04-21-2004, 08:49 AM
#46 |
BOOMSHANKA!
Oddometer: 3,570
Yes... I will be doing something similar
Hey! Yes, I'm in the process of trying to find a nice low mile excellent shape TransAlp. I plan to keep it that way after buying it!
The TransAlp I have now... I want to put on a diet and modify it a bit. Nothing that can't be put back to stock. I will for sure be removing all the fairing parts and side panels. I will be putting on a smaller headlight assembly and such. Hopefully, I can reduce the weight up top and get it lower on the bike. Then, a bit more aggressive tires... maybe some better sus. springs... hmm... yes, this will be fun! I just don't want to start doing this until I have another TransAlp to use daily for commuting and the like. Regards, Michael '89 TA Van., WA USA
~Michael (of The Land of Misfit Land Rovers) Used to have an Africa Twin and Transalp X-Files Gov't Issue Sprinter TurboDiesel ![]() Washougal, WA USA |
04-22-2004, 09:06 PM
#47 |
greetings from Wa state
Oddometer: 4,099
some nice TA here, mines a bit flogged compaed to your bikes, i bought it ( cheap !!) last fall, working on getting it up to spec, fork springs, bearings, CDI's, ohlins rear shock
Anyone hang some bigger forks on theirs? I have heard XR650 fit fairly easily, I have 2 sets and may do the swap, they will need to be lowered natch', I have some USD forks, Showa that I might try to graft on also, it would reduce turnign radius with the USD, I have some ohlins USD but those might go on something else (hmmm DL650....) anyone lengthen the rear suspension? how would a 1" longer shock work ? check this out http://www.xs4all.nl/~hanzw/jpg/dave01.htm note the 650V engine anyone know Dave? this was pinched from the same web site, about the above bike, is this trick or what ? CR frame ..... SA 1990 red Â* See below Â* Â* It is great to find so many Transalp enthusiasts on the web. As you know not as many TAs in the USA... 89 & 90 only... XLV-750Rs and African Twins are grey market only. I have a 1989 Transalp which is White and one of the first in the USA. It has approx. 7K miles and has been modified with a fabricated carbonfiber exhaust, de-smogged, re-jetted, K&N air filter, BMW luggage racks, Enduro 4 Tires, dyno-tuned, etc... I recently purchased a 1990 Transalp with 12K miles ( I always wanted a red one. It is stock for now. I bought it to install my spare NT-650 engine in it but the original equipment is still so good that I'm hesitant to molest it. So I think I'll look for a thrasher to build up. I mostly ride in the coastal mountians of Northern California where I live. We ride year round here and dual sport alot using XR-600Rs made street legal. A group of us ride on every Tuesday night in the Santa Cruz Mountians near Los Gatos, CA. Lots of fun. We are allowed to modify our bikes here. I would like to build up a TA with a African Twin 750 engine or equal. Is anyone already doing this? Harry a friend of mine and expert craftsman recently completed a TA with a 700cc NT-650 built to TWO BROS. specs. He says it bolted right in. he also lowered it and installed CBR wheels and sport bike rear body treatment. This bike was on the road before the new VTR and is very trick. I also own and ride a Hybrid Dualsport bike built by Harry for himself in the early 90s as a desert racer. It has a NT-650 Twin also built as a 700cc special, mounted in a custom fabricated frame using CR-500 suspension componetry. I have riden this bike for the past three years and it thrills me every time. (photo attached) I would enjoy e-mailing with anyone who has similar intrests or has experience and knowledge of AT & TA modifications and engine swaps.
HighwayChile screwed with this post 05-22-2007 at 08:44 PM |
04-22-2004, 09:09 PM
#48 |
Oddometer: 4,099
image went to the bottom of description, I want this Bike!!
I would guess weight maybe under 400lb, maybe less |
04-23-2004, 07:44 AM
#49 |
Oddometer: 271
That IS an awesome bike. Not really a TA any more, but a very cool set up.
Now I feel like the simple little mods I've been posting are pretty boring. Oh well, here's another one. Protect that rear shock with a mudflap extension!
Jay - 98 KLR650, 63CA95, 84XL350, 94ST1100 |
04-23-2004, 10:05 AM
#50 |
Oddometer: 7,891
Probably not what you had in mind :-)
Parts from 18 different bikes- details at http://ratbike.org/docs/577.php
Walter Barlow |
04-23-2004, 10:08 AM
#51 |
Oddometer: 7,891
Can't forget the front :-)
Love the headlight treatment
Walter Barlow |
04-23-2004, 03:44 PM
#52 |
BOOMSHANKA!
Oddometer: 3,570
Yes. I've seen that TA motor in a CR frame bike before. Very very cool!
As for that other "thing"... hmm... I believe I've seen that in the original Mad Max movie! Oh man, what a project bike! Still... it's cool to me in that F'd up kind of way... I'm not sure what it's saying, but I wouldn't get in it's way! Regards, Michael '89 TransAlp (and looking for another TransAlp) Van., WA USA
04-23-2004, 07:46 PM
#53 |
Oddometer: 4,099
WPBarlow, for a second I thought that was a Buell muffler but its too small
ya just need to add a shotgun or small missle launcher, cool bike!!
04-23-2004, 10:23 PM
#54 |
BOOMSHANKA!
Oddometer: 3,570
speedo gear mod?
Not really a mod at all, but still an important part to keep properly cared for. I was forced to replace mine. I found there to be a small bur in the metal speedo housing that really caused the problem... the plastic gear is the weakest link so it goes first!
The typical speedo gear problem. Regards, Michael '89 TA (and looking for another TA) Van., WA USA
04-23-2004, 10:26 PM
#55 |
BOOMSHANKA!
Oddometer: 3,570
The replacement gear
And this is the replacement. Nice and new right from Honda!
Be sure to use white lithium grease of this... it doesn't react with the plastic like most other grease. Regards, Michael '89 TA (and looking for another TA) Van., WA USA
04-23-2004, 10:37 PM
#56 |
BOOMSHANKA!
Oddometer: 3,570
it's ride time! I mean, that's the best part of seeing if your fix actually worked!
Funny thing... one more step back and it's a 30 foot drop down to the stream! Regards, Michael '89 TA (and looking for another TA) Van., WA USA
04-23-2004, 10:42 PM
#57 |
BOOMSHANKA!
Oddometer: 3,570
Hey... look at this Transalp!
It's nothing to ride, but it's a wonderful thing indeed!
It's really called the Transalp. Made by CamelBak. Man, that co. has come a long way since offering just the little bladders with straws. Regards, Michael '89 TA (and looking for another TA) Van., WA USA
04-23-2004, 10:45 PM
#58 |
BOOMSHANKA!
Oddometer: 3,570
and now... again... something completely different
Check this Mad Max TA out... this rig's got more room for that machine gun.
04-24-2004, 07:55 AM
#59 |
Oddometer: 4,099
10-4 on the speedo gear , mine needs replacing too
say motupaiki do you have a overheat problem with your aircooled xr? I have heard the back cylinder can over heat. that is a great bike, if ya ever want to sell it post it here on Advrider, maybe I could sneak it back in luggage ![]() Modrover sounds like you are looking for the same type TA as me, keep the stocker and get another hard core version. I would like to find out more how Dave bertrams was put together ( i posted photo earlier) I do not know him, just found the photo, caption says its a CR 500 frame mod., with all the chopper builders around you would think it would be possible to find someone to do the mod , weather it would be in reason is another matter. hhhhhmmmm, a Water cooled bike that has rad's in place. could be a fun winter project |
04-24-2004, 07:56 AM
#60 |
Oddometer: 4,099
check the forward muffler on the hack.......
