Old 08-03-2011, 09:17 PM   #11851
trex300
trex300's Avatar
Oddometer: 82
Originally Posted by ferretface View Post
Has anyone found a headlight protector for the early Transalp square headlight model?
I'm after a metal frame type similar to that available for AT's and later model TA's.
I attempted to make one from a wire grill but it ain't the same as a proper one
Cheers
Dan
I used a 3M product designed for protecting headlights and is 1/8" thick, clear plastic with adhesive on one side, just cut it to shape and stuck it on.
Rick
Toys:
'08 Honda XL1000V
'09 Kawasaki KX250F
trex300 is offline   Reply With Quote
Old 08-04-2011, 11:21 AM   #11852
showkey
Oddometer: 1,901
Originally Posted by trex300 View Post
School me on the TA's pulse generators...
My '87 TA runs on the rear cylinder only once the motor gets up to operating temp. (FRUSTRATING when you're trying to commute to work!!!)When cold it runs great.
I have narrowed down a fault with the front cylinder's pulse generator. Reads normal when cold, but has no reading when hot (when running on the one cylinder). Rear cylinder reads between 360 and 540 Ohms and is within specs.
Both CDIs are new and coils check out fine too.
So is there anything I can do to fix the pulse generator or is it a matter of replacing it???
Just when I fix one issue another seems to pop up, hopefully by the end of the summer it'll be stone cold reliable again.
Eagerly awaiting your responses,
Rick
The only thing you could repair would be a loose or damaged connection or wire lead. The pulser coils have no repair. I suppose if the part became unavailable one could rewind the coil.
This a very uncommon part too fail, but if one were to fail, you might expect it to be heat sensitive. They come as set price in the US about $100.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey screwed with this post 08-04-2011 at 03:39 PM
showkey is offline   Reply With Quote
Old 08-04-2011, 11:36 AM   #11853
Olirider
Olirider's Avatar
Oddometer: 452
Originally Posted by pdxthmper View Post
THIS picture needs a lot more details, what all did he do to it and to carry what? he defiently had the ADV part down.
Well that was a LONG time ago during Transalp Rallye 1989 from Strasbourg, France to Porto, Portugal.
This Swedish guy and his girl friend were touring across all countries along the shores of Mediterranean Sea when they heard about the Rallye and joined.
This was his bike preparation for a 6 months 2 up adventure tour. If I remember well there was a drinking water tank and a gas tank at the back between the panniers.
The nick name of the bike was panzer bike !
Olirider is offline   Reply With Quote
Old 08-04-2011, 06:42 PM   #11854
trex300
trex300's Avatar
Oddometer: 82
Thankyou showkey for the fast reply. Honda Canada can't get one until October and Honda USA shows the pulse generators for an '89 being bolted on with a 6mm bolt, my '87 has 10mm bolt heads. Don't look the same, weird.
Anybody know if these will interchange? 1989 parts into an '87 motor???
Has anyone had a failure like this before???
Anybody with a pair of pulse generators they'll part with?
Cheers,
Rick
Is my riding season over?
Toys:
'08 Honda XL1000V
'09 Kawasaki KX250F
trex300 screwed with this post 08-04-2011 at 09:33 PM
Old 08-04-2011, 08:57 PM   #11855
Nightrunner
Oddometer: 2,189
Cheers
Dan
Yes, there is one that fits perfectly. Unfortunately I can't point you a vendor. In the late 90's I bought a pair of generic rectangular wire mesh headlight guards for my pickup. They were like $10 from JC Whitney. Well they didn't fit and it was not worth the trouble for a refund so I tossed them on a shelf in the garage. Years later I buy my 89 TA. Turns out they are a perfect fit to cover the glass in the TA headlight. JCW does not list them anymore but I would assume that some 4-wheel-drive catalog would have something along those lines. I'd post a pic but I don't have a pic hosting account. But check around the off-road truck accessories market and you'll find something I'm sure.
Scott
Some places remain unknown because no one has ever ventured forth. Others remain so because no one has ever come back.
Nightrunner is offline   Reply With Quote
Old 08-04-2011, 10:41 PM   #11856
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,536
Here are pics of the wire guard that Scott refers to above. The manufacturer appears to be called Powerflow but a Google search turns up no evidence they are still producing the protectors.
Formerly NorCalTA
WeeBee is offline   Reply With Quote
Old 08-05-2011, 01:29 AM   #11857
Nightrunner
Oddometer: 2,189
A web search turned up the company (Powerflow), but they only sell mud flaps now. The packing says they were made in China so maybe another firm is importing them. They are called "stoneguards".
Thanks to Norcal for posting.
Scott
Old 08-05-2011, 10:23 AM   #11858
showkey
Oddometer: 1,901
Cheers,
Rick
I think there maybe a confusion on the bolt size "nomenclature".
The 1989 each pulser are held on by two 6MM thread size with 10MM head size bolts.
Part # for the pulser bolts is 95701-06020-00 (6x20) generic flange bolt quan 4.
I do not have 1987 shop manual or parts book to compare. You should recheck that. Since they share the CDI box it's very possible they are the same pulsers.
These are NOT fast moving parts in the US and there are very few available, so this is a very rare failure.
There maybe other pulsers that are the same but have different part # because the leads or connectors are different size shape or length.
NT650 pulsers look the same different part # and are discontinued.
showkey screwed with this post 08-05-2011 at 02:52 PM
Old 08-05-2011, 11:06 AM   #11859
whipit1k
Oddometer: 313
Originally Posted by whipit1k View Post
transalp fans will want to see this. F off, board nazis
http://www.govdeals.com/index.cfm?fa...10&acctid=2715
somebody got a great deal. anyone here by any chance?
whipit1k is offline   Reply With Quote
Old 08-05-2011, 11:29 AM   #11860
showkey
Oddometer: 1,901
Only if the GOV sale supplies a clean title other wise a good deal on a parts bike
Old 08-05-2011, 01:32 PM   #11861
ChrisUK
ChrisUK's Avatar
Oddometer: 588
Fuel tap thread question: PD06 Transalp/ RD04 Africa Twin
Hi guys
Hope someone can help. Without going into the whole story, I’m looking to replace my 1987 Pd06 Transalp fuel tap from the oem one with the stupid (IMHO) vacuum hose attachment (that magically turns the fuel off when it wants to… not when I want to, and hence my bike stops when I don’t want it to…) to one that has no vacuum feed from the cylinder head, just gravity.
FWIW, I believe the RD04 Africa Twin fuel tap has the same thread, although it only has on/off, but no reserve.
I have a Transalp oem fuel tap in front of me. My veneer caliper tells me the thread is 12mm. Great, I think to myself… But after a very brief search on Google, it appears there are 1mm, 1.25mm and 1.5mm (and possibly more) pitch 12mm threads on after market fuel taps. My veneer caliper doesn’t fit in the “nut” hole of the fuel tap to measure the pitch.
However I don’t have the bike handy. (It’s in Estonia (I’m in England) and I’m flying there in 7 days to do a trip to North Cape in Norway). So I can’t measure the pitch of the thread on the tank that the tap screws onto.
Can anyone help with the thread size/pitch I need to buy?
I really appreciate a quick reply. Many thanks in advance.
Cheers
Chris
ChrisUK is offline   Reply With Quote
Old 08-05-2011, 02:06 PM   #11862
mas335
xendurist
Oddometer: 1,959
[QUOTE=ChrisUK;16560371] Hi guys
Chris,
Don't make this a bigger task than it need be, your current petcock system simply has a vacuum leak, more than likely it is the hose running to the rear cylinder. It could also be a damaged (cracked) brass vacuum port on the rear cylinder or a leak on the petcock itself although that is unlikely. I have seen these brass fittings crack off at their base leaving the threaded portion in the cylinder head, not a easy situation to resolve.
If you are still determined to do away with the vacuum feature then take the petcock apart, move the coil spring to the opposite side of the diaphragm and it will hold the petcock in a "opened" position all the time. You will want to cut off the valve when not in use just as a precautionary measure. Do this and you will still retain your reserve feature.
That's all there is to it.
Transalps
mas335 is offline   Reply With Quote
Old 08-05-2011, 02:24 PM   #11863
mas335
xendurist
Oddometer: 1,959
To the buyer: if you decide to part it out contact me, Thanks
Transalps
Old 08-05-2011, 02:31 PM   #11864
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,251
Rick
http://www.aerostich.com/14-mil-headlight-shield.html
here are sheets of it. heat it w/ hair dryer for curved surfaces
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 08-05-2011, 03:19 PM   #11865
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,957
Chris,
I have fitted a XR250 petcock onto the Transalp tank (PD06) and also fitted this same petcock onto an RD04 tank. I would conclude, therefore, that the standard RD04 valve will fit the TA tank since the diameter and thread pitch will be identical.
I like manual fuel valves too.
Ladder106 is offline   Reply With Quote
Times are GMT -7.   It's 05:34 AM.
