10-24-2012, 03:43 PM
#13786 |
Factory Rambler
Oddometer: 1,032
raising the rear
I don't remember the numbers, but the maximum with stock TA swingarm and linkage is dictated by the space where the shock goes between the swingarm and the linkage (hope that makes any sense). At a certain angle, the swingarm 'bridge' touches the spring. You can't raise the rear more than that. My wilbers shock has the extra lenght in travel, not just as a 'spacer' at the bottom. The only thing you need to watch is the wear of the chainguide on top of the swingarm. If the chain is set correctly with stock suspension, it will have a little more slack when the bike sits higher. No problems there.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy) want to save on Smugmug? use this code (VoUO8M1ukmnMY) |
10-24-2012, 04:18 PM
#13787 |
It's a short cut, really
Oddometer: 4,269
FWIW, I didn't like the Sarhara 3 front.
It followed every rut and crack in both pavement and dirt and didn't want to climb up out of ruts at all. |
10-25-2012, 01:59 AM
#13788 | |
xendurist
Oddometer: 1,552
That is what I did not like about the Metzler Tourance, on pavement is followed every road imperfection, I found it annoying and they did not ride as smooth or a quiet as the Distanzia's. The Avon's do pretty good off road unless it is wet.
Transalps |
10-25-2012, 04:49 AM
#13789 |
Lost but laughing.
Oddometer: 4,577
I found the same thing with the Sahara 3 front. The E07 front was a lot better on and off road.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
10-25-2012, 06:39 AM
#13790 |
Oddometer: 7
Rear shock TA
Hey guys,
Thanks for the quick replies! @Blackbert: What did you pay for the Wilbers shock? Was that one made by your demands? Where do live in Belgium? Maybe it's interesting to meet? :-) @Daveski: The point is that i putted a AT RD03 swingarm already in my bike(PD06). And i've got a rear shock from an AT from a friend( i guess RD06 or RD07). The gas tube comes out in the front of the shock. This way i can't use it as it's in the way for the water reservoir from the cooling system. I guess what you're saying is that maybe your set up on the bike is different then mine. Or the rear shock from an AT RD03 is different then the one i've got. I'll have a look into it. Hope top hear from you guys again! Thanks a lot! :-) |
10-25-2012, 07:38 AM
#13791 |
Oddometer: 6
You are right, that tube is a pain - and needs lengthing. Another inmate pointed this out to me that a chap on here looked like he'd already done this (Santa?), and lengthened the tube alot. I think it probably also needs a right angle bend where it exits the shock body to completely stop it interfering with the coolant reservoir. I'm interested to see how you get on with a Wilbers shock if that's the way you go, as it looks like a great aftermarket option. Cheers.
10-25-2012, 11:30 AM
#13792 |
Oddometer: 4,269
Just
Move The Coolant Tank It's much easier than getting a longer high pressure hose for the rear shock. Plus....IMHO, the AT rear shock is no better than the standard TA unit...just fancier. Believe me, once you put a decent rear shock on this bike you'll wonder why you didn't do it much sooner. The coolant tank connection is only a bit of tubing. The tank can be any shape and located almost anywhere on the bike. You can find many different tanks, shapes and sizes from auto parts stores. |
10-25-2012, 12:46 PM
#13793 | |
Loco, pero no estúpido!
Oddometer: 2,268
Agree 100%
I'm keeping mine! Quote:
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
10-27-2012, 08:16 AM
#13794 | |
Oddometer: 790
I run Avon Gripsters on my Transalp. Outstanding grip on dry and wet as well. I can drag the pegs and have scraped the aluminum bags. Decent offroad and superior mileage before changing them out. Its an older tire but they are suburb and priced right. Do not overlook them. With the low horsepower Transalps they don't get chewed up. Dudley
What ever happened to Roberta Claypool? 1996 Triumph Trophy 900 1989 Honda Transalp 2010 KTM 690 Duke |
10-27-2012, 10:33 AM
#13795 |
Oddometer: 1,571
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X 1971 CT90,1981 C70, 1986 TRX 250, 1993 TRX300 4X4, 1987 XR250L |
10-27-2012, 10:39 AM
#13796 |
Secular Lord
Oddometer: 91
Assessment prior to mod considerations
Just bought this a couple of days ago.
Chain, sprockets and steering head bearings are all it seems to need right now. Rear Kenda and front Trailwing should suffice. Appears to be an OEM rear shock but probably not the original as the bike with 83k kms runs very smooth over rough roads. Not sure what handle bars they are but ergos suit my 5'10" 185lb 31" inseam frame... stock screen works well with my full face but produces noise and buffeting with my 3/4 - suspect a spoiler may help. Wheels are a little pitted and spokes have lost their sheen but rust seems minimal so I hope they hold out. I won't be taking it off road... mostly got it for bumpy/pot holed pavement and gravel - so may not opt for the crash bars yet. Comments and / or suggestions greatly appreciated ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
10-27-2012, 11:37 AM
#13797 |
Oddometer: 4,269
Remember you asked
All our spokes look like that....well...probably not Marks.....no worries there I'd put a drop of oil on each nipple overnight and then just give the nipple a wiggle with a spoke wrench to make certain none of them are frozen.
The bad spots on the wheel OUTSIDE aren't too bad. Most importantly...pull the tire and tube and look INSIDE. That bike has seen some salt air or a lot of moisture. Water gets between the tube and rim at the schrader valve and causes unseen corrosion at that point. I've seen a few rims that look "OK" from the outside but are badly eaten up on the inside....safety issue. Your chain and sprockets look like they should be replaced. Don't run the chain too tight. It should look more like a MX bike than a street bike. 1.75 to 2 in of play in the middle of the run is about right. Ladder106 screwed with this post 10-27-2012 at 01:27 PM |
10-28-2012, 05:01 AM
#13798 | |
Secular Lord
Oddometer: 91
10-28-2012, 05:07 AM
#13799 |
Lost but laughing.
Oddometer: 4,577
So, what is a good, light replacement front disc rotor to fit to a 1987 600.
Didn't realise how heavy the oem disc is.
10-28-2012, 07:34 AM
#13800 |
Oddometer: 75
Hey Crash,
Nice to see another Bluenoser with an 87. If you're in need of shop manuals (honda and haynes) let me know and I'll drop a copy onto cd/flash drive for you. cheers, Rick
~~~~~~~~~~~~~~~~~~~~~~ Current: 1987 Honda Transalp Prior: 2005 Triumph Thruxon; 1985 Suzuki GR650 'Tempter' |
