Old 02-05-2012, 08:42 AM   #12856
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,490
Originally Posted by radguzzi View Post
Thomas,
Drill and tap a 1/4-20 threaded hole and pull it out with a suitable bolt and puller. Or drive it in a bit...
Best,
Rob
Edit: Ooops, noticed that you are in Oz, in that case drill and tap a 6MM...
Originally Posted by showkey View Post
Look at the HONDA shop manual.....not sure on 2006 TA but other Honda's are usually held in place by clips that must be released (from the end of the bar) and then a 6mm bolt in the threaded end and they can be extract with ease.
Or , you can just put yourself on a nice new set of Renthal Hi-Bends .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 02-05-2012, 05:10 PM   #12857
mas335
xendurist
Oddometer: 1,967
Just read this posted by Baldy,
The mods are gonna announce that we're going to turn off image uploads to our server. You'll have to host your images somewhere to post. Reason being reading/writing the images just uses more disk I/O, slowing down database access to the disks. Also, going to more expensive solid-state disks means I don't want to fill them up with images.
I turned off image uploads in the past once, but since I own a photo sharing site I was accused of doing it because I'm a capitalist pig out to line my pockets at the expense of the little people.
Oh well, better to be an evil man who can keep his free forum up.
Transalps
mas335 is offline   Reply With Quote
Old 02-05-2012, 05:38 PM   #12858
radguzzi
The Journey is the Reward
radguzzi's Avatar
Oddometer: 5,694
You'll have to host your images somewhere to post...
I have always posted photos hosted off-site and I was dully repremanded by those faithful to SmugMug let me tell ya... Sheesh.
So where is this post from Baldy...?
Thanks,
Rob
________________________
Guzzis and Others...
Member: AMA - USCRA - MGNOC
radguzzi is offline   Reply With Quote
Old 02-05-2012, 07:26 PM   #12859
ThomasOz
ThomasOz's Avatar
Oddometer: 228
Thanks Showkey,
I've dugged further through the grip rubber to expose the handle bar end. Indeed, there are clips and some glued smeared all over.
[photo deleted]
The photo shows there is not threat in there, just a perfect metal cylinder. So I'll try to pull them out tonight, but might have to borrow a drill for this job.
Thomas
PS: yes, I do not owned a drill, I am an appartment dweller (and tenant to make matters worst). So apart from chopping wood and building guitar amps cabinets, I haven't had much DYI experience so far. Learning learning every day.
ThomasOz screwed with this post 02-06-2012 at 03:55 AM
ThomasOz is offline   Reply With Quote
Old 02-06-2012, 03:11 AM   #12860
mas335
xendurist
Oddometer: 1,967
Thanks,
Rob
Under Fluff, Ask Baldy, Baldy turns off a couple of features, post #24
It appears a hosting site will be required, I like the way I have been posting images but I guess that will end.
Transalps
Old 02-06-2012, 09:51 AM   #12861
pdxthmper
pdxthmper's Avatar
Oddometer: 391
Originally Posted by Hotmamaandme View Post
Uni Filter part #NU-4097 if u want the foam reusable air filter
When I installed this filter it did not make contact with the rubber ring in the air box, I had to add a 1/4 close cell foam ring to the filter, now I had a nice contact ring with the intake.
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is offline   Reply With Quote
Old 02-06-2012, 08:24 PM   #12862
ThomasOz
ThomasOz's Avatar
Oddometer: 228
SUCCESS!
Well almost, I have fitted the Ego Barkbusters on the Transalp (XL650V).
The only mod required to get them to fit perfectly, is to slightly shorten the brake and clush levers (by about 5mm).
I haven't done that yet, so the lever is not aligned with the aluminium bar, but it will before the week end.
Thank you people for your assistance. I'm really happy about this (as silly as it might seem).
Next is crashbars and when I have money, bashplate.
Thomas
Old 02-07-2012, 07:39 AM   #12863
Motoswami
Motoswami
Oddometer: 75
Going for the Hawk (NT650) engine transplant
Hi Inmates: I'm posting this because I hope others with this experience will chime in with any links to descriptions I may find useful. Just for background, last winter I purchased Jeff@TireBalls project "RallyAlp" from its next owner who only got to enjoy it for 300 miles before the rear piston mysteriously stopped doing its up and down thing. I'm finally just about ready to lift the engine out and take apart the rear cylinder assy to see how bad it is, but I don't expect I'll find very much left that's pretty. Since I suspicion that a proper fix would entail a full disassembly of the engine unit, and sourcing some rather expensive parts, and since I have a complete HawkGT to steal anything from it I need, my present plans are to use the Hawk engine, an RD03 exhaust header, and an assortment of RD03 cooling hoses/thermostat with TA radiators.
Inmate Luke has been kind enough to describe the pulser-related changes I'll need to make to use the TA CDI's and coils. Those changes alone seem like a bit of rigging to work through, but I'm sure that's not all I'll find as I get into the job.
Please feel free to PM me with any helpful advice. I am aware I'm not going to experience tons more power or any magic like that. I'm only using a Hawk engine because the one available to me is free and known to be good.
Thanks in advance
Pete
Motoswami is offline   Reply With Quote
Old 02-07-2012, 10:39 AM   #12864
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
Go See Santa
See if you can get Santa to assist with this. He completed a successful Hawk transplant a while back. Search this thread for particulars.
Also please document you work with photos. The Hawk conversion is something quite a few long-term TA owners may be looking at for riding into the next 10 years (As long as there's no logical replacement forthcoming)
Ladder106 is offline   Reply With Quote
Old 02-07-2012, 07:20 PM   #12865
kyjenkin
Squatchy
kyjenkin's Avatar
Oddometer: 55
continuing my side panels
I have been out of town for a week but here's where I got before I had to take a break:
I was trying to get a view of how close it is to the radiator, i.e. close!
I am showing how the fit isn't anywhere near perfect. But I never claimed to know what I was doing or that I have the experience to do it right the first time. I am learning as I go and will eventually change a few things in the near future but I like where this experiment is going!
I still need to make vents too and paint as well. I'm still in the forming phase!
kyjenkin is offline   Reply With Quote
Old 02-07-2012, 11:42 PM   #12866
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,058
Kyjenkin, I used 3mm thick Kydex for my panels. maybe easier to work with than 2 layers. Keep going, you can get them to fit perfectly.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert screwed with this post 02-09-2012 at 07:42 AM
Blackbert is offline   Reply With Quote
Old 02-08-2012, 09:56 AM   #12867
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,709
Those panels look like they have potential keep up the good work
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 02-09-2012, 06:28 PM   #12868
trex300
trex300's Avatar
Oddometer: 82
Blackbert what are you using for a skid plate in this picture?
Rick
Toys:
'08 Honda XL1000V
'09 Kawasaki KX250F
trex300 is offline   Reply With Quote
Old 02-09-2012, 09:50 PM   #12869
pdxthmper
pdxthmper's Avatar
Oddometer: 391
Delkevic Exhaust
So I am working on putting the Delkevic 14" oval exhaust on my 89 TA, the exhaust is nicely made, and for $110 shipped its hard to beat price wise. The can is 5 inches high and 4 inches wide. I had a mid pipe made at a local exhaust shop, in the end it cost about the same at using the gsxr kit, but I wanted the can to be in line with the seat with the tip pointed down some what to help with the noise, which is why I didn't use the kit. I haven't finished the install yet so I don't know how it sounds but here is how it will look.
XR 650"L"
Old 02-10-2012, 12:16 AM   #12870
ravelv
from Baltic side of river
Oddometer: 444
That's from XRV650. Quite hard to get one...
Rick
ravelv is offline   Reply With Quote
Times are GMT -7.   It's 04:57 AM.
