Old 12-26-2012, 01:36 PM   #14056
happyclam
happyclam's Avatar
Oddometer: 169
Originally Posted by Jim Rowley View Post
Watch it.
If you add potatoes, doesn't that give you more carbs?
NIce!
happyclam is offline   Reply With Quote
Old 12-26-2012, 01:51 PM   #14057
mas335
xendurist
Oddometer: 1,998
Originally Posted by Ladder106 View Post
Lomax,
I think it's the rack....not the bags.
Did nobody understand my "first lady" joke? Or are you all democrats?
I thought it was too obvious to comment on. The last Democrat I voted for a Jimmy Carter, I learned my lesson.
As far as carb cleaning goes, I think you are wasting time if you don't use carb cleaners along with high pressure air blown in all the ports and jets.
I soak jets in Chemtrol B12 and then blow them out.
Transalps
mas335 is offline   Reply With Quote
Old 12-27-2012, 05:09 AM   #14058
Clockwatcher
Oddometer: 520
My 2 cents.........
Here is a little trick I have used from time to time on carbs to cases to calipers ............
http://www.aircooledtech.com/tools-o.../soda_blaster/
A little pennytech solution.........word to the wise.......do this outside......
Clockwatcher is offline   Reply With Quote
Old 12-27-2012, 06:25 AM   #14059
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,255
Sweet idea, I have an old T20 (X-6 Hustler) that needs that reeaallly bad!!
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 12-27-2012, 07:37 AM   #14060
2old2Bbold
was 2bold2getold
Oddometer: 1,831
Media Blaster
Or one of these... http://www.harborfreight.com/21-oz-h...gun-95793.html works pretty bood for soda and small jobs.
2old2Bbold is offline   Reply With Quote
Old 12-27-2012, 07:46 AM   #14061
Dr E
Chasing after theory
Dr E's Avatar
Oddometer: 143
Originally Posted by R_Rick View Post
I think i got lost in the recent flurry of pictures. Anyone put a ss brakeline on and can advise of length?
cheers
You will find lengths mentioned anywhere from 44" to 50" mentioned. Having recently measured my bike for this I went with 50" for the final length. Mind you this is now running a 650 front end and you could safely take 6" out for a stock suspension. I would recommend going with at least 48", extra length will not effect performance and having extra is always better than the alternative.
Also, you might want to consider going to your local industrial hydraulic supply house to have the line made. I went down to my local supplier and was able to have a line made for $54 out the door with tax.
Life is the last thing you experience before you die...living is what you do every day to get you to that point...
Dr E is offline   Reply With Quote
Old 12-27-2012, 09:45 AM   #14062
R_Rick
Oddometer: 379
Thanks for input - 48' it is. I have a (very) small local guy who started making SS lines for bikes a few years ago (in addition to powder coating) ... one of those guys who started coating and making lines for his bike rebuild projects and turned it into a small biz.
Cheers
R_Rick is online now   Reply With Quote
Old 12-28-2012, 12:23 AM   #14063
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,175
Do you just remove the metal joiner piece that is bolted to the lower triple clamp and run a single stainless line like a dirt bike?
Anyone still used the oem joiner piece and two stainless lines?
For and against doing it this way?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 12-28-2012, 06:52 AM   #14064
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Single line from master cylinder to caliper. 1) Less potential leak points. 2) less potential trapped air bubbles. 3) cleaner install.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 12-28-2012, 11:01 AM   #14065
Dr E
Dr E's Avatar
Oddometer: 143
^^^ This right here!
Old 12-28-2012, 11:24 AM   #14066
mas335
xendurist
Oddometer: 1,998
My 91 had a oem factory single one piece front brake fluid hose, no cross over pipe, made bleeding much easier. The hose was a real upgrade from the feel of a 89-90, much firmer braking.
For a while now I have noticed when ever we are on a specific topic the corresponding item magically appears on fleabay, we are being watched.
Transalps
Old 12-28-2012, 12:06 PM   #14067
Dr E
Dr E's Avatar
Oddometer: 143
I think you may be onto something...let's test it (note: nobody buy this...this is my test)!
I would like to point out that I am LOOKING FOR A NEAR MINT 90 TA for $1000.00 BUY NOW on EBAY.
Old 12-28-2012, 12:16 PM   #14068
mas335
xendurist
Oddometer: 1,998
Nice try but I think I will be hitting the BIN button on that one.
No we should start talking about heated grips and see how long it takes for one to show up on ebay.
Transalps
Old 12-28-2012, 12:27 PM   #14069
Dr E
Dr E's Avatar
Oddometer: 143
You would do that! OK, heated grips are in as I am in no position to argue based on the current weather here:
Old 12-28-2012, 12:30 PM   #14070
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I just installed some Oxford brand heated grips on my AT. Really easy install and like all my other heated gear, why didn't I do this sooner?
Did I mention they were made by Oxford?
Jim Rowley
Black Forest, CO
Times are GMT -7.   It's 06:58 AM.
