04-01-2012, 05:22 PM
#13051 |
Patent pending
Oddometer: 148
Thanks guys. I'll do the switch in a day or two and see what happens. Any advice on unhooking them? Are they clipped in or do I just gently pry them? I sure do not want to bust either of those 20 something years old connectors.
And, the big question is this — can I get a new one from Honda? |
04-01-2012, 07:55 PM
#13052 | |
Sleep, Wrench, Ride
Oddometer: 4,440
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 |
04-01-2012, 08:47 PM
#13053 |
It's a short cut, really
Oddometer: 4,258
There's a wire and graphite (I think) gasket between the head pipes and the standard Honda muffler. Usually it stays with the muffler when it's removed. It can be found as a Honda part.
Never had a SuperTrap but this may be necessary to have the pipe fit correctly. Trying to pry/slide the old gasket out of the standard silencer only ruins it. Order a new one. Have the new guy measure the outside of the standard Honda muffler where the clamp goes....then measure the outside of the ST pipe. If the two are the same, then the standard Honda gasket will work just fine. If not, those gaskets are available in various inner and outer diameters. A good parts guy (usually a contradiction in terms) can help you here. Ladder106 screwed with this post 04-01-2012 at 08:57 PM |
04-02-2012, 12:34 AM
#13054 | |
from Baltic side of river
Oddometer: 405
Connectors should unplug normally.
Regards CDI's- I don't see any point of buying new from Honda, they are outdated (spark advance is for 91 octane gas for example), not reliable. I strongly suggest to invest in these: http://www.motorbike-shop.de/index.php?a=2892 For example, these CDI decreased fuel consumption on my TA for about 0.8l/100km without changing anything else! Quote:
04-02-2012, 01:34 AM
#13055 |
Oddometer: 58
hi, where buy this screen ?
![]() I found in Boano, but it does not seem to be the same. Thx ! |
04-02-2012, 02:52 AM
#13056 | |
xendurist
Oddometer: 1,547
There are 2 thin clips on opposite sides of the outer connector. Find a small thin narrow tool so that you can barely 'lift' this clip allowing the inner connector pin can be 'wiggled' out. Both connectors attach in the same manner. Since your CDI's have the updated horizontal style holder then these clips will be on the top and bottom position. These connectors are often very snug due to the inner micro O ring seal, resist pulling on the wires, wiggling or "walking" the connector out works best. A very small amount of WD40 on this connector can really help. The "over rated" need for the updated horizontal CDI holder has little to no effect on the life of the CDI, they still go bad, especially if they are old. I have read comments that would lead you to think that if this update is not done immediately your ride will be cut short that day, just ain't so. Having said that it's a worth while $12.00 investment and should always be done. Removing the CDI's is like minor surgery but you can do it. Resist pulling in the connectors molded onto the CDI, you can damage the internal connection on the circuit board. I hope Graham is still enjoying the bike he got from me in December.
Transalps |
04-02-2012, 05:03 AM
#13057 |
Patent pending
Oddometer: 148
Thanks for the sound advice. I've dealt with enough of that type of clip over the years to know the older ones can be difficult to remove.
I'd love to invest in the $$$ unit but it's likely I will not have won the lottery by next week and therefore will opt for the standard unit. "I hope Graham is still enjoying the bike he got from me in December." — Yes, he loves it. I still have not seen it but I hope to meet up with him soon. |
04-02-2012, 05:11 AM
#13058 |
Oddometer: 405
$350/259 EUR is set of both CDI's (is the stock ones really much cheaper?)... Though, both of my stock CDI's where ok, I decided not to wait until they will fail. Also these CDI's allows to enable/disable sidestand switch and have possibility to work with both ignition settings- 91 and 95 fuel.
BTW, no matter how I was synhronizing carbs, I always had some noticeable vibration from engine on foot pegs around ~93 km/h. Just with using these CDI's this vibration went away. That was first surprise when went to highway (another was less fuel used). ravelv screwed with this post 04-02-2012 at 05:23 AM |
04-02-2012, 05:28 AM
#13059 | |
Patent pending
Oddometer: 148
I will be looking into all of this over the next few days. I'll report on my progress as I go. Thanks to all who advised. |
04-02-2012, 06:04 AM
#13060 | |
xendurist
Oddometer: 1,547
I did not know that price was for a pair, still expensive. I think you can find mail ordered OEM Honda CDI's for around $110.00-$120.00 ?, Not sure because I haven't needed them in a while.
The last CDI's I bought were made in Argentina and sold on Ebay, so far they work great and can not tell the difference, I think they cost $65.00 each? I think Ladder is also using these and has had great luck. Quote:
Transalps |
04-02-2012, 07:01 AM
#13061 | |
Oddometer: 405
OK, I forgot that in US you have a different prices that we here in EU... :)
Here OEM can be around 130EUR, so, no point to buy stock ones. Still you have to take in account also some additional functionality these delivers. In my opinion price is a bit steep, yes, but I'm not dissapointed as well. Quote:
04-02-2012, 10:32 AM
#13062 | |
Bald Adventurer
Oddometer: 3,695
Bob
89 Transalp-98 FXDWG AMA member |
04-02-2012, 04:37 PM
#13063 | |
Now what?
Oddometer: 2,249
04-02-2012, 08:54 PM
#13064 |
Topher
Oddometer: 1,328
Supertrapp gasket?
I looked at my bike, which has a Supertrapp, and frankly didn't know what to think. So I took pictures:
Topher 1989 Transalp. Sort of. I don't have a bucket list, I have a post-bucket list. So far it includes 1) Coroner's report is to read "Death by misadventure." 2) Dixieland jazz band at my funeral. |
04-02-2012, 10:04 PM
#13065 | |
CDIs
http://www.motorbike-shop.de/index.php?k=279 It seems they are also shipping to foreign countries, something like Euro 7, insured letter upto Euro 34. |
