Old 02-26-2005, 02:33 PM   #796
rob_erto
rob_erto's Avatar
Oddometer: 150
For a moment my heart felt so small!
I don't think I'd endanger my lil' Alp like that...
Rodolfo Barros - Portugal
Honda AfricaTwin '00
Honda X8R-X '00
rob_erto is offline   Reply With Quote
Old 02-26-2005, 06:49 PM   #797
Beemer Pat
Oddometer: 2,722
Very nice Keep up the hard riding.
Beemer Pat is offline   Reply With Quote
Old 02-26-2005, 07:02 PM   #798
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,464
Ya, I'm kind of abusive. This ones kind of funny.
http://yogoi.smugmug.com/gallery/411318
Look at this video
I got stuck in that sand so we dicided to set up camp. not a bad spot to be stuck.
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 02-26-2005, 07:14 PM   #799
seat_boy
Wannabe adventurer
seat_boy's Avatar
Oddometer: 156
Columbus?
Originally Posted by Jeff@TheQuadShop
Thanks, I picked it up in Columbus OH.
Where did this pop up for sale? I'm always looking at bikes for sale in the area (I'm in a Columbus 'burb) and I haven't seen a TA for sale since I bought mine.
Not that I need or want another TA, but I'm curious.
Eric
Currently between bikes..
seat_boy is offline   Reply With Quote
Old 02-26-2005, 07:15 PM   #800
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,730
I bought it at State 8 Motorcycles.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 02-26-2005, 07:21 PM   #801
modrover OP
BOOMSHANKA!
modrover's Avatar
Oddometer: 3,579
Look at this video
Maybe a ski under each box next time? Nice one!
~Michael (of The Land of Misfit Land Rovers)
Had an Africa Twin and Transalp
X-Files Gov't Issue Sprinter TurboDiesel
Series IIA 109" Land Rover Deluxe Station Wagon
Washougal, WA USA
modrover is offline   Reply With Quote
Old 02-26-2005, 10:30 PM   #802
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,464
Originally Posted by modrover
YOGOI... great vid.
I must say... BALLS man... BALLS... doing submarine stuff with only that stock lower cowl
Too bad I didn't get a video of this one. The water was up to the seat. A large boulder stoped me in the middle, but I was able to keep the motor going and powered through it. The Ever Amazing Transalp.
Old 02-27-2005, 04:56 AM   #803
Pete Rock
Oddometer: 527
Look at this video
you bad man, how much load was the bike carrying on that video?
Pete Rock is offline   Reply With Quote
Old 02-27-2005, 05:51 AM   #804
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,730
What kind of footpegs are those?
Old 02-27-2005, 07:12 AM   #805
rob_erto
rob_erto's Avatar
Oddometer: 150
On Yogoi bike?? They seem to be the stock Transalp pegs, with the original rubber inserts.
Honda X8R-X '00
Old 02-27-2005, 11:05 AM   #806
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,464
I never wade it to see. I wish I did. We had alot of camping gear in the top bag. (we camped 7 nights out of the 10 days we were on the Baja side). The boxes were packed to there max also. With a pasanger Im sure the bike was well over its wait limit. The transalp had no problems with it; although we bottomed out every time we blasted throug a wash on the dirt roads. (at least 10-20 times a day). I would of slowed down for the washes but with that wait the brakes didn't have the stopping power.
P.S. once I took the top bag off, the bike did do alot better in the sand
Most important mods for a Transalp. IMO.#1 BRAKES #2 Suspention
Old 02-27-2005, 12:06 PM   #807
seat_boy
Wannabe adventurer
seat_boy's Avatar
Oddometer: 156
valve adjustment problem
Hey gang,
I started to do a valve adjustment on my '90 TA this weekend. I stripped off the tank and bodywork, removed the radiators, and (about three hours later), I was ready to start.
Only... I can't remove the crankcase hole cover. This is the silver dollar sized (~35mm in diameter for the Europeans) plug on the left side of the engine. It has a slot for a 10mm allen wrench. The slots for the allen are starting to slip. Any suggestions?
Thanks,
Eric
Old 02-27-2005, 12:26 PM   #808
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,976
Eric,
Have you taken the large valve covers off the cylinder heads? If so, you can adjust the valves without looking at the timing marks (so you don't HAVE TO remove the plug in the side case. Just watch the cam lobes. You can adjust when the rocker is anywhere on the lowest side of the cam. Piston doesn't have to be at TDC.
If you haven't removed the large covers and are adjusting through the smaller access covers you can still find TDC. Open the intake side adjustment cover, put the bike in gear. Push the bike (helps to have the plugs removed) or spin the back wheel if the bike is on a stand. Watch the intake rocker push down the intake valves so your sure that piston is on the intake stroke.
Now insert a clean screwdriver or small rod of some kind into the sparkplug hole until you feel the top of the piston. Keep turning the back wheel until the piston comes up to the highest point...that's Compression TDC. Adjust valves.
You might have to do this a few times to get the "feel" right.
Do the same to the other cylinder and you get the valve adjustment done. You can then happily strip out the soft aluminum side cover and fix it later. I've pretty much given up on mine.
The only thing "magic" about TDC is that is lets you adjust both intake and exhaust at the same time. If you can see the cams you can adjust intake and exhaust seperately just by doing it on the lowest part of the cam.
Ray(who also wants a centerstand)Stedronsky
Davis,CA
Ladder106 is offline   Reply With Quote
Old 02-27-2005, 03:36 PM   #809
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,730
They looked wider than stock in the pic. I'm going to order some different wider aftermarket pegs for different model XR's till I find some that will bolt on to the TA's.
Old 02-27-2005, 05:22 PM   #810
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,464
rob_erto's right, there just the stockers. What about the company (I dont know what thier name is)that sells a piece of peg that you can weld on to make the peg about twice as wide.
Times are GMT -7.   It's 08:35 AM.
