler?
-Spikehead
"I was tempted by the Invisible Man, I surely was." -Propforward
Spikehead is offline   Reply With Quote
Old 10-10-2012, 04:12 AM   #7224
propforward
PIE!romaniac
Oddometer: 12,989
Anyone? Buehler?
Personally I'd leap at the opportunity to obtain another tool. I do have a socket that size, but not a spanner (wrench ).
My lathe is up and running now, I can do it for yer if'n ya want. I am not a master machinist by any means, but I can do it, being as it's only skimming a lil bit off the diameter.
It might cost you more in gas getting to my place than it would buying a new wrench though.
17 bucks for a 26 mm Wrench:
http://www.sears.com/craftsman-26mm-...p-00942932000P
propforward screwed with this post 10-10-2012 at 06:18 AM
Old 10-10-2012, 06:19 AM   #7225
FirstPath
FirstPath's Avatar
Oddometer: 2,329
Did you all see the high temp for Friday is going to be near 70 degrees?! That sucks 'cuz I gotta work.
Scott in Shoreview
'79 Suzuki GS550
FirstPath is offline   Reply With Quote
Old 10-10-2012, 06:20 AM   #7226
propforward
PIE!romaniac
Oddometer: 12,989
My forecast says high of 50 on friday, which is still splendid.
Although a bit lower in Grand Marais.
Old 10-10-2012, 08:07 AM   #7227
safetybob
safetybob's Avatar
Oddometer: 740
Powerhouse you are close to me, you can come on down and we can spin it on my lathe as well. Your call, Prop is much better machinist than I but if you're using a file, I may fit to your KLR standard.
safetybob is offline   Reply With Quote
Old 10-10-2012, 08:42 AM   #7228
FirstPath
FirstPath's Avatar
Oddometer: 2,329
Scott in Shoreview
'79 Suzuki GS550
Never mind... yep, 50s.... Still sucks to work though.
Old 10-10-2012, 09:43 AM   #7229
swann
Just practicing...
Oddometer: 273
All righty, what's the route for tomorrow? I have at least until noon off.
Good judgment comes from experience. Experience comes from bad judgment. ~ various
Believe you can and you're halfway there. ~ Theodore Roosevelt
swann is offline   Reply With Quote
Old 10-10-2012, 09:54 AM   #7230
propforward
PIE!romaniac
Oddometer: 12,989
I'll post some details tonight, but basically heading east to Wisconsin via Cambridge and Scandia, crossing over to Wi in Stillwater I think, then heading south via backroads to end up in Stockholm, Wi at roughly noon. Not sure what time we are meeting yet, but it sounds like 9am ish.
After lunch and pie we'll come back via different backroads.
Times are GMT -7.   It's 07:16 AM.
