Old 12-31-2011, 01:23 PM   #12661
quint7
I don't need a title
Oddometer: 483
Originally Posted by mas335 View Post
Are you sure your return cable is not running under and/or behind the white nylon guide block in the throttle control? This will prevent the throttle action from working right and make the return cable have lots of drag becasue the cable is being pinched.
Getting these cable wires routing misaligned in the throttle control is easy to do and a bit tricky to get them where they belong while trying to assembly the two control body shells.
I've been trying to figure that one out. Seems like a poor design, but my last name isn't Honda. LOL I should check to see if that is available too. 50000+ miles is a lot of wear on a nylon part. I might mess with it some more, but a new throttle is in order... mine looks like it came from a bombed out factory.
Semper Fi & YAT-YAS!
quint7 is offline   Reply With Quote
Old 12-31-2011, 01:50 PM   #12662
mas335
xendurist
Oddometer: 2,016
I have never seen these guides to show much if any wear, all they do is direct the throttle cables. Just be careful when you install the cables in the new control.
What I have seen is glue piled up inside the control house body from the over use of glue when installing the hand grip.
I use hair spray, no glue, makes replacing them a lot easier and no mess.
Transalps
mas335 is offline   Reply With Quote
Old 12-31-2011, 01:55 PM   #12663
quint7
Oddometer: 483
Thanks Mark. I've never used anything but spit to mount grips. Just a wee bit, leave em out in the sun after mounting..... never got the whole grip glue thing. I'll do some more cleaning. Hoping to take the TA to Death Valley in early Feb.
Old 12-31-2011, 03:26 PM   #12664
ric678
ric678's Avatar
Oddometer: 866
too tall?
seeking the wisdom of the Alpers
My new to me 89 Alp has XR650 not sure on the R or L forks and the rear shock spacer mod done to it.
But it is very tall, I'm 6 1 with a 34" inseam and I can only tip toe it. Would just raising the forks a bit in the clamps cause any weird handling problems??
ric678 is offline   Reply With Quote
Old 12-31-2011, 03:43 PM   #12665
Backonthebike
Giddy up
Backonthebike's Avatar
Oddometer: 675
Raising the forks in your clamps will have the effect of slightly reducing your 'trail'; i.e the difference between the contact patch of the tyre and the prolongation of the centre axis of the forks to the road surface.
It will make your steering a teeny bit quicker, but shouldn't lead to stability problems at the speeds the TA is capable of, however the greater trail is a benefit in loose sandy conditions. Depends what you use the bike for.
Either raising the rear or dropping the front was a way we would adjust race bikes in the old days to suit tighter circuits.
Cheers
Tim
Backonthebike is offline   Reply With Quote
Old 12-31-2011, 03:46 PM   #12666
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,563
SPIT HUH , great idea , that does work good for lube ,
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 12-31-2011, 05:02 PM   #12667
pdxthmper
pdxthmper's Avatar
Oddometer: 427
Another option would be to shorten the forks and the rear adaptor. A simple tube spacer in each fork will shorten them, you could even remove the rear spacer if you wanted stock height.
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is offline   Reply With Quote
Old 12-31-2011, 05:26 PM   #12668
quint7
Oddometer: 483
Just not too much!
Old 12-31-2011, 09:50 PM   #12669
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,583
Happy New Year!
Here's wishing our fellow Transalp owners around the world a Happy New Year!
Help Stop McNugget Rage
WeeBee is offline   Reply With Quote
Old 12-31-2011, 09:53 PM   #12670
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,563
Same , Same Same ,,, Back at all yall.
Marko
Old 01-01-2012, 06:10 AM   #12671
BOBaloo22
RIP Baby Girl
BOBaloo22's Avatar
Oddometer: 3,791
Happy New Year Everyone!!!!!!!!!
89 Transalp-98 FXDWG
AMA member
BOBaloo22 is offline   Reply With Quote
Old 01-01-2012, 12:12 PM   #12672
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,597
Happy New Year!
Carlos locorider
From Puerto Rico to Georgia and beyond...
locorider is online now   Reply With Quote
Old 01-01-2012, 12:38 PM   #12673
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,103
Only if the front fender/wheel/tire doesn't contact the frame/crashbars/any other hard parts on full compression.
If it does it will cause very wierd handling problems and also give you the opportunity to see if you can fly.
Ladder106 is offline   Reply With Quote
Old 01-01-2012, 12:40 PM   #12674
ric678
ric678's Avatar
Oddometer: 866
flying
Well yea, gonna try to avoid the flying part, I think I'll try lowering things a bit, If I still don't like it I can always swap the stock stuff back in
Old 01-01-2012, 07:17 PM   #12675
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Originally Posted by dualdogdave View Post
Happy Holidays
Fellow
Transalpians
Wishing all many happy
and safe adventures.
Still Lurking Around
Thanks Dave, you too.... Don't own a TA or a TA/NT/AT but recognize a large step towards motorcycling excellence. See you around , Jeremy
rotten is offline   Reply With Quote
Times are GMT -7.   It's 07:01 AM.
