Old 11-25-2008, 11:15 AM   #5626
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,266
It seems like it was powder coated or painted...
Originally Posted by ravelv
Was trying to wash RD03 caliper bracket, well, seems that I have to look for more extreme washing chemicals as dirt bike cleaner, acetone, soap cleaned only half dirt... Seems that poor RD03 where never washed...
Any suggestions?
Carlos locorider
1974 Catalina 22....sailing, mi otra pasión!
"If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian
"Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller
Longaniza Ride
Ruta del Café
Old 11-25-2008, 11:23 AM   #5627
mas335
xendurist
Oddometer: 1,552
Any suggestions?
Try a spray type carburator cleaner or better yet something with the chemical MEK in it. Don't breath it!
Transalps
mas335 is offline   Reply With Quote
Old 11-25-2008, 11:27 AM   #5628
mas335
xendurist
Oddometer: 1,552
Originally Posted by Santa
Does sound CDI related. You say the tach reading jumped?
simulate a lean condition by turning off the gas while running.
If others are seeking spare CDI's I have two to sell as well
I won't go for a ride without a spare pair in a holder ready to install. Not for me of course but for that one in a million chance I'll run into one of you guys on the side of the road wishing you had a spare CDI module with you.
Transalps
Old 11-25-2008, 11:30 AM   #5629
locorider
locorider's Avatar
Oddometer: 2,266
Now we have five stars, again!!! *****
Carlos locorider
Longaniza Ride
Ruta del Café
Old 11-25-2008, 12:10 PM   #5630
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 367
Dogbone/swingarm bearings and CDI/rough running problems
Couple comments on these two current issues from experieces early this summer before my Alaska trip.
Dogbone/Swingarm bearings:
Since I planned to have the rear suspension apart to replace the rear shock prior to my trip, I figured I might as well replace all the needle bearing while I had it apart. Individually they aren't very expensive, but there are two different sizes involved, and there are a bunch of them, so they add up. The real problem is that they are a real PITA to get in and out. Really requires a hydraulic press with the correct fttings to properly get them in and out. Finally decided to just pay a shop to press most of them out/in. In the end, just wish I had carefully taken them apart (so as not to lose needles), and cleaned/regreased them. Also, to get all of them out you have to deal with that clever Honda design feature that requires you to remove the exhaust to get one of the bolts out. If you take the exhaust parts apart to do this, I suggest you get new gaskets prior to starting the whole project.
CDI/rough running:
While the problem reported could be the CDI (I've had one fail somewhat similarly), it also sounds like carb problems which I've had several of. There are numerous pathways in the carbs that can be easily plugged and cause sporatic problems. Midway through my trip I got some bad gas, or sucked something in through the air box and caused similar rough running issues. Started and idled fine, and ran at high RPMs fine, but everything in between was not well. Took the carbs apart, cleaned them thouroghly, and all was good again. Advice on ADVrider is to be sure to use motorcycle specific carb cleaner, and not auto carb cleaner since the auto version may destroy the gaskets and o-rings in the carbs.
A few years ago a bad float valve turned out to be the problem where the bike would run fine for a while then start coughing and quit all together. The valve and seat looked and appeared to work just fine, but replacing them solved my problems
Hope this helps,
Dale
wdeTA is offline   Reply With Quote
Old 11-25-2008, 12:11 PM   #5631
ravelv
from Baltic side of river
Oddometer: 406
No, this is a bit better... These are crops from pictures about fitting AT swingarm, so, don't be surprised about hanging bolt in center of picture.
Originally Posted by locorider
I was about to say the same...good picture of the centerstand mount!!!!
ravelv is offline   Reply With Quote
Old 11-25-2008, 12:38 PM   #5632
ravelv
Oddometer: 406
If bearings are ok, I recommend to replace sealings, especially that one in triangle-shock joint place- these are weakest ones comparing to others.
Replacing bearings in triangle was very simple with home tools without any press. I did twice for RD03 triangle in shock mount place due to rusted bearings because of cracked sealings... Yes, these are indeed weak.
I also never removed exaust when removing suspension.
Old 11-25-2008, 12:40 PM   #5633
Santa
Focused on the Future
Santa's Avatar
Oddometer: 1,378
Kinda like Grey Poupon eh?
Santa is offline   Reply With Quote
Old 11-25-2008, 01:06 PM   #5634
soloyosh
Dad and husband
soloyosh's Avatar
Oddometer: 5,465
Careful with that stuff. In the environmental cleanup field we called that stuff Methyl-Ethyl-Killyoubad.
2007 Aprilia RXV 5.5
soloyosh is offline   Reply With Quote
Old 11-25-2008, 03:21 PM   #5635
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,269
Any suggestions?
I'd bead blast it....then clearcoat. It'll give you a "matte" type finish though. If you want shiny....it's going to take time and effort.
Ladder106 is offline   Reply With Quote
Old 11-25-2008, 03:21 PM   #5636
locorider
locorider's Avatar
Oddometer: 2,266
Did you posted a RR about your trip to Alaska?
CDI/rough running:
Hope this helps,
Dale
Carlos locorider
Longaniza Ride
Ruta del Café
Old 11-25-2008, 03:31 PM   #5637
locorider
locorider's Avatar
Oddometer: 2,266
Guys: While going over speed bumps I noticed that there is a "bump" noise, like if the fork tube was coming all the way out and nothing to dampen it.
I haven't checked the oil level. What might be the source, low oil level on the fork? Or, is this just something I have to live with because of the pvc spacer?
Carlos locorider
Longaniza Ride
Ruta del Café
Old 11-25-2008, 04:33 PM   #5638
Ladder106
Ladder106's Avatar
Oddometer: 4,269
Squish or squirt?
Carlos, are you talking about when the forks compress when you first contact the bump - or - when they extend afterward.
If it's compression, you might try adding 10cc more oil. If it's extension, the preload spacer is most likely too long for your bike/rider weight. First make sure there's no air pressure build up in the tubes then consider taking .25 to .5 in. off the spacer.
What do the forks do with the weight of the bike on them? Are they compressed an inch or so from fully extended?
Old 11-25-2008, 04:36 PM   #5639
Andy G
2wheeled alpinist
Andy G's Avatar
Oddometer: 551
How did you get them out?
Cheers, Andy
Andy G is offline   Reply With Quote
Old 11-25-2008, 04:46 PM   #5640
locorider
locorider's Avatar
Oddometer: 2,266
Sorry for my crapy english!!!
[quote=Ladder106]Carlos, are you talking about when the forks compress when you first contact the bump - or - when they extend afterward.
When they extend...
It looks like there is an inch.
It looks awesome, but I think the 1.5" is too much.
Carlos locorider
Longaniza Ride
Ruta del Café
Times are GMT -7.   It's 12:30 PM.
