Old 04-19-2012, 04:16 PM   #13156
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
Originally Posted by quint7 View Post
If it has to be on the right than that is the way it needs to be I guess. I'm a lefty who has always had left side center stands but function over form is most important I would say.
Yeah, it works but it is not my first choice either.
If there are anymore comments. It might be better to post it in my vendors thread.The thread is is at the bottom of this post.. No sense gumming up this thread.
Thanks,
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 04-19-2012, 04:19 PM   #13157
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,768
Originally Posted by Cigar Mike View Post
Still trying. Could you live with it on the right side?
Mike
I am willing to give it a try to get a Centerstand
dfc is offline   Reply With Quote
Old 04-19-2012, 04:37 PM   #13158
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,188
Will take one as well if you make it.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 04-19-2012, 05:03 PM   #13159
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,048
With 13,000 posts and counting I don't think gumming it up is remotely possible. Keep going! We get off on all kinda of tangents and a center-stand for the TA is something we've all been wishing for for 20 years so it's certainly relevant.
Ladder106 is offline   Reply With Quote
Old 04-19-2012, 05:57 PM   #13160
2old2Bbold
was 2bold2getold
Oddometer: 1,843
Originally Posted by mas335 View Post
I would be interested to know how much "slack" is in the oil pump chain before you remove it. If you can measure the chain slack travel I can compare it to other engines I have seen.
Once you install the new one a measurement of it would also be helpful.
Thanks,
That's what I was curious about. So here goes.
Looks like about a 1/4"... More than I expected. Ordered the new one this afternoon, will be a few days before it gets here. I'll post more pics and measure again when I get it installed. BTW had to get the wifie to help with the shots. My nails don't look that good.
2old2Bbold is offline   Reply With Quote
Old 04-19-2012, 10:25 PM   #13161
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,484
US Transalp Centerstand
I will go ahead with this design then. I will send the patterns over to the laser cutter and have them start cutting out the parts.
The only other way to put the press down leg on the left is to make a hinged leg. That would be a bigger pain then using the right side, IMO
I have only looked at the US models and have no idea what fits bikes in other countries. It appears that the European models had the centerstand brackets for a factory stand. I have no idea what Canada and Australia imports are and what years might be the same as the US import.
Once I start fabrication I will post that they are available.
Thanks,
Mike
Old 04-20-2012, 12:39 AM   #13162
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,188
Can anyone post up photos of the US version underneath where the mounts have to go so that we can compare?
My 87 is a Jap import 7 years ago.
xronly
Old 04-20-2012, 06:19 AM   #13163
Ladder106
Ladder106's Avatar
Oddometer: 5,048
Transalp Porn
This is the best "under-the-skirts" shot I have (meant to show TA linkage with AT swingarm). Doesn't give you much of what you want. Mark can likely do better
Old 04-20-2012, 08:02 AM   #13164
mas335
xendurist
Oddometer: 2,003
I'm not clear on what you are asking. Do you want to know about the mounting location for the OEM factory equipped centerstand, I can do that. I made a template of the centerstand mounts that could be fabricated and then welding onto the frame for a OEM swingarm.
If you are asking about Mike's swingarm mounts then I can't help with that, have no idea.
The location for these centerstand mounts are kind of obvious, they are the only flat "ears" on either side of the frame at the shock link arm. I'll try to post a image later today.
Transalps
mas335 is offline   Reply With Quote
Old 04-20-2012, 10:45 AM   #13165
2old2Bbold
was 2bold2getold
Oddometer: 1,843
Here's a 1989 US California TA :
Got mine apart for service. Hope this helps.
Old 04-20-2012, 01:19 PM   #13166
tgeliot
Topher
Oddometer: 1,361
But there is that long walk around the bike to get to the right side.
Am I missing something or could one simply learn to get on and off on the right side?
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 04-20-2012, 01:25 PM   #13167
Ladder106
Ladder106's Avatar
Oddometer: 5,048
You could but it takes too much time. First you have to click your heels together three times, then recite the "Don't Fall Over" prayer for forgetting to put the side stand down (which is on the left BTW). Then you have to remember to engage your left brain and pull with your left hand. Then as you turn to walk away from your bike, you actually want into it.s
It will take a bit of brain re-wiring.....
Then you ride your other bike...look down and find.....yep, you shoulda got off on the other side.
It's a zen thing....so, if I have to expain it, you won't understand anyway.
Old 04-20-2012, 02:25 PM   #13168
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,484
I made the stand so it is out of the way for the longer oil filters. The bracket that holds the tubes on the left side near the chain will need to be removed and the tubes routed over and in front of the main cross tube and placed through a wire bracket that comes with the stand. You will loose a little more than 1/2" of ground clearance with the stand. Compared to the European model you loose 2/3 less ground clearance.
I am thinking that I will make the return (up position) higher about one inch. A little more ground clearance would be good and I can do this with the press down leg on the right side.
Mike
Cigar Mike screwed with this post 04-20-2012 at 02:51 PM
Old 04-20-2012, 02:35 PM   #13169
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,484
I always get off on the left side. Here is the procedure.
Forget you have a centerstand.
Get off the bike and place it on the side stand.
Remember you have a centerstand.
Walk all the way around to the right side and place the bike on the centerstand.
You can then reach over and retract the side stand. If you are too old or too short to reach over the bike. Walk all the way around and retract the side stand.
To take the bike off the centerstand.
Stand on the left side and push the bike forward off the stand. This can be done with the side stand retracted or deployed.
If this is too much trouble. Please don't order one.
Cheers,
Mike
Old 04-20-2012, 05:46 PM   #13170
Ladder106
Ladder106's Avatar
Oddometer: 5,048
Looks great, Mike
Any idea on pricing yet?
Times are GMT -7.   It's 01:11 AM.
