Old 05-30-2012, 10:06 PM   #13321
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,045
am running stock suspension on the rear but the bike is fully loaded if that makes any difference.....
What do you mean fully loaded?
In any case, check your rear sag with you on the bike and the bike loaded as ridden. You should have no more than 2.5 inches....if it's more, crank up the preload until it goes away.
If is doesn't go away, reduce the load or replace the rear spring.
Generally TAs with too much rear sag exhibit very odd handling, wobbling etc.
Ladder106 is offline   Reply With Quote
Old 05-31-2012, 03:20 AM   #13322
ric678
ric678's Avatar
Oddometer: 866
Originally Posted by Jim Rowley View Post
I still have mine for sale, complete with genuine Honda auxilliary filters. A new filter is included.
That would fix my problem, If only my wife would understand having 2 of basically the same bike...
ric678 is offline   Reply With Quote
Old 05-31-2012, 05:13 AM   #13323
ferretface
ferretface's Avatar
Oddometer: 57
With hard luggage and probably adding an extra 40kgs overall. Its pretty damn heavy!
I've got the preload on Max already but the sag is probably too much due to the weight. I'm due to get a new rear spring so hopefully that will sort it.
Cheers for your input Ladder.
Dan.
ferretface is offline   Reply With Quote
Old 05-31-2012, 12:40 PM   #13324
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 473
Originally Posted by ferretface View Post
Chaps, need a bit of suspension advice pls.... I've got a strange issue with the front end at approx 40mph where the forks bounce up and down but disappears when the speed gets above 50. I thought it was originally tyre related but have ruled that out and I was wondering if anyone else has ever seen this before?
I think I have 7w or 10w oil and am running stock suspension on the rear but the bike is fully loaded if that makes any difference.....
I have always had a bit of front end bounce in the 35-45 mph range. Isn't apparent at lower speeds and goes away as the speed increases. Not a problem, just noticeable. Changes in wheel balancing and application of Dyna-Beads has no effect.
A mechanical engineering friend of mine thought it had to do with the designs of the dual sport tires. At a certain speed there is a bit of resonance because of the blocks/gaps in the tire tread. I do notice that the exact speed at which it occurs depends on the particular tire I am using and to some degree the surface of the road and tire pressure I am running, so I think his observation has merit. A friends TA has the same issue. It's never caused an problem, so I ignore it.
If the problem is severe for you it may be another issue. I had a significant wobble (as opposed to bounce - highly technical terms) at higher speeds (over 65 mph) when I put a new rear shock on. Adjusting the rear pre-load as others have suggested got rid of that issue.
Dale
89 Transalp
01 XR400R
http://daleeva.smugmug.com/Motorcycle
wdeTA is offline   Reply With Quote
Old 05-31-2012, 02:31 PM   #13325
ferretface
ferretface's Avatar
Oddometer: 57
I was running Conti tkc80's on it before and put it down to being a nobbly but I've since moved to Anakee II's and thought the problem might disappear with it being a more road biased tyre. It's pretty noticeable on my bike so think whatever is causing it could be increasing the affects with the additional weight.
Thinking about it, I don't think the progressive springs are not working as I expected - hitting any potholes and you really feel it hard compared to the standard fork springs.....almost as though it bottoms out.....Can anyone confirm if this is normal?
Old 05-31-2012, 03:40 PM   #13326
mas335
xendurist
Oddometer: 2,003
That's not normal. they are stiffer than the OEM springs but nothing like what you described. Did you put the right amount of fork oil in? Fork oil weight? They should not come close to bottoming on the road.
Transalps
mas335 is offline   Reply With Quote
Old 06-01-2012, 11:21 AM   #13327
explain
Oddometer: 35
Ignitech CDI watertight?
Hi,
i'm about to upgrade CDIs for my Transalp. The unit of choice is DC-CDI-P2 from Ignitech.cz
Question is how is that unit protected from water. I don't want a unit to die because of "not indoor usage". What are the opinions of owners of that unit?
Here is the photo of a unit i'm thinking about. Serial port (for unit programming) sticking out of the box doesn't look watertight at all. That's my concern
explain screwed with this post 06-01-2012 at 10:16 PM
explain is offline   Reply With Quote
Old 06-01-2012, 02:51 PM   #13328
Dekatria
Ad Astra Per Aspera
Dekatria's Avatar
Oddometer: 971
Does anyone here know how often to check the spokes on a '99, and what the torque setting should be if any need tightening? I have got no problems at the moment, but I'm just curious about it. Cheers
The Hekla Project - Riding to Hell and back (Scandinavia 2014 - Iceland 2015)
Thousands of miles, two wheels, and thirteen reasons.
Follow my project at www.thirteenreasons.nl or on Facebook!
Dekatria is offline   Reply With Quote
Old 06-01-2012, 02:58 PM   #13329
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,563
They're just tiny hunks of foam. Buy a lawnmower filter from a hardware store for a few bucks, cut to shape, oil and yer good.
....or buy them here, under air filter... http://www.hdlparts.com/fiche_section_detail.asp
On the other hand, I did mine with lawnmower filter too...
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 06-02-2012, 04:52 AM   #13330
R_Rick
Oddometer: 384
Originally Posted by explain View Post
Hi,
My 87 was outfitted with an ignitech when I bought it. I've been sorting out some other issues so haven't had much seat time and cannot comment on it yet. However, one thing to consider if you get it - take the stock cdi holder, cut the middle section out (piece of rubber that would normally separate the two units) and the cdi can be placed horizontal to keep the connectors away from the seat. If you're concerned about the serial port cap letting water in, give it a few wraps with electrical tape or zip tie a small piece of sandwich bag over the port.
cheers
Rick
R_Rick is offline   Reply With Quote
Old 06-02-2012, 05:51 AM   #13331
Daveski
Oddometer: 6
Transalp (Super)Enduro...
Right All,
I have been lurking on these pages for way too long and to say they've been an inspiration is an understatement! This is my first post so if I screw up, sorry! The mods from folk in the US and elsewhere made me buy a 97 transalp 600 (in good nick) last Feb. I was looking for a more versitile bike than my KTM 640 LC4E, which was awesome, but I wanted more robustness, smoother engine characteristics, bigger service intervals for big trips and simpler servicing and happy to sacrifice a little dirt ability as I am not on the hard end of it - this all came out of taking my ktm to Sweden and riding as much dirt as possible. The KTM rocked, but I felt I could have more by getting a TA and taking a spanner to it. So, I had the odd road trip on the TA in its original state and then set about making it 'better' over the winter - well for what I want... As such, just wanted to share where I'm at with her with you to say thanks! Inspired by the likes of modrover and atgreg, with other folk and there africa alps - i forget all the names, but you've all played a part in me wanting to make something both cool and useful - though there's still a wee way to go, I'm just gonna ride her for the summer, and see where I go next winter... Right, photos...
With luck you like, coz I do! Summary of mods:
KTM 640 Adv Yokes, Forks, Front Wheel, and Brembo Brake with 320mm rotor/disc - much easier than I'd imagined as I realised that the TA takes the same head bearings as the AT - for which you can get an aftermarket replacement steering stem to fit KTM ADV yokes ( http://www.ruggedroads.co.uk/shop/ar...6aid%3D7016%26 ). There seemed to be a 5mm difference in headtube length which I sorted with a spacer under the top cap. Put new needle bearings in at the sametime.
Sunline Bars - have some black ktm handguards to add.
Simpson Detour Side Supersport fairing - great guys to talk too and deal with - I was after the twin headlight type and looked at A LOT of options from using a 640 adv fairing, a boano (maybe in the future?), numerous universal type rally fairings from german manufacturers - but settled on this which I love. The idea when I removed the original fairing and cradle frame was too loose weight and still have good lights with a rally/enduro edge and this ticks the boxes for me. Above 75mph is a bit blustery and I am considering ordering a laminar lip made for a 640 adv which should fit perfectly and take the edge off on longer trips.
Cut the clocks down to fit but will ultimately be putting on some trailtech number when I can be arsed - just enjoying riding again right now.
Radiator shrouds are I think UFO aftermarket for a 1990-1992 honda cr125/250 (thanks to a french chap on this thread who's name I couldn't find) - had to do a little cutting to make them more flush with tank then heated them up with heatgun in the area close to tank and shaped them by holding in place on tank and letting cool. Not bad, but may go for similar ally ones that modrover made eventually - though I like that I can drop it with less fear!
SW Motech Engine guard
Aftrica Twin RD04 rear shock, rear swing arm, linkage and axle. Aluminium so reducing the unsprung weight and also balances up the geometry of the front forks adding more travel and increasing the rear ride height. Used original rear disk brake, but replaced the rear wheel (as had bimetallic rust around spokes and rim) with a mint one from a 650 TA - the rear wheels are identical.
Front indicators are in the mirrors for a clean look - though I'll take these off for more challenging dirty stuff, rear are from a ktm exc.
Got rid of old rear light for an LED unit that someone else on here had used - thank you for the idea! DRC Edge 2.
Aly Chain guard
Avon Distanzia Tyres - okay on gravel and great on the road - set of tkc80s for more dirt.
Supermoto mudguard.
Remus can came with bike - perfect.
I am planning to fit a decent pannier rack and set of ARDCases Panniers - I had a pair on my KTM and they are impeccably well made - the the bloke that makes them, rodger, is a gent. May also think about some crash bars, we'll see.
The bike handles great, confident on gravel and superb on the road... I've only done a couple of hundred miles so far, so there's bound to be some tweeking. I serviced the forks and was wondering about stiffer springs... not yet sure - stock ktm 640 adv about 155kgs, plus takes 30l of fuel so another 30kgs, I've lost at least 10kgs from the trannie, plus it takes only 18l of fuel, plus I only weigh 76kg - we'll see how it works out, just want to keep the front and back balanced which currently they seem to be. Oh, and its about 2 inches taller front and back - which suits me fine. Still gotta get the side stand modified, but will probably keep using a 2 x 4 for the centre stand for the time being.
Think that's about it. Just passed its MOT (so is now road legal) - so time to have some adventures...
Massive thanks to all those that have contributed to this thread - truly inspirational - and it was great to steal a lot of your ideas!
Cheers, Dave.
Daveski is offline   Reply With Quote
Old 06-02-2012, 06:43 AM   #13332
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,708
Good job on that conversion! Love the CR250 tank shrouds! Might need them some day.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 06-02-2012, 07:09 AM   #13333
2old2Bbold
was 2bold2getold
Oddometer: 1,838
Great work on bike the Daveski. I envy you guys over there having all the different models and varieties of used and new parts to choose from. Over here in the US with only the '89 & '90 TA available, you really have to be a fan and determined (obsessed). Again, really nice bike !!!
2old2Bbold is online now   Reply With Quote
Old 06-02-2012, 07:50 AM   #13334
Ladder106
Ladder106's Avatar
Oddometer: 5,045
Welcome and "Well Done", Daveski.
Nicely played
Old 06-02-2012, 06:23 PM   #13335
dualdogdave
Twin Power Rules!
dualdogdave's Avatar
Oddometer: 148
Welcome Daveski
Very Nice !
" In the pursuit of motorcycling excellence"
DDD
Santa Cruz Coastal Mountains
"TransHawk" Dyno Video: http://www.youtube.com/watch?v=tA-y7nxL580
"TransHawk" Dyno Charts:
http://picasaweb.google.com/adv990/D...05658028913170
Transalps and other cool bikes spotted in my travels.
http://picasaweb.google.com/adv990/T...eat=directlink
dualdogdave is offline   Reply With Quote
Times are GMT -7.   It's 09:01 PM.
