11-24-2012, 05:31 AM
#13891 | |
Secular Lord
Oddometer: 91
![]() Installed new chain and sprockets with slack at 1.5 inches... photo after 600kms - bike on sidestand.
KZ400 -> W650 -> RC342 -> XL600V The mystery of human existence lies not in just staying alive, but in finding something to live for. Fyodor Dostoyevsky, The Brothers Karamazov |
11-24-2012, 06:01 AM
#13892 | |
Lost but laughing.
Oddometer: 4,559
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. |
11-24-2012, 07:23 AM
#13893 |
Chasing after theory
Oddometer: 142
Gasket and sealing...
One issue with gaskets is they will all tend to age and either go brittle or fail at some point in their life. There are many types of sealant out there that people like to use, but a common problem is both how much and what are their draw backs. With silicon based sealants excess seepage into the inner space (water pumps, oil pans) to mention a couple, you run the risk of having the excess ooze that is left inside your motor pulled through your engine clogging oil passages and other vital components.
![]() photo uploader This above image is from the oil filter of a Porsche Boxster we were working on and is a common issue when "more" is not better. The source was traced back to the oil pan gasket where the owner had used copious amounts of sealant due to worn oil pan bolts. On all of the engines I work on be it cars or bikes, when there is a gasket that I want to be sure does not leak, yet is capable of easily being removed I use Aviation gasket sealer. Why? This is both gas and oil resistant, forms a leak proof barrier and stays pliable. When servicing is required, removing a component that you are not left with the scraping and peeling that tends to come with using other adhesives. Additionally, if you have metal on metal components, this sealant appropriate for those locations as well. The sealer has the consistency of a very heavy molasses and all you have to do is wet the surface with a small brush. A bottle this size has lasted me over a decade. ![]() With all this said, opening up your oil filter is a good practice to see what lurks in the recesses of the filter material. Conditional changes may first be noticed by what you see your filter stopping. picture sharing
Life is the last thing you experience before you die...living is what you do every day to get you to that point... |
11-24-2012, 08:43 AM
#13894 | |
Oddometer: 466
Exactly!!!!!!!!
This is the truth......most guys will not admit that their motor uses oil. I am personally a little suspicious of an older motor that does not use at least a little oil. Most ADV'ers are pretty much anal about oil, and do change it often, this could be disguising an oil usage issue. How many measure the drained oil? Oil usage might not be noticeable at 2500 mi. but could be destructive at 5000 miles ( might be on an extended trip to a foreign country and proper oil not available) . It might be an interesting experiment to ride your bike for an extended oil change interval just to see what the usage might be , if any. I know mine uses oil between changes, I ride long distances often and I have over 76k miles on a 23 yo motor.............
11-24-2012, 11:12 AM
#13895 |
from Baltic side of river
Oddometer: 405
Seems still depends on design and each engine can have this "threshold"... On my car (x16xel engine) motor starts a bit consume oil if I keep it constantly over 3000rpm's.
On TA I mostly keep not more than 5000rpm's, oil is not consumed noticeably. And I change oil like on car- around 10 000km's or once per 2-3 years, which comes first. Old oil from engine is quite clean always. So, I don't see reason to change oil more frequent, except when most riding is done in city or heavy offroad. But I ride mostly in "light" mode around 90-100km/h on highways |
11-24-2012, 01:41 PM
#13896 | |
Oddometer: 480
11-24-2012, 01:46 PM
#13897 |
xendurist
Oddometer: 1,547
Sounds right to me. Did you disconnect and remove the side stand indicator light switch, I don't see it.
Transalps |
11-24-2012, 01:57 PM
#13898 | |
xendurist
Oddometer: 1,547
I have never heard of a XR (650) or a NX650 being pretty much done at 7-10K miles unless neglect or abuse was involved. I have seen a few NX650's with 50K miles and still running fine. I thought KLR's were more reliable than that? There seems to be more than a few DR350's dead at 10K but they run the crap out of those little engines.
Transalps |
11-24-2012, 02:10 PM
#13899 | |
Old and In the Way
Oddometer: 2,470
I know of a fellow on a local dual sport board who recently posted his KLR had just turned over 100K, so it aint unheard of. YMMV |
11-24-2012, 02:49 PM
#13900 | |
Oddometer: 480
11-24-2012, 03:51 PM
#13901 |
xendurist
Oddometer: 1,547
**Let's face it most riders don't have the knowlede, experience, or will to do maintance of any kind much less major repair on their bikes, cars or anything else. **
I have to agree with you on this statement, craigslist is filled with these kind of butchered bikes. It seems to be a problem that has gotten noticeably worse in the last 5 years. We are watching a mechanically illiterate generation expand.
Transalps |
11-24-2012, 04:07 PM
#13902 | |
Oddometer: 480
2bold2getold screwed with this post 11-24-2012 at 04:48 PM |
11-24-2012, 04:35 PM
#13903 |
Wishing I was riding RTW
Oddometer: 2,420
Qoute
mas335 xendurist Joined: Jun 2006 Location: Piedmont region NC Oddometer: 1,466 Sounds right to me. Did you disconnect and remove the side stand indicator light switch, I don't see it. End Qoute So is there a step by step of the side stand switch elimination? Ive been thinking that getting rid of my switch would be good for remote travel less to go wrong type thing
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
11-25-2012, 06:20 AM
#13904 | ||
Oddometer: 142
Milestone achieved...
Well, I finally completed reading all 13904 posts in this thread and I will tell you it was like being back in graduate school with the amount of information that is thrown out in this thread. My goal was to have it done by Thanksgiving but things came up and it took a tad bit longer. From all this reading, I have compiled 268 pages of detailed notes which tracks part numbers, modifications, enhancements, trouble spots and alternative solutions and will be used in my build.
I need to go through and organize all of my notes in to their sections and update my required parts list. I think what I will do is turn this into a PDF and post it on Google Docs so if anyone wants a copy of my crib notes drawn from almost 9 years of accumulated data here. Did I capture everything? Not by a long shot! Reading this thread is like going on a search for gold as some of the more unique finds (such as websites, parts suppliers and even hard to locate part numbers) tended to be in the single line replies that are posted. You guys are sneaky! Technical data is not always the only thing found here, I have learned a lot about many of you and I will tell you right now, I will by anyone here a beer if you are in my neck of the PNW! If giving was a way to become a millionaire...all of you are wealthy beyond comparison. There are also a few funnies that I have learned about many of the people in this thread and thought I would share: Things I have learned: Michael has a heart the size of Everest! Ray knows 99.998 percent of the cumulative information on the TA Mark has a secret manufacturing shop for body parts (the TA that is...) Carlos has the crappiest weather of everyone on the forum and barely gets to ride yet he came up with one of the coolest garage built shock risers I have seen Jeff has more toys they he should Wait…Ray does knows everything Dan has an Hawk conversion is fantastic Menasco Pirate owns close to every bike built Ray is like the Chuck Norris of knowledge for TA’s Jim sells really cool parts, sadly I can’t use all of them Santa brings presents more than one day a year… and is a good friend to have . Thunder Dan has increased the TA riders by +2 which was great news! Showkey is the expert here on Honda inventory and policies, I secretly think he is a Honda undercover engineer or something like that! (Stolen from Ray) Favorite quotes I found: FAVORITE RAY QUOTE: ....dang. I didn't know I could quote myself like that. .....I outta be a democrat. Second favorite: Warped rotors are the poor-man's ABS Favorite Jim Quote after a very long lesson on carberators from Ray:
11-25-2012, 07:13 AM
#13905 | |
Nanu-Nanu Adventurer
Oddometer: 7,006
Thank you so very much and sorry for the really late reply. It looks like the muffler sticks out about 4 & 1/8 from the original tail rack. It does come up quite a bit in the rear and it might be hit or miss if the 5 & 1/2 down from the stock rack would fit. It sounds like it will be worth a try and if nothing else I break out the welder and customize some more. ![]() I have no idea if you can see what I am talking about in these pictures but I will try. ![]() ![]() ![]() ![]() DOH I really need to paint that rear rack don't I. ![]() Thanks again. Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3 Lomax screwed with this post 11-25-2012 at 07:26 AM |
