03-01-2005, 11:57 PM
#841 |
It's a short cut, really
Oddometer: 4,268
TA clutch kit
Looks like the TA will be needed a clutch soon. Does anyone make a clutch kit fot his bike??
Ray(stuff keeps wearing out)Stedronsky Davis, CA |
03-02-2005, 05:20 AM
#842 | |
TAT survivor
Oddometer: 4,441
1998 RMX 250 singletrack bike 96 XR600 adventure bike KY state Vet A offroad champion TAT and TWVT survivor |
03-02-2005, 07:21 AM
#843 |
Oddometer: 4,268
TA suspention mods
Right....
Our problems were different. At present, I just wanted to find an inexpensive way to get the ride height back where it should be. I understand you (Jeff) have to compensate for the major boost in height and travel you got on the front end. Would shortening the "wishbone" link between the rock assembly and frame accomplish the same thing as making the shock longer? Seem like it. That would also increase the rate that the suspension "ramps up" the spring rate though....at least if I've thought this through correctly. Looking forward to seeing you extension piece Ray Stedronsky Davis, CA |
03-02-2005, 07:27 AM
#844 |
TAT survivor
Oddometer: 4,441
It probally would but it would also throw off the rising rate geometery and make it handle funny. The simple piece I'm having made extends the distance between the shock shaft and clevis just like haveing a longer shock made. This way the geometry stays the same as stock.
03-02-2005, 09:55 AM
#845 |
TAT survivor
Oddometer: 4,441
SCORE!!!!!!
The first set of footpegs I ordered worked like a charm! All I had to do was drill out the mounting hole in the TA mount to accept a bigger pin (which I found at a hardware store ) of the footpeg and grind a little off the footpeg seat and it bolted right up. These are the IMS Pro-4 pegs and are top of the line. Much wider than stock and have nice sharp cleets. These retail for $95 but I bought them on clearance sale for $50. I have 3 pairs left if anyone wants a set. I sell them to you for what I have in them plus shipping. Here you can see the section where I had to grind away a slight amount of material so that the peg would sit flat. I did this with my dremel. I drilled out the hole with a 13/32 bit. ![]() The pins that I bought where a little long so I used an alum spacer to take up the gap. I could have looked harder to find a shorter pin but I was in a hurry. All mounted up and added a little chrome bling too! ![]() ![]()
03-02-2005, 11:10 AM
#846 |
BOOMSHANKA!
Oddometer: 3,570
Jeff,
I really like those pegs, but it'd be nice to find something that is a total bolt-up. Going back to stock pegs (not that you'd want to) would require a little work now. Again, I really like the pegs... I'm still going to check into some others. There's got to be a set (made for another bike) that uses the same bolt holes and bracket angles right?
~Michael (of The Land of Misfit Land Rovers) Used to have an Africa Twin and Transalp X-Files Gov't Issue Sprinter TurboDiesel ![]() Washougal, WA USA |
03-02-2005, 11:21 AM
#847 |
TAT survivor
Oddometer: 4,441
Probally not, seems you can only get aftermarket pegs for true offroad bikes and they will most likely all have the stronger pins. The stock TA pins are tiny and would break under hard offroad abuse.
The grinding I did was very little.
03-02-2005, 01:42 PM
#848 |
Oddometer: 137
More specific..
Jeff,
Where specifically is the 25mm spacer inserted in the assembly? Thanks, Craig
Craig '90 Honda Transalp Red '93 Honda XR650L |
03-02-2005, 02:58 PM
#849 | |
TAT survivor
Oddometer: 4,441
03-02-2005, 04:59 PM
#850 |
TAT survivor
Oddometer: 4,441
Ok, now starts the beginning of the Africa Twin conversion. First is this Africa Twin RD04 swingarm that I won on Ebay for $7 plus $35 freight.
You can see in this pic that the AT swingarm is quite a bit longer and made of aluminum instead of stamped steel. ![]() All the mounts are exactly the same, the only difference is that the AT swingarm is longer and it has a tab for a disc brake instead of a drum brake. ![]() No worries, the dremel comes to the rescue again. With a little grinding work, the drum brake slides right in to the disc brake bracket tab. This is only temporary till I can find an Africa Twin or Transalp rear wheel with disc. ![]() The TA axle is a little long so I used 2 oversize nuts to take up the slack till I can find an AT axle. ![]() All that I need to do to make the brake arm reach is index the drum lever foreward 2 splines and it will just fit. I will hook the return spring to one of the screws for the brake cable holder on top of the swingarm. ![]() Linkage will bolt up but you need the bolt that attaches the linkage to the swingarm from the AT as it is a special bolt. Oh ya, and don't for get to order a longer chain! I bought a DID 525V o-ring with 140 links and cut it down to the right length.
1998 RMX 250 singletrack bike 96 XR600 adventure bike KY state Vet A offroad champion TAT and TWVT survivor Jeff@TheQuadShop screwed with this post 03-02-2005 at 05:25 PM |
03-02-2005, 09:25 PM
#851 |
greetings from Wa state
Oddometer: 4,096
jeff your a wizard, damn fine score on the AT swingarm, the TA is a light duty thing. cool pegs too, I have found some bikes going with bigger pegs, the added space was on the forward part of the peg, ( this wason a KLR650) made it real hard to shift. the TA I had a problem with my right heel hittin the exaust, same problem with my DL650. great job, put this instruction on a CD & sell it
“I would rather wake up in the middle of nowhere than in any city on earth.” .....Steve McQueen |
03-02-2005, 09:27 PM
#852 | |
Oddometer: 4,096
Try barnett or honda
03-02-2005, 11:56 PM
#853 |
BOOMSHANKA!
Oddometer: 3,570
Jeff... well done. Nice to see the @T stuff going on. I was told the early @T would fit right up (this must be what you've got), but the later would require a lot more work to fit.
Can't wait for the tank and cowls... an Africa Twin is such a beautiful thing. One of the best looking bikes ever made.
03-03-2005, 05:28 AM
#854 | |
TAT survivor
Oddometer: 4,441
03-03-2005, 05:31 AM
#855 | |
TAT survivor
Oddometer: 4,441
