Old 04-20-2012, 05:52 PM   #13171
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,178
Thanks to everyone for the photos and explanation.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 04-20-2012, 06:19 PM   #13172
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
Originally Posted by Ladder106 View Post
Looks great, Mike
Any idea on pricing yet?
I will not for sure until I get the quote from the shop that does the laser cutting. Originally I figured it would be closer to $180 but if the laser cutter is reasonable it should be less. My target is $160.
Centerstands are one of those items that after you have it on you never really notice it. Hardly anyone will know you have one until you put the bike up on it. This is a good thing in that it usually doesn't detract from the good looks of the bike.
Thanks,
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 04-22-2012, 04:46 AM   #13173
mas335
xendurist
Oddometer: 1,998
Help! I need a right side (battery) cover in any color or damaged condition, I am having another bike repainted and can't bring myself to paint over a perfectly good white side cover.
Send me a pm please, thanks,
Transalps
mas335 is offline   Reply With Quote
Old 04-22-2012, 02:14 PM   #13174
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,705
PM sent
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 04-24-2012, 05:29 AM   #13175
mas335
xendurist
Oddometer: 1,998
Still looking, any condition, thanks ,
Transalps
Old 04-24-2012, 02:51 PM   #13176
BOBaloo22
RIP Baby Girl
BOBaloo22's Avatar
Oddometer: 3,789
Hello All, Can anyone give me the torque specs in inches or ft pounds for both axles and the pinch bolts on the front.
Thanks,
89 Transalp-98 FXDWG
AMA member
BOBaloo22 is offline   Reply With Quote
Old 04-24-2012, 03:05 PM   #13177
mas335
xendurist
Oddometer: 1,998
Thanks,
Pretty sure they are 69ft. lbs. rear axle, 47 ft. lbs. front axle and 9 ft lbs for the 4 pinch bolts. I'll double check and if I'm wrong I'll let you know.
Transalps
Old 04-24-2012, 04:58 PM   #13178
BOBaloo22
RIP Baby Girl
BOBaloo22's Avatar
Oddometer: 3,789
Thanks Mark!
I'm putting on new tires, tomorrow evening I'm instaling the front and Sat..the rear. The Haynes manual has the specs in nm and I wasn't sure of the conversion. Also do I need (blue) locktite on any of the fastners. The pinch bolts were not very tight so I thought maybe I sould use it on them.
Thanks again,
Bob
AMA member
Old 04-25-2012, 02:39 AM   #13179
mas335
xendurist
Oddometer: 1,998
many torque wrenchs have both scales showing, no loctite is needed. 9 ft lbs won't feel like a lot, too much and you can pop the studs off.
Transalps
Old 04-25-2012, 04:16 AM   #13180
BOBaloo22
RIP Baby Girl
BOBaloo22's Avatar
Oddometer: 3,789
Thanks Mark!
AMA member
Old 04-25-2012, 10:01 PM   #13181
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,494
Help him with a side cover...
And I sure hope you're going to share with us photos of this fresh bike soon!!!
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 04-26-2012, 12:39 AM   #13182
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,178
With bike running and headlights on low beam, turn on indicator and it blinks properly but drop engine revs or stop to idle and the indicator just stays in the on position with no blinking until engine revs again.
Battery is new and bike starts easily straight away.
Is it the regulator that is causing a problem?
xronly
Old 04-26-2012, 02:39 AM   #13183
mas335
xendurist
Oddometer: 1,998
Well it should look exactly like the one I currently have in the flea market but it will be a while, good paint shops are never fast about getting work out.
Transalps
Old 04-26-2012, 08:33 AM   #13184
2old2Bbold
was 2bold2getold
Oddometer: 1,834
From my experience. In a lot(all) of the older bikes, the rate of flash is controled by the current and resistance in the bulb element and flasher relay circuit. Including, of course, all of the wireing, connections and especially grounds(earth). Thats why when an elememt burns out on one side it stops flashing and the other side still works. There has to be the correct ballance of current, bulb resistance and flasher relay resistance or you will have flash rate problems. Sometimes you can clean the bulb sockets( and bulb contacts) or replace the bulb (different combinations of bulbs may cause different rates of flash) and/or replace the flasher relay. Some people replace their flasher relay with a newer style "electronic" flasher that interrupts the circuit independently of the type of bulbs used. Most local auto parts stores in the US have these, and sell the electronic flashers for around $15.00 IIRC. Here's another option.( http://www.customdynamics.com/trick_flasher.htm ) On my KLR I replaced the big, stick way out, in the way, signals with really cheap clearance lights and the cheapest relay ($3.00) I coud find. Works great!!!
2old2Bbold screwed with this post 04-26-2012 at 09:06 AM
2old2Bbold is offline   Reply With Quote
Old 04-26-2012, 10:12 AM   #13185
ric678
ric678's Avatar
Oddometer: 866
modifications
Well It's really not a mod but it is the most important thing I have done to the bike so far
Bolted on the new shiny ugly gold license plate.
A short ride later to see if the mod helped it ride better, So far so good
ric678 is offline   Reply With Quote
Times are GMT -7.   It's 02:29 AM.
