Old 03-16-2009, 11:41 AM   #6721
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,899
I just took mine to the local muffer shop and had them weld a piece of SS tubing to the flange and mate that to the header. Works like a charm.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 03-16-2009, 12:27 PM   #6722
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 474
Originally Posted by NorCalDave
In the last few thousand miles, I've been noticing some instability at speed or while cornering that has me worried. By instability, I mean like if I'm on the freeway doing 75 and I make a little swerve to avoid a bad spot in the road, the bike shows signs of wanting to enter into a wobble/oscillation - the same will happen in a corner if I have to make a line adjustment.
The things that come to mind for me with what little mechanical knowledge I have are worn steering head bearings, swing arm bearings, and rear shock linkage bearings. With nearly 40k on her, would it be prudent to go nuts and just replace all the above? Besides needle bearings, do the "collars" that are shown in the parts fiches wear and need replacing too or should they be ok? What about the dust seals?
I'll second others suggestions here about the rear shock preload. I had s similar issue heading up to Alaska last summer. At speed the front end would shimmy all over the place when a made a quick manuever. I had replaced the headset bearings prior to the trip and was afraid I hadn't gotten it right, but couldn't deal with it on the road. I had also put on a new Wilbers rear shock and decided to try mucking with the preload to see how it affected the ride. Added in about a turn and the shimmy completely went away which made the riding much nicer and less nerve wracking.
Dale
89 Transalp
01 XR400R
http://daleeva.smugmug.com/Motorcycle
wdeTA is offline   Reply With Quote
Old 03-16-2009, 05:19 PM   #6723
Bikerjosh
I was punk once.
Oddometer: 166
My 1989 Transalp is on the fleamarket in Bay Area, CA
http://www.advrider.com/forums/showt...20#post9318120
Job elimination, and a demotion/paycut coupled with a crappy economy is forcing the sale of my transalp.
Please pass the word.
Thanks Josh
"Too dumb for opera, too smart for NASCAR"-Anonymous
Bikerjosh is offline   Reply With Quote
Old 03-16-2009, 10:39 PM   #6724
alculbreth
Oddometer: 57
Me too... '89 Transalp for sale
Link to ad in flea market...
http://www.advrider.com/forums/showthread.php?t=443632
alculbreth is offline   Reply With Quote
Old 03-17-2009, 12:09 AM   #6725
ravelv
from Baltic side of river
Oddometer: 444
This is very sad when you have to sell off your bikes to survive. :(
Well, but still few questions about hardware part- this is first TA I see with XR400 forks! How those 0.47 kg springs performs on TA with this fork? Has fork hydraulic part changed?
What suspension sag you get?
What about brake caliper, looks like that stright bolt on (comparing also XR650R caliper pictures against TA one some posts back)?
How did wheel fits?
And what tripples are used?
Any information (or closer photos) would be very helpfull for me, thank you!
Thanks Josh
ravelv screwed with this post 03-17-2009 at 04:34 AM
ravelv is offline   Reply With Quote
Old 03-17-2009, 12:10 AM   #6726
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,058
Thanks Josh
Sorry to hear all that. Hope it turns around soon.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Old 03-17-2009, 08:04 AM   #6727
Lear60man
Sleeping
Lear60man's Avatar
Oddometer: 720
Regarding what Jeff said, I took the new can to Midas and $50 bucks later they had a custom bent pipe welded up to my ebay find.
Are you guys having to re jett or play with the carbs after putting a new pipe on? Ive noticed power is up but it backfires a little.
Lear60man is offline   Reply With Quote
Old 03-17-2009, 08:59 AM   #6728
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
What can did you use specifically? How about a few pics showing some details?
FYI - if anyone's interested, the GSXR can I referenced in post #6714 is still available for $25 + shipping.
Help Stop McNugget Rage
WeeBee is offline   Reply With Quote
Old 03-17-2009, 11:22 AM   #6729
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,050
I'm interested in the muffler. Thought someone else was ahead of me....but I guess not
Ray
Ladder106 is offline   Reply With Quote
Old 03-17-2009, 11:29 AM   #6730
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
Ray
PM headed your way with the owners contact info
Old 03-17-2009, 12:41 PM   #6731
azabeemerboy
azabeemerboy's Avatar
Oddometer: 1,579
Carb Kit
Anyone got the a source on a carb kit for the TA. Looked at Service Honda but don't see a "kit"
Barry
azabeemerboy is offline   Reply With Quote
Old 03-17-2009, 01:27 PM   #6732
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,899
I didn't rejet and it seems fine, no backfiring at all.
Old 03-17-2009, 07:42 PM   #6733
Lear60man
Sleeping
Lear60man's Avatar
Oddometer: 720
Dave, I used a Yoshi shorty from a 750 GSXR. I really wanted a short pipe as it closely replicated the what was used on the Rothmans Dakkar bikes. This is the best pic I have now,(Im in Japan on the laptop) Post 6405.
http://www.advrider.com/forums/showt...39170&page=427
Old 03-17-2009, 08:01 PM   #6734
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
Thanks - that came out nice
Old 03-17-2009, 08:11 PM   #6735
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Just used a piece of 1/8"x2" aluminum flat stock as a hanger - strong enough or should I of used 3/16 or 1/4"?
Use steel. I had an aluminum hanger on another bike and it cracked and broke. One made out of steel is not going to be that heavy but offers more strength. I would bend it out a little, "s" shape. Looks great.
Jim.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Times are GMT -7.   It's 03:46 AM.
