Old 05-07-2013, 08:31 AM   #14686
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,051
Wow !
If I had a garage like that, it would have a bunk and a refrigerator. Then I'd only leave it to ride.
Good catch on the oil pressure.
I'm thinking that pulling the right side cover and looking at the oil pump drive chain would be pretty easy.
Let us know what you find.
Whatever it is, you certainly have the facility to fix it.
Ladder106 is offline   Reply With Quote
Old 05-07-2013, 10:07 AM   #14687
dualdogdave
Twin Power Rules!
dualdogdave's Avatar
Oddometer: 148
TransHawk Repair Oil Pump
Thanks Guys for the props !
I have been noodling the problem reviewing my Honda Manual.
A look under the clutch cover should be very informative.
I have a spare set of clutch plates while I'm in there.
I'm just getting moved back into the garage after the remodel
This will be a good project to break in my new work space.
" In the pursuit of motorcycling excellence"
DDD
Santa Cruz Coastal Mountains
"TransHawk" Dyno Video: http://www.youtube.com/watch?v=tA-y7nxL580
"TransHawk" Dyno Charts:
http://picasaweb.google.com/adv990/D...05658028913170
Transalps and other cool bikes spotted in my travels.
http://picasaweb.google.com/adv990/T...eat=directlink
dualdogdave is offline   Reply With Quote
Old 05-07-2013, 09:39 PM   #14688
dualdogdave
Twin Power Rules!
Oddometer: 148
TransHawk Oil Preasure Diagnosis
Today I went exploratory on the TransHawk oil pressure issue.
It wasn't long before I got to the trouble............
I immediately noticed the slack in the chain..........
Then noticed fragments from the chain like pins and links.........
Then I pulled the clutch basket..........
Now the problem is obvious.......
The oil pump drive chain completely jumped off of the sprocket behind the clutch basket,,,,,,,,
I feel rather lucky...........
So what caused this ???????????????????????
This could have been catastrophic!!!!!!!!!!!!!
I will have to pull the oil pump still and make sure there is no more shrapnel in the sump.
Stay tuned.................
DDD
dualdogdave screwed with this post 05-07-2013 at 09:56 PM
Old 05-07-2013, 09:49 PM   #14689
Backonthebike
Giddy up
Backonthebike's Avatar
Oddometer: 675
Oh, I'm sorry Dave. Leather lounges, flat screen TV, designer Samsung brand floor mats??? Does your significant other know what you are doing in the house?
(NSFW) http://timothydunn.com.au/
I have come to accept that my role in life is simply to serve as a warning to others.
Backonthebike is offline   Reply With Quote
Old 05-08-2013, 12:48 AM   #14690
Ladder106
Ladder106's Avatar
Oddometer: 5,051
I know,
You could just sleep on the leather sofa.
Haven't seen the refrigerator yet.
Microwave for nachos?
Very nice indeed, Dave.
It looks at though a worn/slack oil pump drive chain was the problem. If you've ever had your mountainbike chain suck up into the frame chainstays while shifting to the small sprocket under load.....it's the same thing.
Chain jams and gets blown apart by the inertia of the engine.
As long as you can account for all the sideplates and rivets, you should be OK. Doesn't look like it made tiny metal shavings anywhere.
At least this makes me feel better about replacing the oil pump chain every time I replace a clutch in the TA.
Old 05-08-2013, 06:01 AM   #14691
mas335
xendurist
Oddometer: 2,005
Dave,
How many miles are on this engine? Given how these chains are made with multiple internal link plates I find it hard to believe that one could ever wear so much that it would jump off the sprocket.
I know they fit fairly loose even when new and the sprocket teeth depth is not great but from a purely mechanical point of view I can't image this happening, especially since it is not under a huge load. Just thinking out loud on this one. Do you know if this engine case side has ever been off before you got the engine? I assume you replaced the pickups with TA pickups so it has at least been off once since you got it?
I am also wondering if the Oil Orifice jet is turned backwards? On a Transalp the small diameter end faces outward and this one looks like it's reversed, the large port is facing outward. I got to admit I never had my two Hawk engines apart and I don't have a manual for one anymore so I don't know what the correct position is for the NT650 oil orifice.
Transalps
mas335 is offline   Reply With Quote
Old 05-08-2013, 06:40 AM   #14692
2old2Bbold
was 2bold2getold
Oddometer: 1,843
WOW, that could have been a lot worse !!! You could have been going 70mph down the highway. Maybe you could take the other side cover off, lay it on it's side and rense it out with something, Even a pressure washer would probably be ok, an air hose to dry it out, and then soak every thing in oil. Sure would make a mess, but you don't want to leave any bits in there. And then do a couple of oil changes. Just thinking out loud. Nice garage. You and DR E have got the right idea.
2old2Bbold is offline   Reply With Quote
Old 05-08-2013, 10:55 AM   #14693
dualdogdave
Twin Power Rules!
Oddometer: 148
TransHawk Oil Pump Continued..............
After sleeping on it, I took the next step, removing the oil pump sprocket.
Down behind and under the oil pump sprocket was this !!!
There had to be an answer.....
The Hawk motor was built from a low mile NT.
The TransHawk
odometer shows only approx. 14 + K miles.
Now the question is where did this mystery bolt come from ?
It is a 5mm button head socket cap (not Honda) and it appears to have passed through the works, the way it is all mangled up.
I have never had the case covers off.
Best I can speculate is: during some oil change it fell in the dipstick filler hole by freak accident.
Fortunately the chain is the only damaged part.
The pump turns with what seems the proper resistance yet tight with no end-play on the pump shaft.
Lets say that its all good,, and an opportunity to freshen up my oil pump drive chain and the old burnt smelling clutch pack.
And yes, once finished, the garage will have a kitchenette
I have a little beer box meantime.
ddd
DDD
Old 05-08-2013, 11:16 AM   #14694
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
You need to change your name to Lucky Dog Dave. Go out and buy a lottery ticket.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 05-08-2013, 05:15 PM   #14695
2old2Bbold
was 2bold2getold
Oddometer: 1,843
Lucky...yes. But if that bolt really dropped in through the oil filler hole, that seems pretty strange. Don't know if any of those were used in the motor but I'd sure be looking around for where it might have come from.
Old 05-09-2013, 04:46 AM   #14696
Big Chris
Oddometer: 87
650 Transalp: forks bottom out too easily - what's the fix?
I have an '04 650 TA, my forks dive a lot under braking, and when I hit the trails they have been known to bottom out with a disconcerting "clang" noise.
The bike's done about 40,000 miles, I'm a lot taller than average and weigh 98kg, sometime I load my bike up with luggage.
What have others doen to fix this problem in the past? Do I need fork springs? or do I need fork valves?
If I'm taking my forks apart what else would you reccomend I do whilst theey're in pieces, I'll replace seals obviously, what else?
Big Chris is offline   Reply With Quote
Old 05-09-2013, 10:26 AM   #14697
Ladder106
Ladder106's Avatar
Oddometer: 5,051
Replace fork bushings.
Respring for your weight and normal load. Local suspension shops can help here.
Install Ricor Intiminators or Racetech emulators.
Inspect, clean and relube steering head bearings.
Then think about how bad the rear shock has become when compared to the front and start saving for nicer rear suspension.
Good suspension really is the best money you can spend on your bike.
Old 05-09-2013, 02:13 PM   #14698
thepoddo
thepoddo's Avatar
Oddometer: 53
you can keep wasting your money on the stock forks or do what I did after trying everything, fit a complete new front pulled from a 2007 ktm sxf 250 (obviusly I changed the fork springs)
best money I spent on my bike
thepoddo is offline   Reply With Quote
Old 05-09-2013, 02:27 PM   #14699
AlpineGuerrilla
AlpineGuerrilla's Avatar
Oddometer: 399
Nice looking bike, thepoddo. I'm sure it handles like a dream. How did you get the rear to be so high? Would love to lift my bike up a bit more.
AlpineGuerrilla is offline   Reply With Quote
Old 05-09-2013, 03:04 PM   #14700
thepoddo
thepoddo's Avatar
Oddometer: 53
I reversed the suspension link and then I had a custom lower shock mounting bracket made by a machine shop (+2cm)
now I can barely touch the ground
Times are GMT -7.   It's 04:08 PM.
