Old 06-09-2012, 10:39 AM   #13366
gskelton
Oddometer: 9
TA parts bike or project just posted
FYI - in the flea market. Love the forum keep up the great work!
http://advrider.com/forums/showthrea...8#post18872828
gskelton is offline   Reply With Quote
Old 06-09-2012, 01:01 PM   #13367
ravelv
from Baltic side of river
Oddometer: 444
RD03 arm have same axle sealings like TA's swing. And as a bit longer that TA's stock swingarm.
RD04 arm have small sealings inside swing's body besides bearing. Longer than RD03 arm.
RD07 arm have additional ball bearing in chainside along with needle one. Will need little adaption to fit in TA's frame.
Originally Posted by 2bold2getold View Post
...I think I have an RD04 swing arm, although if there are three different length arms I can't be sure. It was bought by the PO in Italy. Didn't get the link with it. ...
ravelv is offline   Reply With Quote
Old 06-09-2012, 01:30 PM   #13368
2old2Bbold
was 2bold2getold
Oddometer: 1,731
Then, the swing arm I have is from RD04. Should probably use RD04 triangle link and mounting bolts. I will try to find one. Thanks.
2old2Bbold is online now   Reply With Quote
Old 06-10-2012, 04:41 AM   #13369
wide
Oddometer: 390
Would like to see what you guys on here think.
Did a day on some Welsh lanes, it was pretty rocky stuff. Obviously the speed is much lower than it would be on a smaller enduro bike like my DR, but the suspension height causes the need to go even slower than I expected. This in turn causes stability to be rubbish as sometimes speed is better to get over a rock.
Wrong terrain for an Alp??? Or expecting too much from it?? Mate was on an old Tenere which faired much better
Maybe time for a new Tenere
Honda Transalp 650.. back on the old favorite
XT 600 E... thumping fun but not for motorways
Suzuki DR350... mellow fun but now gone
XR 400 gone
Transalp 600 gone
wide is offline   Reply With Quote
Old 06-10-2012, 08:20 AM   #13370
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,984
My Opinion, a paved road and your photos of that Welsh trail are probably the two extreme ends of what you want your suspension to do.
First one is smooth and most people don't like a lot of brake dive and softness up front when strafing apexes on the pavement.
The trail is filled with repeated rather high, sharp edged bumps that makes it necessary for the suspension to be soft enough to both soak up the edge and react quickly enough to recover for the next one.
With 20 year old suspension (likely standard stuff rather than modded or improved) you are just not going to get it to work well in both worlds. Modern cartridge forks and shocks with high and low speed circuits (not standard TA stuff) will be much better handling these two conditions.
If most of your riding will be done like this, spending some money on suspension improvements will work wonders....or you could buy a more modern bike. That's even more dear.
Beautiful ride though....wish I were there.
It's about deciding what you want the machine to do best or what compromises you can live with.
Ladder106 screwed with this post 06-10-2012 at 08:27 AM
Ladder106 is offline   Reply With Quote
Old 06-11-2012, 05:04 AM   #13371
wide
Oddometer: 390
Someone did suggest a Wilbers rear shock... not sure if they can come with a little longer travel and better springs up front. The last thing I would want to start is bodging on suspension from another bike
XR 400 gone
Transalp 600 gone
Old 06-11-2012, 08:31 AM   #13372
Ladder106
Ladder106's Avatar
Oddometer: 4,984
Those are the decisions that only you can make. My point was that improving suspension is much less expensive than buying a whole new bike. Particularly if the TA offers things or has traits that you really appreciate. Probably the best thing to do is to talk to local riders and find a shop the specializes in suspension work. Take the bike there and ask what they recommend.
Wilbers here in the States can be ordered with different lengths and will build to suit your riding style for damping adjustments. They also offer springs for the front forks.
A while back I was fortunate to work with Ricors here in Nevada to help develop their suspension mod for the TA forks. I'm not paid by them or anything but I do think that they offer the best solution for updating the TA forks to "emulate" the action of modern cartridge forks. Race Tech also has a very good product that does most of the same thing for the forks.
The standard TA rear shock does almost nothing except keep the rear wheel from hitting the inside of the rear fender. If you're half-way serious about riding off-road, the only solution is to replace it with a quality unit....yes, it's expensive.
That being said, the only way you are truly going to have modern suspension is to "bodge" it onto your bike. Everything else is just a "bodge" itself.
So......if you want to make a large improvement you have to decide if it's worth the expense. It will be much less dear than buying a new bike. You have other bikes with better legs so you know how a well set-up bike can act. The TA is big and heavy and (IMHO) the rubber mounted bars go a long way to hurt it's off-road performance....it will never be as good as the little KTM in that stuff.....but then you wouldn't ride the KTM to Scotland.
Also be aware that even new bikes don't have the best boingers as supplied by the factory. Great suspension is EXPENSIVE and it's an area where most manufacturers look to cut cost. Why else to you only see Ohlins on the Factory Special models.
And even the most expensive suspension is junk if it's tuned incorrectly.
Ladder106 screwed with this post 06-11-2012 at 08:36 AM
Old 06-11-2012, 09:08 AM   #13373
wide
Oddometer: 390
Sound advice ladder106 and something for me to pontificate over hey
All being said I am loving the Transalp, and maybe some minor tweaks will help it along
Although I did look at a new Tenere660Z today in a bike shop, but finances wont allow
XR 400 gone
Transalp 600 gone
Old 06-11-2012, 07:33 PM   #13374
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,020
Fitted heavier springs and Race Tech valves to my forks care of Dan and they make a noticeable improvement.
The 660 Tenere has crappier suspension than my 25 year old oem Tranny.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-11-2012, 07:41 PM   #13375
Backonthebike
Giddy up
Backonthebike's Avatar
Oddometer: 675
Originally Posted by Ladder106 View Post
the rubber mounted bars go a long way to hurt it's off-road performance.....
When I was putting my bike together for the first time I think I found a "bodge" solution to the rubber bushes; I put 1" washers above and below the rubber bushings, wound a heap of tension on the lower nuts and the front end feels virtually rigid....FWIW
Cheers
Tim
Backonthebike is offline   Reply With Quote
Old 06-12-2012, 10:08 AM   #13376
mas335
xendurist
Oddometer: 1,974
Has anyone tried to graft a XR650L disc brake swingarm rear end assembly to TA?
Transalps
mas335 is offline   Reply With Quote
Old 06-12-2012, 10:40 AM   #13377
ric678
ric678's Avatar
Oddometer: 866
I'm willing to try is someone has a spare swingarm
ric678 is offline   Reply With Quote
Old 06-13-2012, 01:43 PM   #13378
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,502
I havent seen any comment on this thread about the NC700X. I tried searching but nada came up. Just want know the opinion of Transalpers. I'm looking forward to see and try one...just for fun...you never know...
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 06-13-2012, 02:08 PM   #13379
Ladder106
Ladder106's Avatar
Oddometer: 4,984
Old 06-13-2012, 02:15 PM   #13380
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
you know i bet it's a good bike but honda is dead to me until they actually make a competitive dualsport
MookieBlaylock is offline   Reply With Quote
Times are GMT -7.   It's 10:38 AM.
