Old 12-03-2012, 04:47 PM   #13981
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Originally Posted by mas335 View Post
No all 4 are 89 Blue. Since I have never seen a 96 TA seat I can't say for certain but I would think the seat mounting did not change. I need to get these seats listed in the flea market they do take up a lot of shelf space.
These seats range from near mint to faded and discolored. I also have just a blue seat cover that was taken off of a 89 seat but you need the entire seat and cushion right?
Maybe someone else knows if the seat attachment changed from 89-90 to 96.
Thanks for that mas335. I need to go with an entire black seat.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 12-03-2012, 04:55 PM   #13982
mas335
xendurist
Oddometer: 1,960
USA bikes were only blue and gray. I had a 1991 TA that did have a black seat.
Transalps
mas335 is offline   Reply With Quote
Old 12-03-2012, 09:05 PM   #13983
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,960
Sure looks like the identical frame and tank so older seats should fit.....
.....unless Honda did something odd and changed the mounting points.
My money is on the seats being identical.
Ladder106 is offline   Reply With Quote
Old 12-04-2012, 05:56 AM   #13984
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,181
I wonder if there'd be any hints in the part numbers between the last model year of one and the 1st of the next? I like how KTM does their part numbers. Each part gets a number that cross references to every bike it fits. I think Honda has a model code in their part numbers. I'm hoping to be enlightened on that.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 12-04-2012, 09:51 AM   #13985
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,794
Hi All,
it's been a while since I stopped in to read and catch up (about 18 months since I had a TA). I was in France for Thanksgiving break and came across this near the Sorbonne. I've never seen black bodywork before (in person). Since most bikes/scoots spend most of their life exposed to the elements, this example needed some TLC (especially the saddle). Happy Holidays!
I have no idea about the model year. I see it has a sliver motor with a rear disc, center-stand and gold rims (I'm pretty sure the wind screen is after-market). Did European models differ that much from US spec stuff or is this example from the early-to-mid 90s? And, no, it's not leaking oil/gas, it had been a damp morning.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 12-04-2012, 10:19 AM   #13986
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by GSPD750 View Post
Another buying feature was that it was already lowered with a kit and custom dished out seat. Forks also lowered in the triple clamps. This will make it easy for my family members to ride once they've had a motorcycle course.
Hi,
Are you absoultely sure the bike is actually lowered, and not raised on rear side? Judging by the above pics, it seems to sit just as high, if not higher than the average Transalp 600. These bikes are very common here in Europe. In the pics it is indeed obvious that the fork tubes are raised in the triple clamps to lower the front end, however overall the bike seems higher than most, which puzzles me.
For instance here is a pic of my '99 model
My bike is definitely not lowered in any way. In the meanwhile (since this pic was taken), I cranked the real preload to maximum, which raised the rear end by another 1-2 cm but that's about it.. ground clearance is still crappy, below the officially stated 195mm of this model.
In fact, it would be nice if you could measure the ground clearance, between the ground and the bottom of the center stand mount joints, while holding the bike vertical, and under it's own weight only.
deathu is offline   Reply With Quote
Old 12-04-2012, 05:31 PM   #13987
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Originally Posted by deathu View Post
Hi,
It must be an illusion to your eyes when looking at the pics as this bike is def lowered inluding the spring that is wound down judging by the hammer tooling marks on the spanner ring. You did see the pic of the lowering kit which changes out the OEM link? Ok, I just got down on my back on the cold garage floor and measured ground clearance of approx. 185mm to the center of the cross member of the frame...give or take a mm.
I just purchased a used OEM link on ebay.de which will give me the option of jacking it back up again.
Hey, is that an AT skid plate on your TA? Does it bolt right up?
Old 12-04-2012, 11:17 PM   #13988
Ladder106
Ladder106's Avatar
Oddometer: 4,960
The AT bashplate will certainly fit into that space (at least the RD03/04 one would...not the RD07). But the AT plate uses one bolt at the front and the AT plate uses two...the other mounting hole may or may not line up. It doesn't seem like it would be too difficult to mod some brackets to bolt it up, though.
The TA plate from Twisted throttle is much stronger and will bolt right up to the TA. Mine has brushed off some pretty severe hits over the years.
Old 12-05-2012, 12:17 AM   #13989
deathu
deathu's Avatar
Oddometer: 77
Of course, I did see the custom suspension links on your bike. Well, I am not sure exactly to which point on the frame did you measure, but in my case the clearance was about 175mm (that was before I maxed out the preload, I think I will measure again today just to have an idea). Of course, if the center stand mounting joints did not exist at all, ground clearance would be about 20-25mm higher. This is a bad design on the EU frames... the center stand mounting is always the first to hit in certain situations, such as climbing high curbs or crossing railways in not specifically intended places when going offroad
That is indeed an Africa Twin skidplate, the 3-pieces model from RD04/RD07(a) ATs. It requires minor modifications such as cutting a few notches and drilling new holes in order to mount on the TA. As far as shape and size, it fits well.
The thing is, the higher you wish to mount it, the more you have to cut. As the transalp engine cases are very exposed, protruding a bit below the main frame rails, I wanted a little "buffer" space, around 10mm, between the underside of the engine and the skidplate.I don't know what kind of space is there on a RD04/RD07 AT, but I wanted to allow the skid plate to bend and deform to absorb impacts, not to ruin my engine cases. This also compensates a bit for the height of the centerstand mount joints, and should allow the underside of the bike to slide a bit easier over obstacles.
AFAIK, the Africa Twin RD03 skidplate (one-piece model) is a bolt-on on the Transalp frame, but I may be wrong, maybe others can confirm this.
Old 12-05-2012, 06:11 AM   #13990
ravelv
from Baltic side of river
Oddometer: 444
RD03 skidplate also needs similar modifications as RD04 and RD07 ones to fit TA frame. Though, RD03 skidplate, in my opinion, is best to use for TA.
ravelv is offline   Reply With Quote
Old 12-05-2012, 03:34 PM   #13991
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Any way you look at the TA (with or without the lowering kit) it's fricken low. I know it's not fair if I compare it to my AT. Question....is the Honda OEM centerstand for the TA any lower in physical length than the SW Mototech centerstand?
Old 12-05-2012, 03:58 PM   #13992
Blackbert
Factory Rambler
Blackbert's Avatar
Oddometer: 1,056
I have an RD03 skidplate on mine. A piece of 4mm flat mounted on the front of the frame, 2 holes for M6 bolts with nyloc nuts on the inside mount the plate using the OEM points.
I drilled 2 holes in the rear bottom part and used 2 countersunk bolts to mount the plate to the frametubes, using 2 of these.
It has taken a few beatings, never moved, no damage to the mounting points.
Honestly, have you ever heard of somebody looking back on his life thinking: "Oh, I should have travelled less and mowed the lawn more often"? (Pumpy)
want to save on Smugmug? use this code (VoUO8M1ukmnMY)
Blackbert is offline   Reply With Quote
Old 12-06-2012, 01:24 PM   #13993
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,484
You can build your own bashplate...
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 12-06-2012, 01:34 PM   #13994
locorider
locorider's Avatar
Oddometer: 2,484
Love the crate! Is it yours? Of course, needless to say that the bike is awesome!
I can now officially join in on this thread with the aquisition of a 1996 XL600v-T that I brought over from Germany last week. Yes, working for a major airline here in Canada has it's privlages. My Africa Twin now has a little sister.
A colleague in Frankfurt who works air cargo was also very instrumental in making this happen with transport of the bike in his van to pick it up from the seller 135 kms south of Frankfurt. This coworker also owns an Africa Twin.
After a whirlwind visit with 2 nights stay at a hotel near FRA I was on my way back to Calgary with the TA on the same Airbus A330 as me....and some German Xmas cakes and chocolates. I didn't forget the 1 liter bottle of Crown Royal either.
The bike I came home with was my first choice with 19,500 kms and in the end the seller held it for me which simplified things further with no need to look at a backup '95 TA 30 kms down the road. Another buying feature was that it was already lowered with a kit and custom dished out seat. Forks also lowered in the triple clamps. This will make it easy for my family members to ride once they've had a motorcycle course.
So...needless to say I'm stoked and I'm going to have fun with this bike. Did I mention it was clean? I don't think it's ever been through a mud puddle.
Ok...pics.
Dangerous goods have to be x-rayed.
I did it! It's in my garage. Of course after I paid taxes and a brokerage fee.
And clean it is...
I had to bring it to my buddys m'cycle shop for a required government inspection in order to get it registered....another fee.
Anyone care to comment on this suspension link. It was said by the previous owner that it lowered the bike 22 mm.
Also seen in the pic is the custom shorted sidestand which was fabricated with threaded ready rod and a jam nut. It was actually not a bad weld but the rod did not hold up for the flight over and was bent. Rod is removed in the pic. First repair/mod to do.
Soooo....I've got plenty of time this winter to dress the girl up. Probably start with tires as they are old and hard. I need some ideas for a luggage system. Not sure what yet. Centerstand would be nice...but damn she's pretty low already. I might be plowing the fields with it. Some heated grips and a tankbag might be on order too.
Any ideas...chime in please.
Carlos locorider
Old 12-10-2012, 08:28 PM   #13995
Belgian Waffles
Oddometer: 874
Too good to be true, right?
http://www.ebay.com/itm/Honda-XL600-...0b40d4&vxp=mtr
Just making sure... Is it just cheap quality chain in general? Poor quality seals/rings, etc? Or is someone just being really generous.
I'll be needing a chain and sprockets here pretty soon.
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Times are GMT -7.   It's 12:37 AM.
