Old 10-25-2011, 05:44 PM   #12421
drivefastandswerve
Indianapolis
drivefastandswerve's Avatar
Oddometer: 154
Puke Deals Gap area, Oct 2011
Beautiful 4-day weekend! Just wanted to stop every 4 feet and take another photo!
Announcement!!
Early 2012, keep an eye out for a Transalp "get together" at IronHorse motorcycle Lodge, Stecoah, NC.
John, the owner, has a 89 transalp, and wants to get this together, early in 2012, around April - June time frame.
- chuck
- chuck
There really is no such thing as a 5 minute job!
1989 Honda Transalp (Gotta get it dirtier!)
2000 BMW R1100RT (Iron Butt Qualified)
1993 Honda XR250L (Great woods bike)
Misc mini-bikes (71 Honda Z50, 75 Honda XL70, 73 CT70, 79 XR80)
1973 Suzuki TM125 (vintage racer)
1974 Suzuki TM100 (Racer, when it's repaired!)
Misc motorcycle crap from many swapmeets!
drivefastandswerve is offline   Reply With Quote
Old 10-25-2011, 07:39 PM   #12422
showkey
Oddometer: 1,955
Originally Posted by Bronco638 View Post
Shoot, I should be able to get another month in here in Chicago (I hope).
On another note, the NX125 bars do not seem to want to easily bend back. I may need to remove them and check to see what's actually bent.
Three foot pipe is tool of choice
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 10-26-2011, 06:31 AM   #12423
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
Ah, I wasn't applying enough leverage. Thanks.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 10-26-2011, 06:38 AM   #12424
pdxthmper
pdxthmper's Avatar
Oddometer: 408
I don't know if you have tried to just twist them back, hold the ft wheel with your knees and twist the bars, that may straighten them back so they line up.
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is offline   Reply With Quote
Old 10-26-2011, 08:41 AM   #12425
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,000
You might want to determine exactly WHAT is out of alignment here before you start applying pressure to anything.
If it's the handlebars, they can be removed, set on a flat surface and with a bit of manipulation you can discover if the bend is actually in the bars.
If the NX has rubber mounts on the top triple clamp (like the TA) you can remove the bar and mount up a piece of white PVC pipe. It's cheap and usually pretty straight. Then take another look like you did in your first photo to see of the pipe is in line with the for caps....or not.
If the problem is with the mounts, loosen the bolts underneath and straighten...or add the aluminum plugs that Mr. Rowley has to replace them with something solid.
I'd guess the NX doesn't vibrate too badly, even with solidly mounted bars.
Ladder106 is online now   Reply With Quote
Old 10-26-2011, 06:37 PM   #12426
dutton
Oddometer: 17
Question Question
wondering..... 6'4" 245lbs transalp to small?
dutton is offline   Reply With Quote
Old 10-26-2011, 06:53 PM   #12427
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,513
nope
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 10-26-2011, 06:57 PM   #12428
quint7
I don't need a title
Oddometer: 483
6'3", 285, 34in inseam, freakishly long arms. TA with stock bars, Corbin fits perfectly other than while standing (bars a little too low unless you are really leaning into the tank). Get a taller windscreen.
Semper Fi & YAT-YAS!
quint7 is offline   Reply With Quote
Old 10-26-2011, 07:32 PM   #12429
dutton
Oddometer: 17
Thinking about selling the buellxb12x and trying a 1990 transalp...
Old 10-27-2011, 05:46 AM   #12430
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
remember it's a 400 pound bike with 50 hp so dont expect a rocket ship. For back roads and riding around town i prefer it to the faster heavier bikes
MookieBlaylock is offline   Reply With Quote
Old 10-27-2011, 06:31 AM   #12431
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
I tried it with the forks turned full right and pushed against the left grip like Mr. Rowley suggested. That didn't do much (if anything).
Yes, I plan to investigate further this weekend. I suspect the bars are twisted but I also need to look at the mounts. I did not know that Jim makes aluminum plugs to replace the rubber ones. Hopefully the ones for the TA are the same for the NX. An on-line parts fiche should solve that riddle. Thanks.
Old 10-27-2011, 08:09 AM   #12432
Kamala
Kamala's Avatar
Oddometer: 12,786
Originally Posted by Dudley View Post
Time to put the bikes away till Spring. Today the Transalp got a bath, oil and filter change and a general check over.
I might be in the same situation. The forecast is for snow tonight and if they put salt or chemicals on the road its hibernation time. She got the bath yesterday and I'm about to change the oil, filters and plugs and give it a once over. If I'm lucky the town will plan of the residual heat in the roads to combat the snow and I can get another month or more before she gets pushed into the corner of the shop. Where's Global Warming when you need it!
I survived the Great Folk Music Scare of the 1960s (when it almost caught on) !
Kamala is offline   Reply With Quote
Old 10-27-2011, 08:52 AM   #12433
tgeliot
Topher
Oddometer: 1,357
6'2", 34" inseam. Knees bent a little more than I would like, but that tells you more about my aging knees than it does about the TA. In fact, if you believe cycle-ergo.com, the TA is actually pretty good in this regard.
I agree with another poster who said that the standing position leaves a tall person a bit too bent over.
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 10-27-2011, 09:06 AM   #12434
Ladder106
Ladder106's Avatar
Oddometer: 5,000
Tall guy fix
OK, this mod is a bit "extensive"
But if you're a tall guy, it's well worth the cost and time. It takes some fabrication and welding.
Lower the pegs !!
This does two things that will make you smile:
(A) Drops your feet and relieves the angle of your knees when sitting
(B) Effectively raises the bars (without actually changing the bars or mounts) when standing.
Continually raising the bars is only part of the fix if you want to go in this direction. Because of the angle of the top triple clamp, raising the bars also keeps moving the bars further toward you......not what you want.
If you only want to raise the bars, I'd suggest RoxRisers or something that will also allow movement forward.
Higher bars when standing are uncomfortable if they are shoved into your waist.
Here are some finished photos of my mod:
Old 10-27-2011, 09:56 AM   #12435
O'Hooligan
Ken Dodd's dads dogs dead
O'Hooligan's Avatar
Oddometer: 634
I don't have a shop manual, does anyone know what the stock gearing (# of teeth on each sprocket) is and how many chain links are on a 2001 650 Transalp?
O'Hooligan is offline   Reply With Quote
Times are GMT -7.   It's 10:26 PM.
