08-18-2010, 02:49 PM
#31 | |
Geek Adventurer
Oddometer: 4,601
If you are riding on the pavement at all then the MT43 is about the only trials tire you should use - the competition trials tires are good off-road, but too soft for any pavement mileage. Maybe that is what they were thinking of?
'09 Husaberg FE570 '99 Beta Alp '04 Ducati MTS - sold Not all who wander are lost |
08-18-2010, 03:03 PM
#32 | |
Oddometer: 5,313
08-18-2010, 06:15 PM
#33 |
Oddometer: 270
sounds good so if i get the tire im afraid i will need a longer chain... any suggestions on what chain to get or do i break my chain and put a master in it... if i do that i prolly will need a shop do do that. also any type of chain better than others?
08-18-2010, 07:17 PM
#34 |
Fat Rob
Oddometer: 31
sizing
wonder if I could run Mt 43 as a replcement for a 140/80-18 ?
looking to run on a 690E Robt |
08-19-2010, 09:03 AM
#35 | |
Geek Adventurer
Oddometer: 4,601
08-19-2010, 07:33 PM
#36 |
Oddometer: 112
Bike set-up with trial tire. MT-43
This tire gets such good traction that it tends to launch the front end in tight or steep technical sections. After tipping over, or trying to catch a launching bike, my father in law suggested I use tire pressure to mellow the launch effect. I would raise the tire pressure until I found a sweet spot between traction and controlability. Eighteen pounds for desert conditions, let's me get through the big rock sections with great traction, yet allowing me to get through big sand washes.
In the forest, I like to run sixteen psi as an overall perfect package. Single track, jeep roads, and big granite rocks get equally great traction. This higher psi also keeps me from pinched flats in the desert, and sharp sticks from puncturing the tire in the forest. ![]() ![]()
08-20-2010, 10:48 AM
#37 |
Oddometer: 1,072
I'm surprised you "need" to run such high pressures. Maybe a little better throttle control would help? You're certainly loosing a lot of traction off-road at those pressures; why not just run a knobby? If you don't want the extra traction of the trials tire, a knobby is a better choice as it's more controllable in the corners.
I've found this tire to be really good at 8-9 psi in the woods; I'd go down to 6 psi if I weren't riding on the pavement as well. For long stretches of pavement and gravel roads I'm running 12 psi. |
08-20-2010, 01:51 PM
#38 |
Ride you must.
Oddometer: 1,675
I found 18 psi in sand terrible. Even at 12 i never pinched but did manage to stick a catus thorn through. More pressue wouldn't have stopped that.
One finger on the clutch is the loop out answer. Easier to modulate than the right hand only.
I eat my candy with the pork and beans- |
08-20-2010, 02:37 PM
#39 | |
Oddometer: 5,313
08-20-2010, 02:56 PM
#40 |
Hydrophobic
Oddometer: 2,414
I've been running one at 14 psi, but I'm heavy and a lot of times run the bike on the heavy side. I pinch flatted at that pressure, but it wasn't what you might think. I must not have tightened the rim lock down enough and when I hammered the throttle on pavement it spun the tire on the rim ever so slightly, pinching the tube under the rim lock.
![]() It's also mounted on a cush drive wheel I bought when I had an LC4 (625).
2011 KTM 990 Adventure R 2010 KTM 530 EXC 2009 KTM 950 Super Enduro Erzberg Edition |
08-20-2010, 03:07 PM
#41 | |
Oddometer: 1,072
08-20-2010, 05:23 PM
#42 |
Oddometer: 112
Control...
My throttle control is just fine, so is my riding. I'm sure you guy's are great riders...all I have to do is ask. I am a big guy, 235lb, which changes a few things. These psi figures are an example of how to adjust traction on the fly. I have run my tire as low as 10 to 12, but found out that higher psi worked overall. The Mojave desert is not a forgiving place,and most riders will run higher psi out here. If you have not changed one of these on the trail, they can be difficult. In the Sierras, some guy's will run 8 to 12, depending on conditions. I ran the last dual sport ride at 14, but had very little road sections.
I'm not trying to tell you what to do, I just wanted to offer a way to adjust traction on the fly. This tire is as good as it gets. Sharp, rocky desert conditions are not the same as loamy Washington or quick sand Florida. I hope to make it to the NW to try out this tire in loamy condition. If you want to see what conditions I ride in, check out my blog http://www.iridedualsport.com and check out Mojave. Send me some pics and videos from your rides and I will post them. I would like to compaare terrain types and riding styles to this tire.
08-20-2010, 07:47 PM
#43 |
Oddometer: 5,051
I run 6-8 psi in the trials tires on my KTM XCFW 250.
I also use the Tubliss setup. |
08-21-2010, 08:48 AM
#44 |
Fat Rob
Oddometer: 31
front tyre choice
It's starting to look like the next tire for me (MT43) So what is a good partner for the front ?
Current MT21 F TKC R 690E conditiions ........ gravel, cinders, areas with multiple cond, woods, slab any where from 1 mile to 200 miles to get to areas. Robt |
08-21-2010, 09:00 AM
#45 | |
Bouncing off Rocks!
Oddometer: 2,394
As far as tire pressure when I had 14 psi in my MT43 it made control on gravel rather "fun" so to speak....8 psi works fine on all surfaces for me....
"If you're going through hell.......Keep going!" On Hiatus |
