Old 12-10-2012, 08:47 PM   #13996
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,709
That eBay chain and sprocket set is cheap and maybe too cheap. A good chain alone should cost around $100. Having seen front spline drive sprocket wear I will only get oem front sprockets the rear and chain just good quality but dosnt have to be oem
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is online now   Reply With Quote
Old 12-10-2012, 09:09 PM   #13997
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,538
Last chain I bought was an EK X-Ring from ebay seller moto-heaven for less than $100 shipped. They were great to deal with and have an excellent reputation.
EK 525 SRX GOLD 120 links Motorcycle drive Chain X-RIng
Formerly NorCalTA
WeeBee is offline   Reply With Quote
Old 12-11-2012, 08:15 AM   #13998
danyila
danyila's Avatar
Oddometer: 68
http://transalp.danyila.hu/lajos/haspancel/DSCF9810.JPG
http://transalp.danyila.hu/lajos/haspancel/DSCF9811.JPG
http://transalp.danyila.hu/lajos/haspancel/DSCF9776.JPG
6 mm aluminimu plate. Rivet 8mm aluminum
danyila screwed with this post 12-11-2012 at 08:27 AM
danyila is offline   Reply With Quote
Old 12-11-2012, 09:18 AM   #13999
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,203
Couldn't get the links to show so I edited them. My TA plate is cracked and getting fugly. Need something Heavy like this.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 12-11-2012, 09:27 AM   #14000
Kamala
Kamala's Avatar
Oddometer: 12,729
Originally Posted by tuffgong View Post
Clutch replacement on an 89 TA 600 looks to be a fairly straight forward proposition without too many complications,open access and no special tools required. Am I kidding myself?
You will need something (Clutch basket Tool, Pennys, Wood) to keep the basket from rotating to get the nut off but other than that its pretty easy. BTW, more often than not all you need for a slipping clutch are new clutch springs. If you are replacing them (as you should) its worth while to see if just those alone solves the slipping problem.
I survived the Great Folk Music Scare of the 1960s (when it almost caught on) !
Kamala is offline   Reply With Quote
Old 12-11-2012, 03:03 PM   #14001
Transalp1999
Oddometer: 13
Question What the heck am I missing!?
I put a new National Cycle windscreen on this evening and put new windscreen screws in (Since the originals were in rough shape). Problem is the darn things don't tighten down like they should. They just spin. I've tried grabbing the back with a par of needle-nose pliers but no luck. Think it's just cheap rubber that's not compressing to form a seal?? Or what??
Cheers!
Transalp1999 is offline   Reply With Quote
Old 12-11-2012, 03:59 PM   #14002
2old2Bbold
was 2bold2getold
Oddometer: 1,691
Cheers!
I'm guessing these are what are called "well nuts". A flanged rubber tube with a brass threaded insert in one end. I had some that the threaded part turned in the rubber. I carefully used a little super glue on the metal part and quickly reinserted in the rubber. Worked good. Try to keep it straight, and check the threads on the screws. Or get new well nuts at a hardware store or bike shop.
2old2Bbold is offline   Reply With Quote
Old 12-11-2012, 08:11 PM   #14003
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,203
Make sure the new screws are threaded all the way up, maybe you are running out of threads before it gets tight or they are too long?
Michael
Old 12-11-2012, 08:46 PM   #14004
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
The wellnut rubber end should be a very snug fit in the hole. I have to use a bit of ArmorAll to lube them up a bit before they will pop in.
If they just fall into the hole they are the wrong size
They also have to be long enough to allow the inside bit to deform slightly (like a rivet) to hold the screen tightly against the frame.
Ladder106 is offline   Reply With Quote
Old 12-14-2012, 06:42 AM   #14005
danyila
danyila's Avatar
Oddometer: 68
This is a very robust.
Old 12-14-2012, 06:49 AM   #14006
ChrisUK
ChrisUK's Avatar
Oddometer: 588
Updates of RR involving a TA at http://advrider.com/forums/showthrea...=828973&page=5
Take a look?
ChrisUK is offline   Reply With Quote
Old 12-16-2012, 09:33 AM   #14007
DualDog
Oddometer: 169
Fronk Shocks/Forks
My 1989 Transalp is leaking from front shock and boots are falling apart and has had quite a bit of sag in front end for awhile.
Getting ready to order some Progressive Springs.
Also getting some Honda Fork Seals and Dust Covers.
Question. What is a good fork boot to use? I put Daystar brand ones on my KLR650 and have been happy. Was wondering if anybody is using these and if so, what size. I have seen some sites say the size 58 is what is needed and others say size 69 is what is needed and Daystar website does not list what will fit this cycle. Any suggestions on what size or suggestion on another brand would be helpful (or a brand to avoid).
I am wondering if any special tools and/or equipement will be needed to do this.
Also, any help or suggestions here would be appreciated on how to perform this job.
DualDog is offline   Reply With Quote
Old 12-16-2012, 12:18 PM   #14008
Rob 110
Rob 110's Avatar
Oddometer: 41
noob
hi been lurking for a while and reading up on what to do!
bought this 99 bike with 30,000miles, ex Police bike for 800
got 87 CR500 cartridge forks and RD03 swinger, plus '83 CR250 shocker, so it'll all happen slowly
managed to get a bit done today!
sold loads on ebay, fairing, bars, etc for over 300!!!!
so bought loads too
the transalp exhaust was rotten and i'd always planned for it to go, bit when i removed it actually broke off from the header!
especially pleased with the replacement titanium Gixxer pipe for 11.20 delivered! half the weight too at only 3kg
talking of weightloss i've actually taken 23.5kg off it!
but replacements for some parts only adding 3.8kg, but fairing and a new headlamp will add to this
got the CR forks/XR yokes in today, had to drill and tap some lock stops, but fairly straightforward.
Pleased to find the Transalp progressive springs were longer than the CR ones!
But removing the CR spacer makes em fit with a bit of preload. Trying 5w oil and 120mm air gap.
Oil removed was pretty clean for the age of the forks.
more next week and over chrimbo
http://i589.photobucket.com/albums/s...b110/all-1.png
Dirty R30 CCM
Filty 404 CCM
Rob 110 is offline   Reply With Quote
Old 12-16-2012, 12:38 PM   #14009
Ladder106
Ladder106's Avatar
Oddometer: 4,975
As with any fork swap, you'll want to be certain that the front wheel/tire/fender does not compress so far that it contacts the triple clamp or the frame downtube or crashbars.
Remove the springs and raise the wheel until the fork stops going up...see if anything gets in the way of the tire.
Old 12-16-2012, 12:44 PM   #14010
Rob 110
Rob 110's Avatar
Oddometer: 41
thanks
ooops, had read about it and forgot too
i've ditched the crashbars so no probs there
the 87 CR500 forks are apparently same as later XR6 cartridge forks, so clearance should be ok:/
its going to have a one off fairing made (bodged) for a rally-alp look, eventually;)
Dirty R30 CCM
Filty 404 CCM
Times are GMT -7.   It's 10:47 AM.
