Old 10-28-2012, 10:02 AM   #13801
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,102
Nice Ruan....best model and paint of the entire TA line IMHO.
Ladder106 is online now   Reply With Quote
Old 10-28-2012, 10:27 AM   #13802
Crash48
Secular Lord
Crash48's Avatar
Oddometer: 92
Originally Posted by R_Rick View Post
Hey Crash,
Nice to see another Bluenoser with an 87. If you're in need of shop manuals (honda and haynes) let me know and I'll drop a copy onto cd/flash drive for you.
cheers,
Rick
That would be greatly appreciated Rick... I sent you my contact info through the Transalp forum email but will repeat the process from here.
Crash48 is offline   Reply With Quote
Old 10-28-2012, 11:34 AM   #13803
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,583
Originally Posted by Crash48 View Post
I won't be taking it off road... mostly got it for bumpy/pot holed pavement and gravel - so may not opt for the crash bars yet.
Comments and / or suggestions greatly appreciated
With replacement Transalp plastics no longer available from Honda, the Givi TN363 crash bars are a fairly inexpensive, must have accessory for any TA. Accidents do happen and you will cuss and kick yourself if your precious plastics get crunched because you balked at spending a little money to protect them.
http://www.sporttour.com/shopexd.asp?id=2568
Help Stop McNugget Rage
WeeBee is offline   Reply With Quote
Old 10-28-2012, 12:24 PM   #13804
Ruan
Adventurer to be
Ruan's Avatar
Oddometer: 81
Thanks...
com4riding.blogspot.com
Portugal to Andorra in 1984
http://advrider.com/forums/showthread.php?t=817041
Ruan is offline   Reply With Quote
Old 10-28-2012, 02:31 PM   #13805
wide
Oddometer: 391
Originally Posted by Ruan View Post
Bought mine like this in may 2012:
Now it has crash bars and adventure lights:
Adventure lights on:
Like those little lights with big power, where did you get them from
Honda Transalp 650.. back on the old favorite
XT 600 E... thumping fun but not for motorways
Suzuki DR350... mellow fun but now gone
XR 400 gone
Transalp 600 gone
wide is offline   Reply With Quote
Old 10-28-2012, 02:57 PM   #13806
Ruan
Adventurer to be
Ruan's Avatar
Oddometer: 81
Bought them in a motorcycle shop in northern Portugal.
some forum mate is selling one kit for 25€. Mine cost 36€.
http://www.trailaventura.com/forum/v...p?f=90&t=19259
Ask him wether he wants to send it to you...
Ruan screwed with this post 10-28-2012 at 03:05 PM
Old 10-28-2012, 05:09 PM   #13807
Crash48
Secular Lord
Crash48's Avatar
Oddometer: 92
Wow only $113... description says 1989 - 93 - will it bolt right on to the '87? (edit: I see in a previous post that it works with a longer bolt from hardware store)
Crash48 screwed with this post 10-28-2012 at 06:14 PM Reason: found answer
Old 10-28-2012, 05:22 PM   #13808
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,721
Easy Ray easy thems is some big words
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is online now   Reply With Quote
Old 10-29-2012, 06:13 AM   #13809
JBMorse
JBMorse's Avatar
Oddometer: 239
Give us a brake!
Originally Posted by Cruz View Post
So, what is a good, light replacement front disc rotor to fit to a 1987 600.
Didn't realise how heavy the oem disc is.
Anybody have an opinion on this? One of my only gripes with living with the Transalp is its somewhat weak brakes. I was planning to swap the front brake lines for a stainless one, which was a significant improvement on my CB500/4. The rear drum is just a lost cause I think. I put in some grooved EBC shoes but they aren't much better than the originals. It would help if I corrected the linkage action to the rear brake ( my Alp was once crashed and the left footpeg bracket is slightly skewed, causing the rear brake linkage to be out of whack.)
EBC seems to have a replacement disc, but I can't tell whether it's just an OEM replacement or an upgraded design. If it is an upgraded disc, what pads would be good with it?
Edit: Here's the EBC disc I mentioned:
http://www.jcmotors.com/p-28324-ebc-...x#.UI5_aK6FKwo
JBMorse is online now   Reply With Quote
Old 10-29-2012, 07:01 AM   #13810
Motoswami
Motoswami
Oddometer: 104
improved front braking
Those wishing to make an inexpensive front brake improvement may benefit from knowing that the 1989-1990 HawkGT front rotor is 315mm in diameter and bolts directly to the Transalp front hub of the same years.
An adapter to relocate the caliper must be machined. I took the parts to a local machine shop and had no trouble having one fabricated from aluminum.
The Hawk rotor can be found used for a reasonable price.
Well worth the expense in performance upgrade.
Pete
Motoswami is offline   Reply With Quote
Old 10-29-2012, 12:06 PM   #13811
ferretface
ferretface's Avatar
Oddometer: 57
Pete
+1
I fitted the Lenac adapter to mine and it has improved the braking mucho!
I'm not sure if they are still available but there might be another manufacturer that sells them....someone on here should be able to advise.....
Two Brits traveling overland through Canada, USA, Mexico, Central and South America by motorcycle.
http://heyivegotanidea.wordpress.com/
ferretface is offline   Reply With Quote
Old 10-29-2012, 12:39 PM   #13812
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 476
XL600V Transalp Caliper Adapter
M.A.P Engineering in Colorado Springs sells the adapter.
http://www.map-engineering.com/prodd...46eea58f2e0177
Pretty sure he originally designed it and the Lenac one was a take off from his (sorry I didn't know that until after I bought the Lenac kit). The page lists the disks it works with and if you contact him he might be able to source one. The adapter/rotor change along w/ SS lines made a significant difference in braking on my TA.
Dale
89 Transalp
01 XR400R
http://daleeva.smugmug.com/Motorcycle
wdeTA is offline   Reply With Quote
Old 10-29-2012, 03:58 PM   #13813
R_Rick
Oddometer: 410
Prior to buying engine guards, I checked various websites and found some fairly low prices, however, due to bulk of them, freight costs (from US to Can, and from West Can to East Can) pushed the total price up to $150+. I ended up ordering them through ProCycle for, IIRC, around $155ish.
You are correct, long bolt that comes with kit will not work on the 87. Not being able to find a metric bolt, I went with a 5 1/2 long, 5/16" (5 1/4" long would have worked as well). You may need to ratchet the lower sections in place to get lined up with the bolt holes.
R_Rick is offline   Reply With Quote
Old 10-30-2012, 10:43 AM   #13814
Crash48
Secular Lord
Crash48's Avatar
Oddometer: 92
Thanks Rick... I read your engine guard installation report - hope you had a few beer afterward.
Motorcycle Superstore has the engine guards in stock if anyone else is looking.
$113 incl shipping to the lower 48... $160 incl shipping, duty and taxes to Upper Canuckstan.
Old 10-30-2012, 12:33 PM   #13815
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,059
Originally Posted by Bossit View Post
Hey guys,
Thanks for the quick replies!
@Blackbert: What did you pay for the Wilbers shock? Was that one made by your demands? Where do live in Belgium? Maybe it's interesting to meet? :-)
Hope top hear from you guys again!
Thanks a lot! :-)
I'll have to look for the paperwork, but from IIRC, something like 400€ (basic shock, no remote preload adjuster or other add-ons that make it more expensive. Got it from these guys.
I'm close to Antwerp, across the river ;-)
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Times are GMT -7.   It's 10:28 AM.
