Old 01-05-2013, 07:40 PM   #61
brucifer
brucifer's Avatar
Oddometer: 2,429
Well, this probably isn't much help to you but a buddy of mine was way into these 500s several years ago and had tons of engine parts lying around. I know I've seen heads with and without the slots cut in them. It may have been a running production change Honda made to help oil the journals in the post '79 engines.
If it was me putting this engine together, I certainly wouldn't be afraid of using the '79 head. Just keep the oil clean and full.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 01-05-2013, 08:06 PM   #62
brucifer
brucifer's Avatar
Oddometer: 2,429
Just found this: http://www.ebay.com/itm/1981-XL500-H...e9f789&vxp=mtr
No grooves.
*Edit*
Looking at FT500 heads on ebay as well--basically the same as your head--and they don't have grooves either.
It's kinda looking like the plain ones are the norm and the grooved the exception.
brucifer screwed with this post 01-05-2013 at 08:18 PM Reason: More info.
Old 01-07-2013, 06:51 PM   #63
mtn500 OP
bush jumper
mtn500's Avatar
Oddometer: 304
Brucifer, thanks for your input and help. I saw the same with the other heads and figured the ones with no slots would be OK too, but I really wanted somebody else to have the same opinion/reasoning .
I can't wait to get this girl back together and running. I've been going at it slow but I want to make sure that I do it right the first time.
certs and destroy
If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law.
When any government, or any church for that matter, undertakes to say to its subjects, "This you may not read, this you may not see, this you are forbidden to know", the end result is tyranny and oppression no matter how holy the motives.
mtn500 is offline   Reply With Quote
Old 01-07-2013, 07:29 PM   #64
sieg
sieg's Avatar
Oddometer: 2,821
I love these threads, it's amazing how much money and time you can save doing your own maintenance. And hell this mechanic stuff is so simple anyone can do it!
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 01-10-2013, 06:27 PM   #65
mtn500 OP
bush jumper
mtn500's Avatar
Oddometer: 304
I am investigation the need for a set of ring expander pliers. As I have never installed new rings before can anyone comment on whether or not the ring expanders are necessary? Can the rings be CAREFULLY installed by hand or are the expanders highly recommended for installation?
certs and destroy
Old 01-10-2013, 06:35 PM   #66
sieg
sieg's Avatar
Oddometer: 2,821
Your fingers should suffice.
Old 01-10-2013, 06:41 PM   #67
mtn500 OP
bush jumper
mtn500's Avatar
Oddometer: 304
That is what I am thinking too as the rings are pretty thin. I'm probably just over thinking the whole process because I don' t want to mess it up. I've been told that the rings can be over expanded, and that makes sense but I figure if I very carefully do it...
certs and destroy
Old 01-10-2013, 06:48 PM   #68
brucifer
brucifer's Avatar
Oddometer: 2,429
Yeah, just take your time and be careful. If you have any questions on which rings go where or their orientation, just ask. Good luck.
Old 03-03-2013, 08:45 AM   #69
mtn500 OP
bush jumper
mtn500's Avatar
Oddometer: 304
Cylinder head exhaust studs
Has anyone got any experience with replacing the exhaust stud bolts on the cylinder head? The studs would be at the 5 and 11 o'clock positions around the exhaust ports.
My replacement head for this project did not have the studs when I received it. I ordered new studs to insert but the diameter of the end that screws into the cylinder head (end with fewer threads) seems to be too large. I have double checked that I ordered and received the correct part and verified that both the 79 ad 80 models used the same size studs. Using a caliper I measured the diameter of both ends of the studs; the end with fewer threads does have a slightly larger diameter. The stud(s) will start threading into the cylinder head but get really tight about half way in.
I do not want to keep tightening and force them in and risk stripping the threads in the cylinder head. I've compared/referenced my old cylinder head and I am inserting them in the correct orientation. If i reverse orientation I can screw them in all the way with no problem, but hat is not how they are supposed to go.
My clymer manual has limited info and does not indicate the correct torque to apply to these studs.
Anyone know the correct amount of torque?
Should they be this tight?
Thoughts?
certs and destroy
Old 03-03-2013, 11:06 AM   #70
brucifer
brucifer's Avatar
Oddometer: 2,429
When you screw them in the other way, do they feel kinda loose or wiggly?
I checked my Honda XR500 manual but it didn't say anything about those studs or the exhaust at all.
I'm thinking that maybe the threads are an interference fit possibly, where the threads in the head are a little off to the threads on the stud for locking purposes--so the studs wouldn't come out with the nuts every time you loosened them. I could be way off on that though...
Hopefully someone else will chime in.
Old 03-03-2013, 11:38 AM   #71
mtn500 OP
bush jumper
mtn500's Avatar
Oddometer: 304
brucifer, thanks for chiming in. When the threads are screwed in the other way they are just noticeably loose/wiggly all the way until all the threads are sunk and the smooth part of the stud is flush to the head.
I have came across the interference fit theory and that makes sense. However, I don't want to push my luck, until I know for sure, and risk damaging this head.
certs and destroy
Times are GMT -7.   It's 09:12 AM.
