Old 03-07-2006, 09:39 PM   #1636
rockt
Oddometer: 1,163
Originally Posted by wpbarlow
Then I remembered Avon Gripsters. I ran through a couple sets on my Morini Camel and liked them, so figured I'd try them on the TA.
Little more agressive tread than the Siracs, but that should be fine.
I'm also thinking of trying TKCs on the other set of rims when the Karoos wear out in prep for a 2k mile mixed surface trip later this year in hopes of better mileage.
Gripsters last a long time and are decent for light off-road, but not mud, (like most DS tires).
What kind of mileage have you seen from the Karoos?
rockt is offline   Reply With Quote
Old 03-08-2006, 06:14 AM   #1637
wpbarlow
Oddometer: 10,619
About 2k miles. What burns them out is that I usually have 20-40 miles of highway to get to the good stuff and am not afraid of working them on pavement. Siracs are good for almost 5k miles; unless I take a long road tour. I fried a set of them in <3k miles doing CroMags 2 years ago.
wpbarlow is online now   Reply With Quote
Old 03-08-2006, 06:38 AM   #1638
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 470
I'm happy with tourances on my TA. Had em' on my GS in the past too...good milage and they do ok in the dirt.
00 Honda Africa Twin XRV750 RD07a -- Rebuild Story
89 Honda Africa Twin XRV650 RD03 -- Its here!! -- Restoration
69 Honda CB750 Sandcast - Restoring Now
ujeni is offline   Reply With Quote
Old 03-08-2006, 07:33 AM   #1639
gothamAlp
happy to be here
gothamAlp's Avatar
Oddometer: 809
Thumb twisted throttle
i've also just used twisted throttle for the MRA-Vario windscreen, and bar risers. took a while on the screen, too. but they were conscientious about keeping me posted on it.
Originally Posted by Santa
Where are you guys getting the aluminum bash plates?
Twisted throttle comes up on the web.
Any one do business there?
Thanks for the info.
Santa
gothamAlp screwed with this post 02-13-2007 at 02:27 PM
gothamAlp is offline   Reply With Quote
Old 03-08-2006, 07:58 AM   #1640
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 470
Hey, I am in the midst of an 8k service on my 89 TA. The manual calls for 50/50 mix of water and ethylene glycol.
Can I use water and car antifreeze? Same thing? EDIT: Just found elsewhere in the manual where the refer to it as antifreeze....so I guess that will be fine (can you tell this is my first water-cooled bike?)
Also, anyone make their own carb sync tool? I found this version and I am gonna try it out later today:
$1.55 Carb Sync Tool
Any thoughts?
Old 03-08-2006, 08:36 AM   #1641
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
If you're going to use automotive antifreeze, make sure it's the kind compatible with aluminum. And use distilled water for your mixture. I use Spectro coolant. It's already mixed and made for bikes. It's not that expensive either. I think you only need 2.2 quarts. By the time you get a gallon of the car stuff, a gallon of water and mix it up, you have way too much hanging around for the next few years. Just my thoughts.
Jim.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 03-08-2006, 11:09 AM   #1642
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
The carb sync tool works great. I've found that the TA runs best when the carbs are synced at idle or just barely above. For some reason (maybe the wierd TA intact tract) the sync changes at larger throttle openings. I've synced at 4000 rpm only to be unhappy with increased vibes under load like when climbing a hill.
Best smoothness came with the carbs done at idle....your mileage may vary. Build up a small plastic fuel bottle so you can completely remove the tank when doing the carbs. My wife got real bored holding the tank to the left of the bike while I fooled around with the sync screw. Oh...you'll also need a phillips screwdriver #2 (I think) with a long narrow shaft to reach the screw.
On antifreeze/coolant, an old Honda mechanic (like been working on them since the CB model days) says that Honda cooland or a product called "Coolinall" or similar does best. He says that the weak link in the water pumps is the ceramic seal and the Honda brand stuff does best with lubing this seal and letting water pumps last. For the relatively insignificant savings in buyin the auto stuff I've listened to him and have had good luck with water pumps on the TA (36,000) and my DRZ (6500). The DRZ by the way has a rep for leaking water pumps.
Ray Stedronsky
Davis, CA
Ladder106 is offline   Reply With Quote
Old 03-08-2006, 11:11 AM   #1643
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 470
Ok, one more question...
Did I screw up? I noticed that the headers on my transalp were looking worn and showing a bit of surface rust here and there. So i took them off, cleaned them up and refinished them with high-heat paint (up to 500 degreef F according to the label). Now, a day later, when I start the bike, the pipes are smoking and the paint goes soft. Did I just screw up or do I need to let the paint dry longer? New pipes aren't too expensive.....
Old 03-08-2006, 12:49 PM   #1644
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
The paint will stop smoking eventually. If you have some down time, I would get them ceramic coated.
Jim.
Jim Rowley
Black Forest, CO
Old 03-08-2006, 01:09 PM   #1645
Dixter
Boxertrixter
Oddometer: 216
Ok...I don't own one but I rented an AT whilst visiting a friend in Cyprus back in '04. Really grew to like this bike, especially on the island's fabulous roads.
Yours truly - hating every minute of it...
'00 Honda VFR800FiX
www.boxertrix.com
Dixter is offline   Reply With Quote
Old 03-09-2006, 04:09 PM   #1646
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 470
Jim.
Yer right...they turned out nice actually.
By the way, I am looking for an original transalp exhaust to trade for my stainless steel exhaust. Here's a pic:
Just put the ad in the fle market too:
http://www.advrider.com/forums/showthread.php?t=124087
Anyone wanna trade your quiet honda exhaust for my cool-but-too-loud-for-my-wimpy-ears supertrapp?
Old 03-10-2006, 08:58 AM   #1647
PTRadam
Oddometer: 499
Hey Ujeni, I think you can add discs to your suppertrap to quiet it down. I had one on an XR once and that was how it worked.
PTRadam is offline   Reply With Quote
Old 03-10-2006, 09:05 AM   #1648
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I think it's the other way around. You remove discs to quiet it down. But you also change the power and torque bands.
I think Modrover had a stock muffler for sale. Come in, Michael.
Jim.
Jim Rowley
Black Forest, CO
Old 03-11-2006, 08:39 AM   #1649
HighwayChile
greetings from Wa state
HighwayChile's Avatar
Oddometer: 4,349
oh man I'd be all over this if it would be possible,
http://cgi.ebay.co.uk/2-HONDA-XLV750...QQcmdZViewItem
I would rather wake up in the middle of nowhere than in any city on earth. .....Steve McQueen
HighwayChile is offline   Reply With Quote
Old 03-13-2006, 08:58 AM   #1650
Craypot
Lounge lizard
Craypot's Avatar
Oddometer: 787
I've made one of these carb sync tools. Very easy to make and they work fine. No need to get a yard stick any piece of wood or anything long and thin will do. There's no need for measurements as all you are trying to do is get the oil level.
Any thoughts?
Craypot is offline   Reply With Quote
Times are GMT -7.   It's 08:15 AM.
