Old 06-23-2011, 07:03 PM   #11611
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 462
M.A.P. Engineering (Jim Rowley) looks to be still selling the adapter.
http://www.map-engineering.com/prodd...a9031104ac0c79
I think he may have actually developed it first and he is an inmate here.
Should be relatively inexpensive to ship the lightweight aluminum piece to the UK and find a used Hawk rotor in the UK. I'm sure Jim can provide exact details of what to look for.
The disc upgrade and SS braided lines made a noticeable difference on my TA.
Dale
89 Transalp
01 XR400R
http://daleeva.smugmug.com/Motorcycle
wdeTA is offline   Reply With Quote
Old 06-24-2011, 12:51 AM   #11612
malkmus13
Oddometer: 15
ok, forgive my ignorance, but what is the "hawk rotor"? do i need to buy a new caliper? where do i get a "hawk rotor"? and where can i get the right braided lines?
ok.. i have just realised that a hawk is called an NTV "Revere" in the UK, so... can someone tell me what size rotor I need? And from what year Hawk? (they had different rotors, depending on the model year)
thanks all
malkmus13 screwed with this post 06-24-2011 at 01:04 AM
malkmus13 is offline   Reply With Quote
Old 06-24-2011, 01:30 AM   #11613
ravelv
from Baltic side of river
Oddometer: 444
Depends which model year you have... If something starting from 1991, when front brake was upgraded and caliper bracket bolt holes are 117mm apart, simpler would be to user SLR650 caliper and any 296mm honda rotor... Look back for my posts here about this.
Originally Posted by malkmus13 View Post
hi, i have a single-disc 600 transalp and would like to make the front brake better
can anyone recommend a decent disc/pads?
what about these??
http://cgi.ebay.com/ebaymotors/ws/eB...m=200555891385
also... can anyone recommend a braided hose kit? where could i get one
(i am in the UK)
thanks all
ravelv is offline   Reply With Quote
Old 06-24-2011, 03:07 AM   #11614
malkmus13
Oddometer: 15
its a XL600 VK model
Old 06-24-2011, 08:13 AM   #11615
mas335
xendurist
Oddometer: 1,974
year?
Transalps
mas335 is offline   Reply With Quote
Old 06-24-2011, 04:14 PM   #11616
trex300
trex300's Avatar
Oddometer: 82
Originally Posted by Welshman in Canada View Post
Yes,they worked fine and they were sold to me for $120 US each,no idea what the price would be up here.The dealer looked it up as a US model '89
So the ones I'm looking at on Ebay should work for me.
And ordered.
Thank you very much for this info,
you guys are the best,
Rick
Toys:
'08 Honda XL1000V
'09 Kawasaki KX250F
trex300 is offline   Reply With Quote
Old 06-25-2011, 06:14 AM   #11617
malkmus13
Oddometer: 15
sorry, its an XL600 VK. 1990 model. in red/white
malkmus13 screwed with this post 06-25-2011 at 08:01 AM
Old 06-25-2011, 06:25 AM   #11618
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,984
Wow one of the really OLD ones!
Steampunk anyone?
Ladder106 is offline   Reply With Quote
Old 06-25-2011, 12:55 PM   #11619
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 462
thanks all
The Hawk Rotor is just the front disk from a Honda Hawk. Unfortunately there is no identifying info stamped on mine and I got the whole thing as a package deal. I would just advise emailing or PM ing Jim Rowley at MAP engineering before ordering the caliper adapter and he can tell you exactly what part/year/size you need to look for. You don't need a new caliper, the adapter just moves the existing caliper outwards to accomodate the larger diameter disc from the Hawk (larger diameter means better stopping power apparently).
As for the braided lines, there are several manufactures and I don't know what is easier for you to access there, but all you really need is the right length with the correct fittings fittings on each end. The TA originally has rubber hose connecting to fixed steel tubing and back to rubber hose. You can replace the whole thing with a single braided line of the right total length (mine appears to be approx. 46 inches long incl. fittings). Just make sure to route it so nothing pinches and secure it appropriately with clips or zip ties. Any good bike shop that carries braided line should be able to help you out.
The adapter/rotor upgrade can be done independently from the brake line upgrade.
Dale
89 Transalp
01 XR400R
Old 06-25-2011, 03:24 PM   #11620
showkey
Oddometer: 1,934
Not to over complicate this Honda did use the name Hawk on many bikes.........
The Hawk you what the rotor from is the NT650 and Europe it has a diffferent name.
That same rotor is use on several other bikes I believe the St1100 uses the same rotor and it "bolts right up"....best way to determine the cross reference on the NT650 rotor is check on an aftermarket brake site and you will see they use the same rotor part # on several bikes. The Honda part numbers does not show a croos reference interchange.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 06-25-2011, 05:16 PM   #11621
Dudley
Dudley's Avatar
Oddometer: 872
Tire advice
What works for your Transalps for gravel, asphalt and everything in between. I'm researching tires for my James Bay, Goose Bay trip this Sept.
I have a set of Avon Gripsters mounted now and they worked great for 5000 miles of 99% pavement.
I'm thinking of TKC 80s, another set of Gripsters or others that have been advised. Tourances, distanzias and I enen thought of mounting another set of D606s but the ride and noise would drive me up the wall.
I figure I'll ride 6500 miles with about 1500 miles of gravel and in Sept rain.
Dudley
What ever happened to Roberta Claypool?
1996 Triumph Trophy 900
1989 Honda Transalp
2010 KTM 690 Duke
Dudley is offline   Reply With Quote
Old 06-25-2011, 05:31 PM   #11622
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,552
If jim Rowley doesn't have any of his rotors available, EBC, a British company, also makes a high quality, full-floating rotor for the Honda NT650 Hawk that should work with the adapter bracket Jim designed.
Help Stop McNugget Rage
WeeBee is offline   Reply With Quote
Old 06-26-2011, 12:08 AM   #11623
willows
Oddometer: 300
anyone interested in a TA
Gooday, have put my 650 TA up for sale in Australia. Here's a link to the ad.
http://www.bikesales.com.au/all-bikes/private/details.aspx?Cr=2&R=10450197&keywords=&trecs=16&__Ns=p_IsPoa_Int32|0||p_RankSort_Int32|1||p_HasPho tos_Int32|1||p_Make_String|0||p_Model_String|0||p_ YearMade_Int32|1||p_PriceSort_Decimal|1||p_PhotoCo unt_Int32|1&__sid=130A8D9518E0&__Nne=15&__Qpb=1&seot=1&__N=1432 604 1429 1626 1428 4294967259 4294958003&silo=1400
2005 KLR650
willows is offline   Reply With Quote
Old 06-26-2011, 01:46 AM   #11624
malkmus13
Oddometer: 15
Thanks all. MAP engineering is getting me the adapter thing and also a used Hawk rotor. for $60 - A brand new Hawk rotor in the UK is $270.
I am looking forward to being able to stop the bike without giving myself a hernia pulling on the brake lever!
Old 06-26-2011, 05:09 AM   #11625
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,878
Dudley
I have Tourances on mine and like them on both pavement and gravel. They should be able to handle the mileage and the weather.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Times are GMT -7.   It's 05:57 AM.
