Old 10-20-2008, 10:47 PM   #1
bowerbird OP
BMW R65
Oddometer: 142
BMW r65 richness problem
Just joined the board today. Hello all. I hope to add to all the great conversations going on here. I have a bit of a problem with an 82 BMW r65 I recently picked up on the cheap.
It was not running well and I discovered the left side plug was bad so I replaced them both. The now starts and runs but after about a minute or two, a lot of smoke comes out of the left pipe, a little out of the right. I tried a bunch of stuff to narrow this down.
Valve adjustment (tight now good)
compression check (130 in each cylinder)
timing check (good)
new carb floats
general carb cleaning
I even swapped all the jets, needles and diaphrams to see if there was any way to isolate the problem
So now I an a little lost. I don't think the carbs look bad but wonder if I could do a $70 overhaul if I don't know it will help I wonder if it is engine richness I am seeing and smelling. I think it is but am not completely sure. The next thing I'm going to do is inspect the enrichers and see if thee is anything obviously wrong.
Has anyone here experienced something like this?
Thanks for any advice.
bowerbird is offline   Reply With Quote
Old 10-21-2008, 12:48 AM   #2
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Check your left plug if it's oil or gas causing the fouling. Could be rings if it's oil.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 10-21-2008, 12:08 PM   #3
P B G
Oddometer: 10,001
would rings foul that bad and still provide 130 compression.
Old 10-21-2008, 12:16 PM   #4
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,725
My R80G/S is running 165 lbs of compression on both sides and still manages a good puff of blue smoke when starting every second or third time after sitting for a few days...
Don't know why yet, but am going to take the top end off to inspect this winter
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 10-21-2008, 12:18 PM   #5
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
Some pointers............
  • sooty black = fuel richness
  • shiny, oily black = oil fouling, could be rings, valve guides
First thing to check, regardless: be sure that the float is actually shutting off fuel. Do this by taking off the bowl, hold the float up manually, turn on the petcock, then slowly lower and raise it to see that the float needle is doing its job. If it does turn it off, you might try lowering the point at which it turns it off (turns it off sooner as it rises)
If it is fuel fouling: depends on the engine speed at which you ran this test: if they are black from idle only, check the idle circuit. If they are black from regular running, check the needle and needle jet.
Idle: the idle adjustment is idle AIR: screw it in, makes it richer, at idle ONLY.
Mid throttle: check to see that both needles are at the same notch (presuming that the other side is "good"), that needle is not worn, that jet is in place, etc.
and by the way.... Welcome! ... to this insane assylumm....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 10-21-2008, 12:49 PM   #6
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,573
Do you know how to adjust the mixture. The mixture screw is under the carb, turn it clockwise until the engine starts to die, then back it off until it also starts to die, then screw back in until you find the sweet point.
www.gsshop.biz
Steptoe is online now   Reply With Quote
Old 10-21-2008, 04:24 PM   #7
bowerbird OP
BMW R65
Oddometer: 142
The plugs are chalky black and dry (fuel). I'm prety sure oil isn't getting into the combustion chamber. I'm still stumped. I may try getting "hotter plugs" The manual calls for Bosch W6D. The bike came with Bosh W5D plugs which are cooler. I wonder if this could make a change. Can smoke be attributed to plugs?
Old 10-21-2008, 04:42 PM   #8
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
No, plugs couldn't cause this. Specially a one-step change in heat range. besides, it only happens with the left side.
As someone said, check your float height. It could be the key to your issues.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 10-21-2008, 04:45 PM   #9
bowerbird OP
BMW R65
Oddometer: 142
thanks for the reply, I'll look at the floats furhter.
The idle mixture screw stock setting is 3/4 turns out. Could the idle mixture come out?
Old 10-21-2008, 05:02 PM   #10
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
It could but after many, many turns. Try 1-1/4 turns out as your starting point, then adjust for better tickover.
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 10-21-2008, 06:42 PM   #11
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
What I tried to ask earlier:
  • Is it running rich at IDLE??
  • Or at all speeds??
IF it is running rich at idle, try turning the air screw OUT more for a less-rich mixture. But, you may just have to pull the carb and blow out the air passages.... those are teeny tiny and you might find a passageway blocked, or partially blocked. Idle circuits are fussy....
Loving the 80ST
Old 10-21-2008, 08:53 PM   #12
jdiaz
Oddometer: 32,184
Did someone re-assemble a choke plate backward?
jdiaz is offline   Reply With Quote
Old 10-21-2008, 08:59 PM   #13
Steve516
Guzzis R Us
Steve516's Avatar
Oddometer: 345
Also check out and join in over here
www.r65.org, for a great worldwide group of R65 fiends and all your R65 needs.
Good luck !
Steve516 is offline   Reply With Quote
Old 10-21-2008, 10:02 PM   #14
bowerbird OP
BMW R65
Oddometer: 142
Thanks all. Is id rich at idle but if I rev it, smoke gets worse. I have not had the enricher off yet so plate (if I am imagining this correctly) is not backwards. I made some progress with the idle adjust. I got rid of the smoking on the left side and replaced it with smoking on the right side. Since I changed a couple variables at the same time I'm not 100% sure if that was the complete fix.
I messed with the carb floats before I fired it up plus yesterday. I swaped the jets needles etc to see If I could put the blame on those parts. The swap did not seem to do anything by itself though. Tomorrow Im going to fiddle with the idle adjusting screws a bit. It was the first positive change I've had so I'm going to see what more will come from adjusting these.
It seems like there was infact some starvation of gas as the bike just quit after several smoke-free minutes of running. This was welcomeThanks so far for the detailed advice. I use to spend a lot of time on thesamba.com and got great feedback and advice for my bus. I am happy to know there is such an active resource here!
Old 10-22-2008, 12:51 AM   #15
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
I think you got it the other way around. Thes eare Bing CV carbs, right?
OCJ
92 R100GS-PD Euro
07 R1200GS
Times are GMT -7.   It's 06:44 AM.
