10-22-2008, 10:02 PM
#1 |
Oddometer: 112
pirelli mt-43 trials tire..DOT yes!
Just installed a Pirelli MT-43 on my exc 450. will let you know what happens this weekend.
10-23-2008, 06:43 AM
#2 | |
Professional Idiot
Oddometer: 925
10-23-2008, 12:36 PM
#3 |
Oddometer: 77
Mt-43
I've been running one all summer, offroad and on. it's been great during dry rocky rides and holds well on the road too. but get into any sitcky gumbo style mud and be prepared to work hard to keep going the direction you want. I had read that prior to buying so I wasn't surprised. for most of the terrain around here (upstate NY - rocks, roots, gravel, with mud thrown in) it works really well. I've put about 1000 miles on it, about half off road, half dirt roads and pavement and it hasn't really worn much at all. no knob chunking, still have pretty good edges. I'll definitely buy another one.
2008 990 Adventure 2008 450 EXCR 2001 453 MXC - Sold 1995 250 EXC - Sold |
10-23-2008, 06:47 PM
#4 | |
Oddometer: 3,902
2012 Husaberg TE300 - "Huzinger" '07 Husaberg FE650E - "The Monster" - Dual sport '05 Husaberg FE450E - Sold '03 KTM 640AdvR - Sold, and I miss her Several other KTMs, Suzukis, etc. |
10-23-2008, 07:57 PM
#5 |
Justa Venturer
Oddometer: 1,245
I just ran into 3 guys with KTM Thumpers this afternoon with Dunlop and Michelin trials tires. They couldn't be happier with them. Here in Western Or. it is pretty muddy, rocky and rooty. The only complaint was steep downhill.
Really got me thinking again about trying one. I had the feeling they would be a summer tire only, but......
___________________________________________ So much riding-so little time |
10-23-2008, 08:18 PM
#6 | |
Still alive...
Oddometer: 10,718
That's not very practical for a DS bike ridden on road, so most, out of practical necessity, run at least 12 and up to as much as 20 psi. The MT43s have a stiffer sidewall, so you can get away with running a little less pressure than the Michelin and Dunlop trials tires. Drop a trials tire down to 4-8 psi and most of the downhill "feel" issues evaporate. Of course, when it's time to leave the trail and take the road home, 8 psi is a little sketchy at 50 mph on asphalt. Some carry CO2 bottles or itty bitty pumps and refill their tires for the road. C |
10-24-2008, 03:38 AM
#7 |
I did that.
Oddometer: 6,433
Michelin Trials radials make lousy rears for DS work. Tried them twice on the XR, scared me shitless at a little over 35mph as the bike continually crabbed sideways in a straight line. Can't comment on the others, never tried them. But the Michelins work great on trials bikes.
10-24-2008, 04:17 AM
#8 |
Oddometer: 77
pressure
I'm running about 8-10psi all the time. I don't check it often other than to squeeze it with my hand to make sure it's still got air. I'm also running a bridgestone UHD tube, it makes the sides a little stiffer and I don't have to worry about pinch flats.
10-24-2008, 07:29 AM
#9 |
Go ahead, U pick
Been running trials tires for years, in fact every bike in the garage (except the TE610 that JUST arrived) has one on it.
For years folks would sneer and comment about how we didnt have real "knobbies" until they tried to follow us in the rocks roots and snot. Tried.... ![]() Mitas also makes a DOT version but it chunked up pretty quick over 40 mph on the road. If your a slam - power and brake slide and dance rider off road they wont work for you. The absolutely SUCK if you try to play "pro" on nice flat grass track... As has been mentioned, if you run in rocks, roots, dry pack, snotty stuff and clearly with the new MT-43 pavement, once you try one, well you will be a bit upset you didnt change over sooner. In the dirt only mode we get 3 seasons EASY on a rear. Traction is like velcro. I run dual rim locks off road, UHD tubes and slime and about 8-10 (max) psi, as long as I dont plan on running anything over 40 mph. get past that with the low pressure and things get religious REALLY FAST ![]() bump it up over 15 PSI for road work and is still pretty sweet off road too. Trials tires are something pretty magic and the low tire pressure softens up the rear suspension as well in the rock and roots... ONLY thing we run up here off road in Western Washington. HR
2008 FE500 Husaberg -- 2004 CRF 270x -- 1983 XC500 Husky (Ten Fins of Fury) -- 1981 YZ465 Primary Vintage MX racer -- 1982 IT250 (250 Vintage MX racer with Eric Gorr Motor!) -- 1973 MX360 - - No, I dont have enough yet... |
11-07-2008, 04:53 AM
#10 |
devro
Oddometer: 468
Same here in NW Arkansas where we have mostly rootz 'n roks. I have been using the IRC radial trial, it works fantastic! I air to about 8-10 off road and maybe 20-25 on road. The tire wears pretty quickly on road but otherwis does fine. I get about 1200 miles of combined trail/road use.
I can't say anything bad about the tire, it's like cheating on gnarly single track. I ran into a few riding acquantences who are running the Pirelli MT43 and really like it. These guys are F A S T AA harescramble and enduro riders. They also DS a lot. They are using the Pirelli exclusivly now, both DS and racing. They run 6-7psi off road and 15 on road. That sold me, I have my order in for my first Pirelli MT 43. |
11-07-2008, 03:45 PM
#11 |
BS for short
Oddometer: 9
Maybe irrelevant to its performance, but what front tire are you guys using with the MT43?
12-30-2008, 11:18 AM
#12 |
Oddometer: 312
If you were going to race on dirt and gravel roads (not clay just your basic Northwest dirt and gravel forest service road) wet OR dry what are your thoughts on this tire?
The name of the game is speed here as the roads are closed to traffic and are marshaled. It sounds like the traction to twist it up out of the corners would be good. My concern would be how they do hitting 80+ mph for short stretches and how they drift in the corners with that low of pressure. My only concern I guess is how they would handle having the rear locked up to start a slide. I read somewhere that once they loose bite do to a slide they under perform and are a bit scary. Basically looking for a good RallyMoto tire and to be honest once of the tarmac I'm a noob. Thanks!
Do not mistake for wisdom the fantasies of your sick mind ropedrag screwed with this post 12-30-2008 at 11:30 AM |
07-11-2009, 02:29 PM
#13 |
3rd Wheel Adventurer
Oddometer: 505
I would also be interested in how a trials tire does on gravel. I had a wr450 with trials tires and loved them. Got a lot of miles before knobs started chunkin off. I would like to know how they handle on a xr650l. I ride 40 mi. a day to work and home on rough pavement. play every chance i get on gravel (high speed) and dirt single track. I know they will do great on dirt and single track but would like to hear from someone about gravel and pavement.
later |
07-12-2009, 02:49 PM
#14 |
Oddometer: 5,313
The MT43 is DOT approved to over 90 MPH. It is not like the other Trials tires.
08-18-2009, 03:33 PM
#15 | |
Oddometer: 77
Cheers, 6fiddy |
