Old 02-01-2009, 01:44 PM   #6301
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,441
Nice DR Big Ladder!
1998 RMX 250 singletrack bike
96 XR600 adventure bike
KY state Vet A offroad champion
TAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 02-01-2009, 01:53 PM   #6302
NorCalTA
Roaming ADV Gnome
NorCalTA's Avatar
Oddometer: 1,395
Originally Posted by mas335
Ditto, and by the way, what exactly is that bike that Ray bought? I don't speak Suzuki.
Mark - here's some info
http://www.suzukicycles.org/DR-serie...800S-Big.shtml
NorCalTA is offline   Reply With Quote
Old 02-01-2009, 01:54 PM   #6303
debaisley
debaisley's Avatar
Oddometer: 1,388
I have always been a Honda man , but that Suzuki is TITS.
debaisley is offline   Reply With Quote
Old 02-01-2009, 02:34 PM   #6304
mas335
xendurist
Oddometer: 1,547
Originally Posted by NorCalDave
Thanks Dave, I haven't read it all just yet but I assume they never sold it here? It's a bike model I have never heard of but then again I pay no attention to Suzuki's.
Transalps
mas335 is offline   Reply With Quote
Old 02-01-2009, 02:39 PM   #6305
Jim Rowley
Now what?
Jim Rowley's Avatar
Oddometer: 2,249
Along with the Africa Twin, Téneré, Super Téneré and Varadero. But thanks to some souls, various bikes make it over here anyway.
Jim Rowley
Colorado Springs, CO
M. A. P.
Jim Rowley is offline   Reply With Quote
Old 02-01-2009, 02:52 PM   #6306
combustion cycles
Action Jansen
combustion cycles's Avatar
Oddometer: 99
Wheel Spacers for Frankenbike
Hey guys, I have a transalp with xr600r (very narrow) rear rim on a xlv650 alum swingarm and NT650 engine. Trying to be ready for Sandblast on this coming Saturday.
Bike has 1991 xr600r forks. Does anybody have a reference point on the frame/shock/motor for where the rear wheel centerline should fall? When i mock it up based on the front wheel centerline, it looks way to the right side. I want something else to go on since i have crashed the bike and front end might be tweaked. My front rim is centered between the fork sliders with a 1.4mm washer on the left side. Any Thoughts? I got my lathe going so spacers are no prob. I just hate making it a trial and error process...
you guys rock!
Motorcycle Sales and Service in Durham, NC -http://www.combustioncycles.com
1989 Transalp rally bike, plated XR650R, rat ST1100
Past Projects: Picasa Page!
Future: get back to Baja!
combustion cycles is offline   Reply With Quote
Old 02-01-2009, 04:05 PM   #6307
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,441
Gaspipe has a real nice DR Big too!
Old 02-01-2009, 04:06 PM   #6308
Jim Rowley
Now what?
Jim Rowley's Avatar
Oddometer: 2,249
What doesn't he have?
Jim Rowley
M. A. P.
Old 02-01-2009, 04:18 PM   #6309
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,441
Touche!
Old 02-01-2009, 05:10 PM   #6310
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,258
CJ,
This is the closest I could come to some type of reference point.
My bike uses the RD03 XRV650 rear arm and rear wheel. The centerline of the rear wheel lines up with the centerline of the rear suspension linkage. At least that's what it looks like to my eyes.
I think my neighbors though I was trying some arcane form of sepuku while trying to get photos. Looked a bit odd.
I can't really think of any other way to do this. But, even if the front is a bit tweaked (which may be doubtful unless you smacked something really hard), don't you want the front and rear wheels in the same line. Particularly riding in sand?
If I can be of any more help, let me know.
Good luck with the race. I'm glad someone is still running a big old trailie in this event.
Ladder106 is offline   Reply With Quote
Old 02-02-2009, 01:12 AM   #6311
Schelbi
Schelbi's Avatar
Oddometer: 134
Nice bike.
My girlfriend tried one of these DRs with the 800ccm engine but she decided to buy a 650 Transalp. I did a short test ride and I really liked the riding position and the suspension very much but the engine was really bad. My girlfriend's old XL600LM single had much more power than this Suzi.
Maybe there was something wrong with this engine. I can't believe that all 800ccm DRs are so weak. Please tell us about your DR as soon as you ride it!
btw. my girl is still very happy with her 650 Alp and I bought a 600 Alp directly after my first test ride with hers!
If you need parts for the DR Big search in Germany. Here are still a lot of these bikes.
Schelbi.
1975 Honda CB550 Four 1980 Honda CX500 dual sport conversion
1983 Honda XLV750R 1983 Honda XL600R
1983 Honda CB985FII Bol d'Or 1983 MZ ETZ250 sidecar
1985 Honda XL600LM 1988 Honda NX650
1989 Honda XL600V Transalp 1992 Honda XRV750 SW-Motec 1995 Husqvarna TE610
Schelbi is offline   Reply With Quote
Old 02-02-2009, 09:32 AM   #6312
WoodButcher
WoodButcher's Avatar
Oddometer: 1,644
Send a message via AIM to WoodButcher
Originally Posted by Ladder106
Check simple stuff first.
Did you fall or tip over on the left hand side? Is the shifter bent and hitting the case or anything preventing full lever movement? Grass, weeds branches etc jammed between the lever and the frame?
Lever loose on the shaft?
If it isn't that, the next step would be to remove the right side case, remove the clutch and look into the shifting mechanism and the shift drum detent "star". Maybe a PO bent something in there that finally wore to the point of not competing the shift.
Hope it's an "easy fix".....
Thanks Ray, I went out and double checked the cable adjustment. Even though I thought there was enough play I figured I'd start at the beginning. What I found was that the adjuster was wound all the way out to the point of no longer having any threads in the perch. So I adjusted it. I probably should get a new lever though because there pivot hole seems to have some play. Anyway, the cable still seemed like it had some slack in it though, but a test ride had perfect shifts. Which was nice, but I wasn't able to upshift at all into third or higher when the problem showed up orginally. The shift lever physically wouldn't go up. I've shifted my dirt bike many times (sometimes on purpose even) without using the clutch. So I'm concerned that the cable adjustment wasn't really the problem. Unless somebody can explain to me why a partial clutch engagement would prevent shifting?
So I may still have a problem. I'll do a longer ride this weekned and see if I can make it repeat.
NorCalDave, I've not had a problem with it popping out of gear. Hope that one doesn't start up too.
BTW, I'm at 23,000 miles on the odometer so I'd hope it wasn't the shift forks or the fork shaft. That's what I'm afraid of though.
Rusty
2009 BMW R1200GS Adventure
1999 DR650
2007 DR200
WoodButcher is offline   Reply With Quote
Old 02-02-2009, 10:49 AM   #6313
Shandy
Shandy's Avatar
Oddometer: 467
Clutch problem
First, I'm sorry I can not be part of a group that takes pictures up the skirts of motorcycles
Nice bike Ladder!!!
Duh...on the oil I used on my last oil change. I put "car" synthetic in my TA. At the recommendation of some of you I, 1. checked the make sure what kind of oil I put in. 2. Two oil changes on Saturday with Valvoline 20W-50 as recommended in the manual. The Valvoline said it was "extra good for wet clutches"....motorcycle oil mind you. Ran the first change for about an hr then drained, new oil again and new filter and ran it for about 1/2 hr through all the gears and.....no slippage Fixed? Maybe...time will tell.
Thanks for everyone input...and the FNG learned something too
JIM
1989 Transalp
Shandy is offline   Reply With Quote
Old 02-02-2009, 01:05 PM   #6314
combustion cycles
Action Jansen
Oddometer: 99
Sweet!
Thanks Ray for the pic! I'll post a link later to pics of the build. I still have much to get ready!
Dave
Old 02-03-2009, 02:40 AM   #6315
Thunder Dan
Thunder Dan's Avatar
Oddometer: 547
Question Suspension Upgrade Details????
G'day Guys,
I'm just about to get started on this Ignition bracket to mount the ignition/fuse box to the XR600 triple clamps. I found a good photo on page 136 (2028) & a drawing on page 137 (2046), but it only has the length & width of the plate. Does anyone have a drawing with hole centres marked out, etc? I'm still re-reading this thread, & am up to page 300, so I apologise if it has already been posted. If someone has a drawing & would like to email it, please PM me. Or if you can re-post it here that would be great!
Also, the rear shock is in getting serviced & the technician is organising the manufacture of the spacer. I am using the Standard Transalp ('88) swingarm with the '98 XR600R front end. Can anyone advise whether I am looking to extend the rear shock length by 25mm, 30mm, 35mm??? I can see that most of the TA's fitted with Africa Twin swing arms seem to be running 30mm spacers (is this correct?) but has anyone lifted the rear using the shorter, standard swing arm?
Any help is greatly apreciated guys
Cheers,
Daniel.
Thunder Dan is offline   Reply With Quote
Times are GMT -7.   It's 06:52 PM.
