09-18-2012, 10:13 PM
#13651 |
Oddometer: 795
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying. Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials Past: 1999 KLR 650, 1990 Tengai 650 |
09-19-2012, 03:04 AM
#13652 |
xendurist
Oddometer: 1,555
BW,
This is a dial indiator and accurately measures the "run out" or warpage of the rotor in thousanths of a inch, some indiators read in mm. The indicator has a tab on the end that contacts the rotor and moves in or out while you rotate the wheel and displays the amount of movement. It is the only accurate way to read the rotors "warpage" from the calipers point of contact and is a fairly common tool for doing precise work. Showkey, I have always heard about a function of the seals as also retracting the piston cups and that the seals are supposed to be directional when installed BUT...... The service manual does not describe this seal orientation and the seals from Honda have no indiactors on them as to which side goes toward the pads. Even when I look at them under magnification I do not see any angle or bevel to the edges. Educate me please.
Transalps |
09-19-2012, 03:38 PM
#13653 | |
Oddometer: 487
But also found this http://www.ucx.com/documents/squareseal.pdf and this http://www.raybestos.com/wps/portal/...liper+Assembly And this http://en.wikipedia.org/wiki/Disc_brake --- TMI --- but explains that hard/wide, soft/narrow thing. Didn't know how or why, Just seen it more than once. 2bold2getold screwed with this post 09-19-2012 at 05:20 PM |
09-19-2012, 07:25 PM
#13654 | |
Oddometer: 1,571
That said if the piston are not retracting after application the first place to look is the caliper seals, piston and piston bore. The piston should slide in and out by hand. The second place is the master cylinder..........all fluid pressure should be released as the brake handle is released. Master cylinder holding pressure ports blockage is common cause, less common but possible is brake hose collapse. on the other comment 2bold Knock back is a bad thing caused by excessive flex in the system........knock back then causes excessive pedal travel to get braking force back on the next application. In a perfect world zero runout, zero warpage, zero thickness variation and zero dish would be preferred and desired.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X 1971 CT90,1981 C70, 1986 TRX 250, 1993 TRX300 4X4, 1987 XR250L showkey screwed with this post 09-19-2012 at 07:42 PM |
09-19-2012, 08:13 PM
#13655 | |
Oddometer: 487
09-20-2012, 03:02 AM
#13656 |
xendurist
Oddometer: 1,555
" In a perfect world zero runout, zero warpage, zero thickness variation and zero dish would be preferred and desired. "
I don't live in a perfect world either, I have seen some rotors that have the surface texture so rippled that the thickness variance is all over the place, I blame this on wrong choice in pads, the braking effect is horrible and will pulse like mad. Most TA caliper cups that I have seen do not move by hand at all, they are very tight.
Transalps |
09-20-2012, 06:10 AM
#13657 |
Oddometer: 1,571
The perfect world is the best case ........not seen on 25 year old bike............there are some that believe the rotor needs run out to knock the pads back........this is not the case. Runout or warpage is bad and at some point ( less than perfect) it will cause several of the problems mentioned earlier such as pulsation and poor braking. Runout can be caused by the rotor, hub, bearing or axle.
But this is not new news as it has thoroughly discussed. There are motorcycle rotor resurfacing companies to make rotors "perfect" but some rotors do not have enough meat to get perfection before min thickness.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X 1971 CT90,1981 C70, 1986 TRX 250, 1993 TRX300 4X4, 1987 XR250L |
09-20-2012, 02:10 PM
#13658 |
Oddometer: 487
Idle Speed Adjustment Mod
09-20-2012, 02:20 PM
#13659 |
It's a short cut, really
Oddometer: 4,268
Nice....it's also cruise-control
09-20-2012, 05:05 PM
#13660 |
Oddometer: 487
09-21-2012, 01:54 PM
#13661 |
Oddometer: 795
So I should be able to get my hands on one of these somewhere around here? Common tool at moto repair shops or am I looking at an unpleasantly large purchase to get ahold of one? Seems like another plausible cause of my issues.
09-21-2012, 02:03 PM
#13662 | |
Oddometer: 1,571
but......it can be had for under $40...........quality unknown![]() http://www.harborfreight.com/clampin...tor-93051.html Sears lists a wide variety of indicators with varying quality and price: http://www.sears.com/search=dial%20i...e=CAT_REC_PRED your location may vary............
09-21-2012, 02:30 PM
#13663 | |
Oddometer: 487
09-22-2012, 07:19 AM
#13664 |
Thor77
Oddometer: 1
09-22-2012, 07:07 PM
#13665 |
Oddometer: 53
My ta is finally legal. Still have a lot of work to do. Carb still has issues, xr forks feel like a jack hammer, rear shock waiting for a spacer upgrade, etc. I've put about 500 miles on her since i brought her back to life. Thanks for this thread you guys...I'm up to page270. My vstrom is getting neglected...as well as my wife and kids
